I got it to work. That means Kel45 and I have been missing
some steps.
Here then are the steps I followed.
1) Save the following as the file
C:\Coldfusion8\sms_gw\smsListener.cfc
<cfcomponent>
<cffunction name="onIncomingMessage">
<cfargument name="cfEvent" required="yes"
type="struct">
<cfset var msg = arguments.cfEvent.data.message>
<cflog file="smsTestRecord" text="sms log message">
<!--- Use actual e-mail addresses --->
<cfmail to="email1@domain1" from="email2@domain2"
subject="SMS gateway test">
<cfoutput>#msg#</cfoutput>
</cfmail>
<cfreturn>
</cffunction>
</cfcomponent>
2) Save the following as the file
C:\Coldfusion8\sms_gw\config\smsConfig.cfg
# SMSGateway configuration file
# Test server config
# This is the IP address of SMSC
ip-address=127.0.0.1
# Port to bind to
port=7901
# Your system id
system-id=cf
# Your password
password=cf
# The source address for this client
source-ton=1
source-npi=1
# This is a made-up address
source-address=5551213
# The address range this smpp client will serve
# Generally the same as your source address
addr-ton=1
addr-npi=1
address-range=5551213
# Message sending rate; how many messages per second is the
# gateway allowed to send to your service provider.
# This can be a decimal (i.e. 0.1). 0 is unlimited.
# The default is 100 messages per second.
message-rate=100.0
# The mode of the gateway; Either synchronous or asynchronous
# In synchronous mode the gateway will wait for the response
# from the server when sending a message and the
SendGatewayMessage()
# CFML function will return the SMS messageID of the message
# or an empty string if their is an error. In asynchronous
mode,
# the gateway will not wait for a response and the SMS
messageID
# will NOT be returned from SendGatewayMessage().
# The default is synchronous.
mode=synchronous
# Should the gateway retry delivery on Network Errors?
# If a network error occurs while trying to deliver a
message,
# should the message be queued for delivery when the gateway
# is able to re-bind to the SMSC. This is useful if the
gateway
# is in asynchronous mode, where no error status is returned
from
# the CFML SendGatewayMessage() function.
# The default is no.
network-retry=no
# Should the gateway retry delievery on Transient Errors?
# If an error is returned from the SMSC that indicates
# the message may be able to be delivered in the future,
# should the gateway attemp to resend send the message?
# This is useful if the gateway is in asynchronous mode,
# where no error status is returned from the CFML
# SendGatewayMessage() function.
transient-retry=no
# Everything below here is usually OK.
# The function in the Gateway CFC which the is called
# when an incoming message arrives.
cfc-method=onIncomingMessage
# The default destination address info
destination-ton=1
destination-npi=1
# You can't have a default destination
# destination-address=
# The service type can be empty or one of
# the following values:
# CMT, CPT, VMN, VMA, WAP or USSD
# service-type=
# From the spec:
# Identifies the type of system requesting the bind.
# This may enable SMSC responses which are
# particular to a given type of ESME.
system-type=SMPP
# The receive timeout is a timeout for trying to receive a
message
# from the SMSC. If you want go to infinite wait until a PDU
# is received, set the receive-timeout to -1.
# The value is in seconds. The default is 30 seconds.
receive-timeout=10
# The ping interval is how often the SMS Gateway will send an
# EnquireLink PDU to the server to verify the health of the
connection.
# The value is in seconds. The default is 60 seconds.
ping-interval=60
# The number of connection attempts the gateway will make
until it gives up.
# Use -1 to retry until connected. The default is -1 (try
forever).
retries=-1
# Connection retry interval; how long to wait between
connection attemps.
# The value is in seconds. The default is 10 seconds.
retry-interval=10
3) On the Gateway Settings page in the Administrator, start
the SMS Test Server.
4) On the Gateway Instances page in the Administrator, add
the following new instance
Gateway ID: smsTest
Gateway Type: SMS - Handles SMS text messaging
CFC Path: C:\Coldfusion8\sms_gw\smsListener.cfc
Configuration File:
Startup Mode: Automatic
5) Start the SMS instance.
If necessary, press the Refresh button after a few seconds to
go from 'Starting' to 'Running'.
6) In C:\Coldfusion8\bin, double-click on SMSClient.bat to
start the client
7) Click on the Connect button
8) Enter the value 5551213 in the field 'Send SMS to:'
That is the value in the configuration file.
9) Enter some text (e.g. Eureka! It works!) in the message
field. Press Send.
10) Check the email account and Coldfusion log directory to
confirm it worked
