sql add blank row to result
Mar 17, 2009 6:05 PM
I currently use a temporary table to add a blank row to the top/beginning of my query results. I'm moving to MS SQL stored procedures and wanted to know if it's possible to add a blank row right into my SQL so I can eliminate the temporary table solution.
Any thoughts on this are appreciated!
cfwild
    Mar 17, 2009 7:23 PM   in reply to cfwild
    You could use a union to merge your blank row with your other results and order it so the blank sorts on top. But why do you need a blank row? It sounds like mixing user interface code with database code ..
    Mar 17, 2009 8:16 PM   in reply to cfwild
    You have to use SELECT with the string literal
    SELECT Category
    FROM Syndicated
    UNION
    SELECT '<HI>'
    ORDER BY Category
