You can change the document size! There is no need to create a new Illustrator file - this is false.
All you have to do is go to your tools > double click on the artboard icon > enter in the new size you want. You can also manually change the size by clicking on the "anchors".
By the way the artboard icon is just above the slice tool on the tool bar.
From the UI, yes you can make these changes but this is a scripting forum and from a script you cannot change a document's size.
What about scripting a copy from the existing file and paste into a new document (created from a .ait of the correct size)? If your files are single layers, it shouldn't be too unmanageable to script.
Hello Al Se!
Any ideas how to do this?
Resizing the artborard(s) was added to the DOM in CS4 when you got multi-artboards… What version are you using as this is an old thread…?
Thanks for your answer.
I use CS3.
Thank you, Dawnsun! I am constantly needing to resize artwork and your tip was so helpful!!
Dawsun's answer is the right one! (Thanks, Dawsun )
follow this tutorial, Video : How to change adobe illustrator artboard size (resize) - YouTube
or use this script
This absolutely does NOT work, Adobe Illustrator no longer allows me to tell it what size I want my artboard to be. I have uninstalled and reinstalled 6 times today. IT WILL NOT let me type to change the artboard size. I have to create a brand new adobe illustrator file setup to the size I want. Adobe ignores these typed inputs in an already existing document
You are answering a thread about Illustrator CS2 covering scripting. Those versions were quite different than today's versions.
Unless your question is about scripting an equally old version, please create a new thread and describe your issues.
