NetConnection.Call.BadVersion amfsecure timeout??
Apr 1, 2008 12:26 AM
Hi.<br /><br />We are using a secure channel like this:<br /><br />    <channels><br />        <channel-definition id="my-secure-amf" class="mx.messaging.channels.SecureAMFChannel"><br />            <endpoint url="https://{server.name}:{server.port}/{context.root}/messagebroker /amfsecure" class="flex.messaging.endpoints.SecureAMFEndpoint"/><br />            <properties><br />                <add-no-cache-headers>false</add-no-cache-headers><br />            </properties><br />        </channel-definition><br />    </channels><br /><br />And we expose a remote service like this:<br /><br /><?xml version="1.0" encoding="UTF-8"?><br /><service id="remoting-service" class="flex.messaging.services.RemotingService"><br />    <adapters><br />        <adapter-definition id="java-object" class="flex.messaging.services.remoting.adapters.JavaAdapter" default="true"/><br />    </adapters><br />     <br />    <default-channels><br />        <channel ref="my-secure-amf"/><br />    </default-channels><br /><br />    <destination id="WebFlow"><br />        <properties><br />            <source>xxxxxxxxxxx.flex.FlexAdapter</source><br />        </properties><br />    </destination><br /></service><br /><br />Then, we create a RemoteObject like this:<br /><br />flowController = new RemoteObject("WebFlow");<br /><br />var channelSet: ChannelSet = new ChannelSet();<br />var channel: Channel = new AMFChannel("my-secure-amf", "https://localhost:443/example/messagebroker/amfsecure");<br />               <br />channelSet.addChannel(channel);<br />flowController.channelSet = channelSet;<br /><br />flowController.showBusyCursor = true;<br /><br />flowController.launch.addEventListener('result', onLaunch);<br /><br />It works well, but if we wait one minute (idle), when we try to invoke the method launch again it appears the following error:<br /><br />[RPC Fault faultString="Send failed" faultCode="Client.Error.MessageSend" faultDetail="Channel.Connect.Failed error NetConnection.Call.BadVersion: : url: 'http://localhost:443/example/messagebroker/amfsecure'"]<br />     at mx.rpc::AbstractInvoker/http://www.adobe.com/2006/flex/mx/internal::f aultHandler()[E:\dev\3.0.x\frameworks\projects\rpc\src\mx\rpc\Abstract Invoker.as:216]<br />     at mx.rpc::Responder/fault()[E:\dev\3.0.x\frameworks\projects\rpc\src\mx \rpc\Responder.as:49]<br />     at mx.rpc::AsyncRequest/fault()[E:\dev\3.0.x\frameworks\projects\rpc\src \mx\rpc\AsyncRequest.as:103]<br />     at mx.messaging::ChannelSet/faultPendingSends()[E:\dev\3.0.x\frameworks\ projects\rpc\src\mx\messaging\ChannelSet.as:1399]<br />     at mx.messaging::ChannelSet/channelFaultHandler()[E:\dev\3.0.x\framework s\projects\rpc\src\mx\messaging\ChannelSet.as:935]<br />     at flash.events::EventDispatcher/dispatchEventFunction()<br />     at flash.events::EventDispatcher/dispatchEvent()<br />     at mx.messaging::Channel/connectFailed()[E:\dev\3.0.x\frameworks\project s\rpc\src\mx\messaging\Channel.as:997]<br />     at mx.messaging.channels::PollingChannel/connectFailed()[E:\dev\3.0.x\fr ameworks\projects\rpc\src\mx\messaging\channels\PollingChannel.as:354] <br />     at mx.messaging.channels::AMFChannel/statusHandler()[E:\dev\3.0.x\framew orks\projects\rpc\src\mx\messaging\channels\AMFChannel.as:369]<br /><br />Is there any one minute idle timeout?<br /><br />We have tried:<br /><br />     <flex-client><br />          <timeout-minutes>0</timeout-minutes><br />     </flex-client><br /><br />But it doesn't fix the problem.<br /><br />Any help would be appreciated.<br /><br />Thanks a lot.
