Primary monitor just died ...
Nov 1, 2008 12:06 PM
Hey all!
Well, it finally happened, my primary monitor bit the dust this morning. :( I've really become spoiled by the larger size (21") monitor and would like to replace it with a similar size. Problem is, as always for me, I need to keep the pricing as low as possible, while still getting something reasonable.
So, to that end, do you guys have any suggestions on low priced, decent monitors? Most are wide screen these days, aren't they?
thanks!
hopper
ps ...
I'm also going to have to get used to using a LCD screen, aren't I? The one that just died was a CRT.
    Nov 1, 2008 12:57 PM   in reply to greenjumpyone
    Probably ought to look into a Dell Ultra-Sharp if price is important, GH.
    Nov 1, 2008 3:13 PM   in reply to greenjumpyone
    Hopper, I honestly don't know. Just referring to some stuff that I've read on the PS forum.
    Nov 1, 2008 7:30 PM   in reply to greenjumpyone
    whatever monitor you chose, make sure you don't HAVE TO pay $100 for the cable : )
    (Dell is fine, I have a 22", I think : )
    this looks nice (I don't have one):
    http://www.circuitcity.com/ccd/productDetail.do?oid=211914#CustomerRat ings
    this looks expensive for no apparent reason:
    http://www.circuitcity.com/ssm/Belkin-10-DVI-D-Dual-Link-Cable/sem/rps m/oid/213360/rpem/ccd/productDetail.do?cc_fm=Accessories+Mod
    Nov 1, 2008 8:56 PM   in reply to greenjumpyone
    The Belkin is a rip off at Circuit city. Here is Belkin's direct price:
    http://catalog.belkin.com/IWCatProductPage.process?Product_Id=105267
    Nov 2, 2008 1:29 AM   in reply to greenjumpyone
    What's with buying cables?
    My Dell monitor came with its own DVI cable. So did my primary Eizo.
    Nov 2, 2008 4:28 AM   in reply to greenjumpyone
    Every monitor I've purchased has come with a cable.
    Edit: I should have said that both flat screens have come with a DVI cable.
    Nov 2, 2008 6:52 AM   in reply to greenjumpyone
    I use the 24" Dell ultrasharp for my main monitor. It's been great so far and I've had it for almost 2 years now. If you buy one, get the extended 5 year warranty. It's cheap.
    What ever you do, DO NOT BUY ANYTHING FROM VIEWSONIC!
    Nov 2, 2008 9:04 AM   in reply to greenjumpyone
    you may have to check the video card too, for connectivity and wide gamut
    Nov 2, 2008 9:54 AM   in reply to greenjumpyone
    The cable is important, as the bandwidth requirements for proper resolution are much greater than VGA. With cheap cables you will see, for instance, in an Excel spreadsheet, ghosting of the narrow lines and smearing of the edges of the type. This because of timing errors between the color information and the luminance signal causes skewing.
    The quality of the electronics to which the cable connects is vitally important as well.
    The upshot of all this is you may see artifacts and resolution problems that are not due to the image, but due to the connectivity. Therefore, trying to sharpen with little improvement may in fact be a systemic problem. (Based on the 1920/1080 screen resolution)
    Don't go beyond 10'in length. The signal losses mount quickly. 10' is the ideal length.
    This is compliments of a friend who is chief engineer for a company that makes the display setups for the likes of Circuit City etc who have to have clean, properly setup connections to each and every monitor or TV. When they go beyond 10' per set, differences are introduced which compromise the comparison test. The cables they use are first class.
    So, if you are going to spend hundreds of dollars for the monitor, go ahead and spend the extra bucks for the high end Belkin.
    Nov 3, 2008 12:54 AM   in reply to greenjumpyone
    Ten Inches??????????????????
    While cable length can cause losses and signal distortion, I hardly think that that sort of restriction makes sense in the real world.
    Personally I think cable companies make far too much of the need for their expensive products. The proof of the pudding, or in this case, the picture, is in the user's experience not what somebody measured in a lab.
    I would say, try the monitor with the cable it came with and only if you are not satisfied with what you see, get a more expensive cable.
    I always have to laugh a those HiFi enthusiasts with their $10 000 valve amplifiers and half-inch diameter speaker cables. As if ...
