Feb 14, 2008 6:01 AM
Hi!
We are trying to compile a project with lcds-samples.war,
using LCDS 2.6 Beta 1, and it does not work. It generate this
errors:
The method addChannel(String) is undefined for the type
DataDestination lcds-samples/src/flex/samples/runtimeconfig
EmployeeRuntimeDataDestination.java
line 55
The method createDestination(DestinationSettings) in the type
DataService is not applicable for the arguments (String)
line 54
MessageService is not applicable for the arguments (String)
ChatRoomService.java
line 42
RemotingService is not applicable for the arguments (String)
EmployeeRuntimeRemotingDestination.java
line 18
The method createUUID(boolean) in the type UUIDUtils is not
applicable for the arguments () lcds-samples/src/flex/samples/feed
Feed.java
line 32
Feed.java
line 53
lcds-samples/src/flex/samples/marketdata
Feed.java
line 42
Feed.java
line 67
lcds-samples/src/flex/samples/pdfgen
PDFService.java
line 32
XDPXFAService.java
line 32
The method getFlexClient() is undefined for the type
FlexContext lcds-samples/src/flex/samples/qos
FlexClientConfigService.java line 15
FlexClientConfigService.java line 21
The method getService(String) is undefined for the type
MessageBroker lcds-samples/src/flex/samples/runtimeconfig
line 41
line 53
line 17
The method isStarted() is undefined for the type
MessageService lcds-samples/src/flex/samples/runtimeconfig
line 44
The method setDestination(DataDestination) is undefined for
the type JavaAdapter lcds-samples/src/flex/samples/runtimeconfig
line 78
The method setId(String) is undefined for the type
line 76
The method setMetadataSettings(MetadataSettings) is undefined
for the type DataDestination
line 61
The method setNetworkSettings(DataNetworkSettings) is
undefined for the type DataDestination
line 73
The method setScope(String) is undefined for the type
line 57
The method setSource(String) is undefined for the type
line 56
RemotingDestination lcds-samples/src/flex/samples/runtimeconfig
line 19
The method setSubscriptionTimeoutMinutes(int) is undefined
for the type DataNetworkSettings
line 64
The method start() is undefined for the type
MessageDestination lcds-samples/src/flex/samples/runtimeconfig
line 46
The type DatabaseCheckService must implement the inherited
abstract method Service.getSettings() lcds-samples/src/flex/samples
DatabaseCheckService.java line 9
The type EmployeeRuntimeDataDestination must implement the
inherited abstract method Service.getSettings()
line 44
The type EmployeeRuntimeRemotingDestination must implement
the inherited abstract method Service.getSettings()
line 8
Do you know something about it ? There is an updated version
of lcds-samples.war to LCDS 2.6 ?
