>>Yes, it sucks.
No, it doesn't. It was poor style to ever do that and good developers didn't anyway. Now, you're forced to produce cleaner code, as it's more consolidated, and not scattered over a bunch of objects.
quote:
Originally posted by: Bloom
So if I do what Andrei says, it should be using AS3, correct?
quote:
No, what I suggested was AS2 code. This code is used when onRollOver functions is assigned to your button on the main timeline.
Since you are using the on(rollover) from withing the instance and if stageRoaster is located on main timeline - you need to change the scope of stageRoaster. It either can be _root or _parent:
on (rollOver) {_root.stageRoster.loadMovie("playerMovies/hahnJordan09.swf");
quote:
Originally posted by: abeall
If it does nothing at all then your code is not attached at the time you are rolling over the button. How many keyframes do you have for the button?
