Strangely, that solution hasn't worked for me.
I get the same message of "Warning: The size of stop file has to be limited in 512 bytes." but it still successfully compiles the help. I began to wonder if one day it would decide to NOT compile the file, so I started researching preventative measures and stumbled onto this post.
I tried moving my project into a Project folder at the C:/ level as suggested, but I'm still getting the same message. I'll try the idea of creating a new project next and swapping out the .STP file, and see if anything changes.
Georgina
Hello,
This is long but I am trying to give specifics and background. I am stuck with this problem despite search for a solution here and on the web. None of the possible solutions offered here worked for me.
RoboHelp 8 with .1 and .2 patches / upgrades installed in sequence and running on recent DELL with XP.
Background:
I inherited a HTML help project which was stored on and run from a network drive (a big no-no) for 3/4 months. I was not aware that the project was run from the network. The previous help author had problems with performance and stability when the project was upgraded from Robohelp 7 to the initial 8 without the upgrades / patches which were not available yet.
I stored the active project on my local C: drive and have zipped up the whole project at intervals and stored the backup on the network. I can revert back with the loss of about 1 days work but the concern is that there is something unstable with the whole project. I have Breadcrumb Browse Sequences implemented and this current version of our software was the first one to register the Adobe redist HHActiveX.dll during install. Everything worked fine with the .chm. from the application. I could call the help for the different objects plus the Breadcrumb displayed.
The help file also has some dropdown text DHTML effects which hide the content for a tab on an object. I am working with RoboHelp 8 with the two upgrades done in sequence .1 and .2.
Immediately before, I had this problem, I was assigning context ids to topics and plus created a number of new placeholder topics with an ID asigned. I was using Bughunter to see what context ID different parts of the interface was calling. I had also just imported a second map file with the IDs for the interface.
When I Compile MS HTML Help Its Now Fails:
I get this problems when generating .chm help:
'Warning: The size of stop file has to be limited in 512 bytes.'
and then at the end
'ehlpdhtm.js
Fatal Error: Unexpected error from Microsoft HTML compiler.
Finished compiling HTMLHELP in 71 sec(s)
Compilation complete.'
Also
During compile I get some warning messages like this one:
'HHC4014: Warning:
The following map definition has an invalid context ID: #define HIDO_DIGITAL ANIMATION OBJECT 21311000.'
I Tried the Following to Fix This Problem(s):
1) I have Robohelp 8 with the .1 and .2 updates done.
2) I shortened the file path to:
Starting compilation...
HTMLHELP preprocessor 8.0.0.203
Compiling C:\RH8_Pjts\OWS340\!SSL!\MS_HTML_Help_Layout2_Dec8_2009\!chm_tmp_fold er_0\Copy_of_helpfiles.chm ...
C:\RH8_Pjts\OWS340\!SSL!\MS_HTML_Help_Layout2_Dec8_2009\!chm_tmp_folde r_0\Copy_of_helpfiles.hhp
Microsoft HTML Help Compiler 4.74.8702
3) I Reset to Default the stop list. File> Project Settings. Press Advanced Button and then Press Reset to Default.
4) I created (deleted the previous ones) a new version of two topics listed before and after the message. 'Warning: The size of stop file has to be limited in 512 bytes.' I excluded some topics from the build to see if I could generate a CHM and find a topic with possible problems.
5) I created a new layout from scratch but still the same problem.
6) I renamed the .cpd by appending _OLD to the name. When I generated a .chm, it gave the same behaviour. The file size did decrease from 3.2 MB to 1.5 MB. I am aware of the Tools > Options > general tab and the checkbox for 'Clear project cache (.cpd) file before opening any file'. For now, this is unchecked which is the default.
7) If I try to generate a chm from the same MS HTML project layout without shutting down, I get this message:
'Cannot create compiled file. It may be open in another window. Please close all HTML Help windows and try again.'
It will try to generate from a different MS HTML layout without restarting RoboHelp and you do not get this message.
Other Possibe Things to Try:
If anyone has any suggestions, I would welcome them. I keep hoping for some simple recipe to heal my sick project!
One thing that I have not tried is to delete half the topics and then try to generate a chm. It is like what I do with long unstable Word doc files and sometimes it is just one tiny icon graphic that is bad or I just have to delete one line and type it in again and the file is immediately healed.
Clutching at straws!-- One thing that I notice is that the Project Properties have English (US) but some of the topics have None for language in the Topic Properties.
I can revert back and generate a chm to be sure it is ok and then redo my recent changes but with frequent zips of the project and also generations of a chm.
Robert
Let's see if anything here helps.
