Home/Support/
Forums
10 Replies Last post: Mar 13, 2008 8:23 AM by MarkWalsh
User 8 posts since
Feb 14, 2005
Feb 12, 2008 5:33 PM
PS3 script to batch rename layers
Sometimes, I make copies of layers (for example: copy little diamonds to align into a shape of the letter M). Each time I "alt+drag" the content in that layer (to make a copy of it), PS makes a copy and then appends the name of the layer to something like "diamond copy 3". After making a ton of copies (and because I'm anal about having actual names for each layer), I want each layer to read "diamond". Instead of manually renaming all these layers, is there a way to highlight the affected layers and choose to rename all layers according to what you want?
MarkWalsh User 319 posts since
Feb 28, 2008
1. Feb 28, 2008 9:14 AM in response to: (Shandy_Elliott)
Re: PS3 script to batch rename layers
You're in luck. I just finished writing this yesterday. :)
This will remove " copy", " copy 1"... etc from all open files. Let me know how it works out for you.
// Script Name: RenameLayers.jsx
// Version: 1.0
// Date: 2/27/08
// Usage: Removes 'copy 1, copy 2, etc' from name of all layers
#target photoshop
//$.localize = true;
var displayDialogMode = app.displayDialogs;
app.bringToFront();
app.bringToFront();
app.displayDialogs = DialogModes.NO;
processObjects(app.documents, processDocument,function () {alert("You have no documents open")})
app.displayDialogs = displayDialogMode;
// Function: processObjects
// Usage: Runs theMainFunction on every object in list theObjects
// Input: List of objects (documents, layers, etc.), Function to run on each object, Function to run on parent if there are no object
// Return: value returned from function used
function processObjects(theObjects, theMainFunction, theAlternateFunction) {
var returnValue = null;
if (theObjects.length ==0) {
if (!(theAlternateFunction == undefined) && !(theAlternateFunction == null) && !(theAlternateFunction == "")) {
returnValue = theAlternateFunction (theObjects.parent);
} else {
if (!(theMainFunction == undefined) && !(theMainFunction == null) && !(theMainFunction == "")) {
for (var i = theObjects.length -1; i> -1; i--) {
returnValue += theMainFunction (theObjects[i], i);
return returnValue;
// Function: processDocument
// Usage: Processes layers of document with 'processLayer' function
// Input: Document object, Document object index
// Return: none
function processDocument(objectRef, i) {
app.activeDocument = objectRef
processObjects(objectRef.layers, processLayer, null);
// Function: processLayer
// Usage: Removes 'copy' from layer name (processes Layer Set contents)
// Input: Layer object, Layer Object index
// Return: none
function processLayer(objectRef, i) {
if (objectRef.typename == 'LayerSet') {
var layerCount = processObjects(objectRef.layers, processLayer);
renameLayer(objectRef)
return 0
// Function: renameLayer
// Return: none
function renameLayer(objectRef) {
var theRegEx = new RegExp(/^(.*)(copy(\s(\d)+)*)+$/)
if (theRegEx.test(objectRef.name)) {
var indexNumber = 0
indexnumber = objectRef.name.indexOf(" copy")
objectRef.name = objectRef.name.substr(0,indexnumber)
return 0
Feb 28, 2008
3. Feb 29, 2008 6:39 AM in response to: (Shandy_Elliott)
Paste into a text program (notepad on PC, TextEdit on mac) and save into the 'Scripts' directory in the 'Presets' directory of your Photoshop application folder with a '.js' or '.jsx' extension (e.g. "RenameLayers.jsx").
To activate, select "Scripts" from the"File" menu and select the saved script.
GagnonEric User 101 posts since
Jun 18, 2007
5. Mar 12, 2008 2:38 PM in response to: (Shandy_Elliott)
Hi!
I will surely have a look at the script... Does it handle well hierarchical nested layers?
In my current project, i have some documents that are very heavy (by exemple more than 1000 layers!).
The automated renaming of around 300 layers in particular document is a process that take as much as 7 hours! (Applescript on a 1.8 G5 computer/4go ram).
It's not fully clear to me if it's the logic of the script/the scripting api speed or the heavy use of PSD document that is at fault..
If only i had more time for pluggin developpement! :)
Eric
Feb 28, 2008
6. Mar 12, 2008 3:11 PM in response to: (Shandy_Elliott)
Yes, it will handle all layers in every layer set. (in every opened file)
If you have a lot of layers, it could take a while as it opens each layer set and scrolls through every layer. On the files I've used it on, it runs pretty speedy. I think it will also run much faster than an applescript.
Jun 18, 2007
7. Mar 12, 2008 3:33 PM in response to: (Shandy_Elliott)
I have tested it.. it works like advertised (including layers in groups).
The script is fast on small sample but get quite slow on heavy documents ... so maybe my problem is more related to document size and maybe not worth investigating other scripting alternatives (but i'm pretty sure that on the same set your script would be faster).
The only bug i have found is that the script dont keep track of the visibility of layers. If a layer is invisible (when you do the renaming), the layer should be invisible when you are done with the processing.
That "problem" is also visible in a normal user interaction through the interface (select a layer make the layer visible). It's questionable in the user interface and a real problem with automation even if you record and set back the property. It must be clear to the users that if a script is crashing that document need to be reloaded!
Feb 28, 2008
8. Mar 13, 2008 5:48 AM in response to: (Shandy_Elliott)
It looks like changing the name of the layer makes it visible (unless it is the selected layer). I'll see if I can find the time to edit the script to activate each layer before it renames it. This should solve that problem. I'd also like it to restore the state of the layer sets that it opens to select each layer, and if I have it select each layer before renaming, then it should also end with the originally selected layer selected.
Jun 18, 2007
9. Mar 13, 2008 8:23 AM in response to: (Shandy_Elliott)
I must say that in my scripts, i had quite a few problems to get around while working with layers! (and not all where solved!)
Feb 28, 2008
10. Mar 13, 2008 8:23 AM in response to: (Shandy_Elliott)
I made a quick rewrite to the renameLayer function. This should fix the problem with invisible layers. I ran the script on a large document just now, and it did take a while (although MUCH faster than would be manually, plus more accurate). It switches to the layer to rename it, and switches back to the original selected layer afterwards. I will rewrite it later to switch to the layer before renaming (hopefully that should solve that slowdown).
var theRegEx = new RegExp(/(\s*copy\s*\d*)+$/)
// save state of layer (visible or invisible)
var layerVisible = objectRef.visible
var indexNumber = 0
objectRef.visible = layerVisible
return 0