  • Ramón G Castañeda
    Jul 27, 2006
    Nov 3, 2008 1:02 AM   in reply to greenjumpyone
    C'mon, JJ
    Don't go beyond 10' in length = Don't go beyond 10 feet in length
    Nov 3, 2008 2:36 AM   in reply to greenjumpyone
    Yes, dammit! Should have realised ten inches is ridiculously short. I can't get my head round these old-fashioned units. ;)
    I still stand by the rest of the remarks though.
    Nov 3, 2008 3:18 AM   in reply to greenjumpyone
    you can't get your head round ********
    (and grab at any opportunity you don't understand)
    Nov 3, 2008 3:41 AM   in reply to greenjumpyone
    Trust you to devalue a serious discussion.
    Don't bother to reply.
    Nov 3, 2008 3:53 AM   in reply to greenjumpyone
    Ramón G Castañeda's advise was sound technical advice. Don't go beyond the 10 foot. That rule also applies to lines to your router.
    Nov 3, 2008 4:01 AM   in reply to greenjumpyone
    don't bother to reply? : )
    you're funnier than I thought you could be
    (not a compliment)
    don't bother reading your own posts
    but remember that I understand a lot more than you do
    Nov 3, 2008 4:33 AM   in reply to greenjumpyone
    Ana, the advice was Larry's
    (Ramón only demonstrated attention to detail and quality, this time "round" : )
    [unlike arrogant/negative/pompous/useless/angry/totalitarian/boring jj]
    Nov 3, 2008 7:33 AM   in reply to greenjumpyone
    Unfortunately, the audio debacle spilled over to the digital world.
    JJ, here's the story technically.
    At the frequencies necessary for proper digital communication, we resort to transmission line theory, which, for audio made no sense at all given the cable lengths.
    Transmission lines require termination in a load which matches the characteristic impedance of the line, typically in the order of 50 ohms unbalanced and up to 100 ohms balanced. If you think that 10 feet is inconsequential, consider that the Intel Core Two Duos have what is called a Front Side Bus, which is on the order of a few inches, and is rigorously controlled, as to line impedance and termination. It is directly involved in the marvelous performance of those devices, matching and exceeding that with which AMD competes, and AMD doesn't have a front side bus! If the FSB was not controlled we would all be either running AMD or running behind.
    Think of it this way. The pulse which corresponds to, say a "one" is like a golf ball, a steady stream of golf balls heading for a target. Now, if the target is somewhat soft and thin, the ball gets through and lands on the space waiting for the signal "One" or "Zero". Now, consider a target is hard. The ball hits the target, bounces back and Uh oh!, it's heading back to the source. But wait! There is more! Another ball is heading to the target, it gets hit by the returning ball, and in this case, is a zero ball. The two cancel, and a pixel location gets the wrong info.
    I have worked with transmission lines for years, both RF and digital. At Intel, I was responsible for measurements involving FSB performance on CPU to MCH (Northbridge) connections.
    Since I have no recent experience with the practical notions of DVI cabling, I went to my source, who detailed it for me, far more than I have written here.
    Anyway, take it for what it's worth. You can do as JJ suggests and try before you buy. And buy from a dealer that allows returns, should you decide for you, it makes no difference.
    One more thing: The electronics has to terminate the cable correctly. If it doesn't, no amount of cable upgrade will improve performance!
    You get what you pay for.
    Nov 3, 2008 7:34 AM   in reply to greenjumpyone
    he wouldn't understand
    Nov 3, 2008 7:40 AM   in reply to greenjumpyone
    Hopper, set the screen resolution to max. The monitor should set itself properly.
    Use the cards recommended as tested by Adobe.
    Nov 3, 2008 7:42 AM   in reply to greenjumpyone
    Well, that's not my problem, Todie. The info is there to substantiate the claims and the rest is up to the reader. :-)
    Nov 3, 2008 7:43 AM   in reply to greenjumpyone
    Oh, and Hopper, if you use the VGA connections, which are slower, there is less pressure on cables and terminations, but the display will not be as crisp either.
    Dec 27, 2008 12:44 PM   in reply to greenjumpyone
    i'll trade you my 21" CRT for an LCD :p
