Same Problem - Adobe Media Encoder crashes:
Adobe Media Encoder has encountered an error.
[..\..\Src\Win\WinFile.ccp-754]
Clean Installation, Vista 64 + CS4 Master Collection, all Updates (30 Min, one Restart) CS4 Vista 64bit, Intel Core2 Duo T9300 @ 2.50GHz, Video Ati Radeon HD 2600 XT.
Sorry, CS4 Master Collection is a nightmare, it is unproffesionell!!!
Help please!
A really frustrated User!!
Helmut Lehmeyer
rharvster wrote:
I get a runtime error, saying the program has asked to be terminated in an unexpected way.
Using Athlon XP 2600+ processor
Wonder if it will be fixed or ignored...
Ditto:
Same error message.... Same processor...
Actually the exact message is:
Runtime Error!
Program: C:\Program...
This application has requested the runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
Hello,
I get runtime error in Flash CS4. For example when I select text field opens dialog box and then drops down Flash:
MS Visual C++ Runtime Library
Runtime error!
Program: C:\Program Files\Adobe\Adobe Flash CS4\Flash.exe
This application has requested the Runtime to terminate it in an unusual way.
Please contact the applications support team for more information.
If you have solution write it please.
Don't know if this helps anyone else, bt the runtime errors i have been getting occur when I try to build and burn a blu-ray file. And they happen intermittently. In fact, on this project, I had burned several test blu-rays without difficulty. When I made one minor change on the penultimate version, and tried to burn again, the system crashed with a run time error. Then it crashed 9 more times over the course of the week.
Finally in frustration, I created an interim ISO file in Encore- ie in the build workstream, i selected burn an image file rather than burning a blu-ray disk. After this intermediate step completed, i then did a separate burn in encore but burned from the image file. No snags.
Not sure why but this program has trouble doing a sequence of activities. As it is, I already render and save the file before burning. Now I have another interim step to create an image file before burning.
In my next hardware change, I am going to switch to make Mac and Apple software. Enough of MS Windows and Adobe, the GM and Chrysler of the software industry. Hopefully what my friends tell me is true; that Apple stuff actually works.
Hello,
Try this:
deactivate your Adobe software pack uninstall it (and other professional software that needs deactivate and uninstall before next step). Then reinstall your OS, after reinstall turn off automatic updates (OS WIN) and also dont update in between install. Install drivers (for your hardware), etc. Then install Adobe software pack aktivate it. And it may work. In my way it working.
Have a nice day.
mio_kol
P.S.:this may work for everybody who has runtime error.
mio_kol wrote:
Hello,
Try this:
Have a nice day.
mio_kol
"Then reinstall your OS..." laughable. this is not a solution.
Dear vivid007,
you wrote : "laughable. ...". From my position it isnt because I need to work with Adobe CS4 package all the day everyday and that was the fastest solution. But if you have some usable solution just write it... Because I just want to help to somebody who is in the same position like I was.
So if you have something usable than write it. And unusable (like your words: "Then reinstall your OS..." laughable. this is not a solution.") write to another corporations.
Thanks.
MM
I have to agree with info@h-m-l.de in post 13. Very unprofessional garbage Adobe has released. Feels like a beta. I've heard others on the forums defending this release, but they are out of their minds. Maybe they're paid by Adobe to say that. This **** crashes so often it's unreal. My livelyhood depends on these programs, we paid 2500 bucks for this junk, and it just doesn't work.
And no Adobe, don't say it does, or you Adobe lovers. Premiere or AE working all the way up until you render, then crashing does me absolutely no good. In fact, it's worse, because I spent a month on this animation and now it seems I won't be able to render. CS4 Master Collection is absolute garbage.
I had the same problem on my mac when I changed computers and
upgraded to snow leopard. The media encoder crashed and gave an
error. I then uninstalled Flash CS4 and reinstalled it and now it works. Probably
there is something changed or deleted during the upgrade, which causes this problem.
I just ran into this same error and I found the cause.
Earlier today I used the program for the first time without an issue. I then had to install the trial version of Camtasia 6 to work on an associate's files. After then creating an avi from after effects I wanted to use the media encoder to export an f4v file but got the error. I tried reinstalling production premium but still got the error. I uninstalled the camtasia trial and now media encoder works fine. Hopefully that helps some of you.
I can see this issue has years and years, I will tell you shortly what was my experience dealing with this error:
The Real Problem:
In my case the problem was (as somebody else said) an error with the audio track of my video, not with the encoder/decoder but the audio track itself,
My solution:
I separate the audio track from the video, import them in Premiere and then export the video with the AME normally.
Hope this will help you all.
This has nothing to do with SSE2 I wish people would stop posting that as a solution. You need to have a REALLY old processor to run into that problem.
The issue is Quicktime.
I am on Windows 7 x64 and I get the "Load Audio Only" error when the latest Quicktime is installed (7.6).
If you uninstall Quicktime, Media Encoder and all other affected programs will work.
But, you can't use iTunes which blows.
Stuff like this just undermines Adobe's credibility as developers.
Well, I've now the same problem: AME, at the Loading Audio Only splash, simply crashes. I tried everything: uninstall/reinstall CS4, uninistalling Quicktime, upgrading AME with the last update (CS4.2), upgrading my OS, drivers and everything... Result: a fu**!!
I'm really bored of these Adobe crap that doesn't work when it wants. I tried also to delete the folder 4.0 in my users\Apps blabla folder, restarted the SO but nothing happes: AME crashes ALWAYS loading Audio Only. Any suggestion?
