quote:
Originally posted by: acropete
Hello rw34oc, Patrick, and Brooke,
Here's the latest:
According to rw34oc's crash log, there are two input manager on the machine, plaxo and cooliris. We don't support any input managers, and many have been known to crash AIR. The situation has been improved in the next AIR update, and is worth trying in this case, with the hope that this issue could be resolved.
The AIR update will be going live next week.
Can you all hang tight until next Wednesday, and try the new AIR version, and see if crash still occurs?
quote:
Originally posted by: patrickcheatham
Currently users report their languages are Russian, Italian, Polish and French.
Finally, you have to do the following ( under Mac OS Snow Leopard ):
-Uninstall ALL air applications.
-Uninstall AIR, using the Uninstaller App ( located in /Applications/Utilities )
AND
-Delete the following directory:
sudo rm -rf /Users/YOUR_USERNAME/Library/Application\ Support/Adobe/AIR/
And BINGO! after doing that, reinstall adobe air, and tweetdeck!!!
There you go, at least that worked for me, hopefully it works for you!
Hey I had this problem - I tried everything I could think of including most of the suggestions on this form. In the end I found all I had to do was delete (I didn't even have to re-install adobe-air! );
sudo rm -rf /Users/YOUR_USERNAME/Library/Application Support/SIMBL/Plugins/Afloat.bundle/
NOTE: The 'Afloat.bundle' was the problem in my case but from what I read on a different form, it can happen with many different programs. Be CAREFUL that you aren't actaully using the directory your about to delete. In my case the 'Afloat' was a program I had uninstalled already.
Here's where I found the answer originally -- http://forum.dofus.com/en/4-problems-solutions/98828-dofus-not-working -adobe-air-cannot-be-found
Hope that helps someone!
Hello All,
I had Adobe Air installed with three applications: Zinio, Mindomo & Prezi. Everything was working fine. I upgraded my Mac OS X leopard to Snow Leopard. Zinio asked to be upgraded to 4.0 and upon upgrading the app I was asked to upgrade to Adobe Air 2.5.1. After upgrades I receive the following error when I try to run any of the applications : "This application requires a version of Adobe AIR which cannot be found. Please download the latest version of the runtime from http://www.adobe.com/go/getair, or contact the application author for an updated version." followed by a crash, here is the crash report: http://www.box.net/shared/b003opfbmo
I have tried the above steps, including uninstalling the applications, adobe air, running the terminals commands and then installing all again. Can anyone help?
P.S. the same reproduces on another administrative account on the same machine.
