Feb 13, 2009 3:23 AM
I'm running Flash Media Encoder, and have the profiles
loading from the command line in batch files - I'm using Scheduled
Tasks to start and stop encoding by batch file, eg. "start.bat"
looks like this:
"c:\Program Files\Adobe\Flash Media Encoder 2.5\FMEcmd.exe"
/p c:\profiles\myprofile.xml /l c:\my_log2.txt /r
etc.
I've been using the <reconnectinterval> setting in my
profiles to ensure that, if a connection to the server (I'm using
Wowza) drops, it will try to reconnect - and this works very well.
However, 1 time in 10 when the "start" batch file is run, it
won't connect - but I know that if it tried again, it would
probably connect fine. But the <reconnectinterval> setting
doesn't seem to be appropriate here, so I'm looking for an
equivalent that says - "if I connected, start encoding and end
batch file, if I didn't connect, run again and keep trying until
you can connect".
Someone suggesting starting and stopping the server, rather
than the encoders - but the server has to keep running all the
time, as it is being used for multiple streams that run at
different times - so it has to be the encoders that start and stop
at the correct times (it's for live TV).
This is something that needs to run unattended, hence using
scheduled tasks to start and stop the encoding.
Any ideas?
Cheers.
