Manage categories
Close
Create and manage categories in After Effects Scripting. Removing a category will not remove content.
Categories in After Effects Scripting
Add a new category (0 remaining)
Manage Announcements
Close
Create and manage announcements in After Effects Scripting. Try to limit the announcements to keep them useful.
Announcements in After Effects Scripting
Subject Author Date Actions
Discussions
Items per page
Filter:
1 2 3 Previous Next
Author Status Subject Views Replies Last Post Modify Date
Adam Volerich Adam Volerich Calculating status... How can I export speech analysis text with imbedded timecodes for the creation of subtitle files? 145 1 1 month ago by Adam Volerich 1 month ago
afgkljshglkjsd afgkljshglkjsd Calculating status... scripting reference 114 1 1 month ago by afgkljshglkjsd 1 month ago
kjubi kjubi Calculating status... How to suppress project warnings so they not block an opening script? 140 2 1 month ago by kjubi 1 month ago
paulinventome paulinventome Calculating status... Creating Comp With Timecode from Imported Footage 231 6 1 month ago by paulinventome 1 month ago
flashframe1 flashframe1 Calculating status... setSpatialAutoBezierAtKey() method 162 2 1 month ago by flashframe1 1 month ago
Jerry Witt Jerry Witt Function myPanel.add is undefined for Papagayo Lip Sync script 215 2 1 month ago by Jerry Witt 1 month ago
SFBurning SFBurning Calculating status... Why must I use the absolute path to an expression property when accessing it via a script? 306 4 2 months ago by Alan_AEDScripts 2 months ago
Ichabodcole Ichabodcole Need to make sure layer names are unique 474 4 2 months ago by David Torno 2 months ago
Lazlo Hollyfeld Lazlo Hollyfeld Possible to restart AE within a script? 198 1 2 months ago by Todd_Kopriva 2 months ago
Lazlo Hollyfeld Lazlo Hollyfeld Using File.copy to overwrite a file that is read-only. 171 1 2 months ago by Lazlo Hollyfeld 2 months ago
Dimn7211 Dimn7211 Calculating status... Execute commands on Project save? 181 1 2 months ago by David Torno 2 months ago
Dimn7211 Dimn7211 Unique Layer IDs? 191 3 2 months ago by maxweel 2 months ago
joeydanna1 joeydanna1 Calculating status... Javascript math.max bug in AE cs5 1,125 11 2 months ago by Todd_Kopriva 2 months ago
sylvaimz sylvaimz Calculating status... environment variable 513 3 2 months ago by CenekStrichel 2 months ago
Lazlo Hollyfeld Lazlo Hollyfeld How to detect the OS with ExtendScript? 216 2 2 months ago by maxweel 2 months ago
Dimn7211 Dimn7211 Reference item by ID 198 2 2 months ago by Dimn7211 2 months ago
orangechicken orangechicken Calculating status... Adding an expression to Source Text breaks alignment? 195 1 2 months ago by Dan Ebberts 2 months ago
orangechicken orangechicken Is there a way to script a composition to generate & control clips similar to Flash's ActionScript? 185 1 2 months ago by David Torno 2 months ago
Dimn7211 Dimn7211 Saving Script Data to Project? 310 5 2 months ago by chauffeurdevan 2 months ago
A. Cobb A. Cobb AE CS4 ExtendScript documentation? 1,371 12 2 months ago by Todd_Kopriva 2 months ago
i_like_nothing i_like_nothing Calculating status... Where is the documentation!? 261 1 3 months ago by Paul Tuersley 3 months ago
Jesse Toula Jesse Toula Calculating status... Script UI Panel not showing in Window Menu 376 3 3 months ago by Jesse Toula 3 months ago
bradvr4 bradvr4 Calculating status... After Effects 3D Transformation Stack Values and Javascript 287 1 3 months ago by françois leroy 3 months ago
Lazlo Hollyfeld Lazlo Hollyfeld How to retrieve the path where AE is installed? 296 3 3 months ago by Lazlo Hollyfeld 3 months ago
edgarSalgado edgarSalgado Calculating status... Is it possible to make a dropdown list collapse using code? 394 4 3 months ago by edgarSalgado 3 months ago
taravasya taravasya How to disable one separate effect control? 256 2 3 months ago by taravasya 3 months ago
Lazlo Hollyfeld Lazlo Hollyfeld Creating portable psuedo-effects for AfterEffects 291 2 3 months ago by Lazlo Hollyfeld 3 months ago
Lazlo Hollyfeld Lazlo Hollyfeld Script that implements a ripple edit? 266 3 3 months ago by Alan_AEDScripts 3 months ago
Zhiqiang_Li Zhiqiang_Li Calculating status... preferredSize() doesn't work! 312 4 3 months ago by Alan_AEDScripts 3 months ago
colacholaborde1973 colacholaborde1973 Calculating status... UIScripts don't appear at the bottom of the window menu 300 3 3 months ago by Todd_Kopriva 3 months ago
