Manage categories
Close
Create and manage categories in PDF Language and Specifications. Removing a category will not remove content.
Categories in PDF Language and Specifications
Add a new category (0 remaining)
Manage Announcements
Close
Create and manage announcements in PDF Language and Specifications. Try to limit the announcements to keep them useful.
Announcements in PDF Language and Specifications
Subject Author Date Actions
Discussions
Items per page
Filter:
1 2 Previous Next
Author Status Subject Views Replies Last Post Modify Date
(mattad) How to permanently rotate pdf 90 deg? 356,047 7 5 days ago by Test Screen Name 5 days ago
sherwood_morovia sherwood_morovia Calculating status... change font in DA of FreeText Annotation 155 1 2 weeks ago by lrosenth 2 weeks ago
tetleyforget tetleyforget Calculating status... PDF File with Run Length Encoding? 873 10 3 weeks ago by tetleyforget 3 weeks ago
OleK OleK Calculating status... Example font subset with non-unicode output 838 26 4 weeks ago by Test Screen Name 4 weeks ago
bobhopfner bobhopfner Form field info not showing up, unless field is clicked? (again) 410 2 1 month ago by lrosenth 1 month ago
nanoBarry nanoBarry Calculating status... Indexed png transparency using /Mask 732 8 1 month ago by lrosenth 1 month ago
baccah baccah Some characters extracted from pdf hasn't corresponding unicode in its font 913 9 2 months ago by Test Screen Name 2 months ago
bobhopfner bobhopfner page height is zero 759 7 2 months ago by Test Screen Name 2 months ago
JayP111 JayP111 Calculating status... in browser- URL of PDF where it imports FDF data 2,061 15 2 months ago by Stuck Mojo 2 months ago
tetleyforget tetleyforget PDF Stream Extent? 937 8 3 months ago by Test Screen Name 3 months ago
Lev Reznikov Lev Reznikov Calculating status... Is it possible to control the height of the Portfolio panel via the PDF Portfolio itself? 464 1 3 months ago by lrosenth 3 months ago
botnico botnico Calculating status... Simple pdf file leads to wrong output color, whats wrong? 636 3 3 months ago by Test Screen Name 3 months ago
kevinyuan kevinyuan Change the image under Form XObject to the first layer 792 6 3 months ago by kevinyuan 3 months ago
Hezi Hezi Convert text file into pdf with hebrew charcters 1,133 10 4 months ago by Test Screen Name 4 months ago
tetleyforget tetleyforget Reading a PDF stream for LZW decompression? 621 1 4 months ago by lrosenth 4 months ago
cheng845 cheng845 how to insert png to pdf? 3,076 3 4 months ago by amit12121989 4 months ago
Rudylandnet Rudylandnet Calculating status... PC users can't save PDF form data from form created on Mac 52,267 10 5 months ago by lrosenth 5 months ago
ToM_1st ToM_1st Calculating status... Appearance state (AS) vs. value (V) of Button Form Fields 742 2 5 months ago by ToM_1st 5 months ago
Gudel Corporation Gudel Corporation Calculating status... PDF-Printer Settings 987 2 5 months ago by Gudel Corporation 5 months ago
Xavier.d@adobe.con Xavier.d@adobe.con Calculating status... How to download Adobe-UCS-0 cmap? 793 1 6 months ago by Test Screen Name 6 months ago
kevinyuan kevinyuan Question on OPM as 0 1,248 7 6 months ago by kevinyuan 6 months ago
Xavier.d@adobe.con Xavier.d@adobe.con How to find decoder name from decoded stream? 1,079 5 6 months ago by olafdruemmer 6 months ago
baccah baccah This font not work with me after extracting it from pdf! 981 5 7 months ago by Test Screen Name 7 months ago
WCoder WCoder Calculating status... Problem with invalid /Pages on root obj... 1,399 8 7 months ago by WCoder 7 months ago
benny10men benny10men Problem saving Reader extended PDF with Javascript functions built in 1,653 8 7 months ago by Test Screen Name 7 months ago
Mohammed_Mostafa Mohammed_Mostafa Calculating status... How can I check text rotation when extracting text from pdf file? 2,717 23 7 months ago by Test Screen Name 7 months ago
baccah baccah Extract embedded fonts from pdf 5,011 10 7 months ago by baccah 7 months ago
Mohammed_Mostafa Mohammed_Mostafa Paragraph detection in pdf 1,559 9 8 months ago by Test Screen Name 8 months ago
xfrapp xfrapp Calculating status... Extract embedded xml from PDF/A-3b (also creation) 1,634 2 8 months ago by olafdruemmer 8 months ago
WCoder WCoder Decoding TJ on BT...ET block... 2,149 13 8 months ago by WCoder 8 months ago
Actions
Notifications
