Agreed. After careful testing, I find the D90 to run a I would expect from the DXO site data. I still have to check out the dynamic range capabilities. However, I noticed immediately that my defaults for the Shadow/Highlight tool are too aggressive for this body, and in many cases where it is called for with the D80, none is necessary with the D90. What I do want to accomplish is a check on the dynamic range change with ISO changes.
I also added two lenses, one prime, Nikon 50mm f 1.8 another a shorter zoom range Tamron 28 to 75mm f2.8, which I chose because of the results indicated in SLRGear. My objective here is excellent sharpness, CA, vignetting and distortion figures over the focal length range. The downside of the Tamron seems to be that the combination here tends to go on a hunting expedition when auto focusing. I set up a test, and at f8, I could not see any sharpness differences, but at f2.8 I could. I tried different lenses at the store, they all do it.
For critical work, I can see to focus with the F90, but it is a drag. OTOH, setting the focal point with respect to desired DOF has always been the job of the photographer, and depending on autofocus to do that has been a negative for me, no matter the camera's capability. Why I can't have a screen like a split image is beyond me. The manual focus indicator does help, though.
From a qualitative pov, I am finding less need to go the stitched route to excellence in images, but at the same time, the stitched images are smoother due to the low values in distortion and a more consistent exposure from frame to frame when shooting.
I still expect to do the stitched version for the big landscapes, but everything else seems just fine as a single shot.
I probably will add a macro sometime down the line, perhaps the Nikon 85mm prime.I am less sure here because i don't do macros, so I don't know where to land so far as the basic F/L is concerned. The longer versions seem the better route as one can be physically further from the object, but DOF is to be considered as well. So, any suggestions here?
The cinematography capabilities are the most novel part of the D90, and boy, am I bad at that! :D