First thing to get out of the way is the warning. It is just a warning that the stop file must not exceed that size. It is not a statement that it does and as the previous posts show, it always appears. Create a brand new project with just the default topic and you will still see the warning.
What you will see has fixed the problem using Rick's advice is to shorten the path length. Now while the path I can see in your post is not excessively long, it does contain more characters than necessary and when you add that to the paths in your project, length could still be the problem.
Open one of the supplied sample projects and generate a CHM from that. If the new project and the sample project both compiled OK with just the warning, that confirms your installation can compile OK and then it all points to your project and I think path length is the first thing to consider.
Follow me @petergrainge
... and don't worry about the language settings. Project settings defines the language to be applied to all topics except those that have another language applied. If the two languages are the same it will do no harm but it is a bit pointless.
Hi Peter,
Thanks for the prompt reply.
I can compile to chm with the CCC Sample Project with the stop file message appearing in the compile output.
D:\My Documents\My RoboHelp Projects\Adobe RoboHelp 8\Samples\CCC\!SSL!\Microsoft_HTML_Help\CCC.chm
I also got a copy of another smaller MS HTML project that I maintain and it compiled to chm fine.
I tried to compile my problem larger project from the hhp using FAR and it fails to generate chm. (I can generate a chm from another project with FAR.)
These are examples of the four types of warnings generated.
HHC4003: Warning:
The following option line does not contain an '=' character separating the option and its value: [OPTIONS].
HHC4001: Warning:
The following alias line does not contain an '=' character separating the topic IDs: </alias>.
HHC4014: Warning:
The following map definition has an invalid context ID: #define HIDO_DIGITAL ANIMATION OBJECT_OBJECT 21311001.
HHC3004: Warning:
calendar_generic.htm :
The HTML tag "?rh-placeholder type="footer" ?" is not a valid HTML tag (it does not begin with an alphanumeric character).
(I got the KeyTools Error Reference Guide)
To me, these finding would seem to confirm the operation of RoboHelp 8 and point to the project files and / or the configuration specified for this problematic project. Maybe?
I had already shortened the path for my problem project to:
C:\RH8_Pjts\OWS340\!SSL!\Microsoft_HTML_Help\OWS340.chm
(maybe, I could reduce the previous path by a further 7 to 9 characters, I will try)
from D:\My Documents\My RoboHelp Projects\OWS340 HTML Help Nov2009ff\OWS340 Robo8\Help Files\!SSL!\Microsoft_HTML_Help\OWS340.chm
RoboHelp 8 is installed in:
C:\Program Files\Adobe\Adobe RoboHelp 8\RoboHTML
I ran the MJsDiag.exe utility and it reports that the dlls etc. are okay.
One other idea is to do a clean Robohelp 8 install on my laptop, get the problematic project and see if it compiles chm.
Thanks again.
I shortened the path further to:
C:\R8\o340\!SSL!\CHM_Layout3\OWS.chm
But I get the same messages in the compile output for CHM. (removed all the lists of topics and graphics)
Compiling C:\R8\o340\!SSL!\CHM_Layout3\!chm_tmp_folder_0\OWS.chm ...
Preparing to create HTMLHELP...
Clearing output folder...
Preparing files for HTML Help...
Copying files...
Updating files...
Finished preparing in 16 sec(s)
Initializing compiler...
Generating HTMLHELP (8.0.0.203)...
Updating topics...
Updating What_is_a_Schedule.htm...
C:\R8\o340\!SSL!\CHM_Layout3\!chm_tmp_folder_0\OWS.hhp
ehlpdhtm.js
Finished compiling HTMLHELP in 44 sec(s)
I can create a FlashHelp output and it works fine.
I have reading material for tonight at home and may get some more ideas.
Any other suggestions would be greatly appreciated.
Thanks.
I think it is pretty clear that the problem is with the project and putting a copy of RH on your laptop will pretty much confirm it, or not. ![]()
I would offer to take a look at the project but I think this one would take time that I don't have much of this week. You can send the project if you want but it will be a while before I can poke it about. See my contact page.
Not really any new info - just thought I'd do my good citizen bit and share today's experiences:
I had a compilation fail on me today, and got thrown by the Stop file error.
Having read some of the earlier posts here, I checked the stop file in the failed project against one that worked => exactly the same (ie therfore clearly not the cause then).
So I shifted the entire project to a folder on my desktop (therefore with a slightly shorter path name), => hey presto, sorted.
If one does plough through the compilation log, you do indeed see that stop file error even in successful compilations.
Regarding MM Acton's Robohelp 9/project in root folder situation, sorry Guv - Lord knows.
FYI I am using Robohelp HTML v8.