    Apr 1, 2008 4:33 AM   in reply to (paco)
    <DIV dir=ltr align=left><SPAN class=437043212-01042008><FONT face=Arial <br />color=#0000ff size=2>Hi Paco, </FONT></SPAN></DIV><br /><DIV dir=ltr align=left><SPAN class=437043212-01042008><FONT face=Arial <br />color=#0000ff size=2></FONT></SPAN> </DIV><br /><DIV dir=ltr align=left><SPAN class=437043212-01042008><FONT face=Arial <br />color=#0000ff size=2>In the error message, it says </FONT></SPAN></DIV><br /><DIV dir=ltr align=left><SPAN class=437043212-01042008><FONT face=Arial <br />color=#0000ff size=2></FONT></SPAN> </DIV><br /><DIV dir=ltr align=left><SPAN class=437043212-01042008><FONT face=Arial <br />color=#0000ff size=2><FONT face="Times New Roman" color=#000000 size=3>[RPC <br />Fault faultString="Send failed" faultCode="Client.Error.MessageSend" <br />faultDetail="Channel.Connect.Failed error NetConnection.Call.BadVersion: : url: <br />'http://localhost:443/example/messagebroker/amfsecure'"] <br /></FONT><BR></FONT></SPAN></DIV><br /><DIV dir=ltr align=left><SPAN class=437043212-01042008><FONT face=Arial <br />color=#0000ff size=2>You are connecting to http destination instead of <br />https.   Could this be a configuration error?</FONT></SPAN></DIV><br /><DIV dir=ltr align=left><SPAN class=437043212-01042008><FONT face=Arial <br />color=#0000ff size=2></FONT></SPAN> </DIV><br /><DIV dir=ltr align=left><SPAN class=437043212-01042008><FONT face=Arial <br />color=#0000ff size=2>-John</DIV></FONT></SPAN><BR><br /><DIV class=OutlookMessageHeader lang=en-us dir=ltr align=left><br /><HR tabIndex=-1><br /><FONT face=Tahoma size=2><B>From:</B> paco [mailto:member@adobeforums.com] <br /><BR><B>Sent:</B> Tuesday, April 01, 2008 4:27 AM<BR><B>To:</B> <br />blazeds-general@adobeforums.com<BR><B>Subject:</B> NetConnection.Call.BadVersion <br />amfsecure timeout??<BR></FONT><BR></DIV><br /><DIV></DIV>A new discussion was started by paco in <BR><BR><B>General <br />Discussion</B> --<BR>  NetConnection.Call.BadVersion amfsecure <br />timeout??<BR><BR>Hi. <BR><BR>We are using a secure channel like this: <br /><BR><BR>&lt;channels&gt; <br /><BR>        &lt;channel-definition <br />id="my-secure-amf" class="mx.messaging.channels.SecureAMFChannel"&gt; <br /><BR>            &lt;endpoint <br />url="https://{server.name}:{server.port}/{context.root}/messagebrok er/amfsecure" <br />class="flex.messaging.endpoints.SecureAMFEndpoint"/&gt; <br /><BR>            &lt;properties&gt; <br /><BR>                &lt;add-no-cache-headers&gt;false&lt;/add-no-ca che-headers&gt; <br /><BR>            &lt;/properties&gt; <br /><BR>        &lt;/channel-definition&gt; <br /><BR>    &lt;/channels&gt; <BR><BR>And we expose a remote <br />service like this: <BR><BR>&lt;?xml version="1.0" encoding="UTF-8"?&gt; <br /><BR>&lt;service id="remoting-service" <br />class="flex.messaging.services.RemotingService"&gt; <br /><BR>    &lt;adapters&gt; <br /><BR>        &lt;adapter-definition <br />id="java-object" class="flex.messaging.services.remoting.adapters.JavaAdapter" <br />default="true"/&gt; <BR>    &lt;/adapters&gt; <br /><BR><BR>&lt;default-channels&gt; <br /><BR>        &lt;channel <br />ref="my-secure-amf"/&gt; <BR>    &lt;/default-channels&gt; <br /><BR><BR>&lt;destination id="WebFlow"&gt; <br /><BR>        &lt;properties&gt; <br /><BR>            &lt;source&gt;xxxxxxxxxxx.flex.FlexAdapter&lt;/sour ce&gt; <br /><BR>        &lt;/properties&gt; <br /><BR>    &lt;/destination&gt; <BR>&lt;/service&gt; <br /><BR><BR>Then, we create a RemoteObject like this: <BR><BR>flowController = new <br />RemoteObject("WebFlow"); <BR><BR>var channelSet: ChannelSet = new ChannelSet(); <br /><BR>var channel: Channel = new AMFChannel("my-secure-amf", <br />"https://localhost:443/example/messagebroker/amfsecure"); <br /><BR><BR>channelSet.addChannel(channel); <BR>flowController.channelSet = <br />channelSet; <BR><BR>flowController.showBusyCursor = true; <br /><BR><BR>flowController.launch.addEventListener('result', onLaunch); <BR><BR>It <br />works well, but if we wait one minute (idle), when we try to invoke the method <br />launch again it appears the following error: <BR><BR>[RPC Fault <br />faultString="Send failed" faultCode="Client.Error.MessageSend" <br />faultDetail="Channel.Connect.Failed error NetConnection.Call.BadVersion: : url: <br />'http://localhost:443/example/messagebroker/amfsecure'"] <BR>at <br />mx.rpc::AbstractInvoker/http://www.adobe.com/2006/flex/mx/internal: :faultHandler()[E:\dev\3.0.x\frameworks\projects\rpc\src\mx\rpc\Abstra ctInvoker.as:216] <br /><BR>at <br />mx.rpc::Responder/fault()[E:\dev\3.0.x\frameworks\projects\rpc\src\ mx\rpc\Responder.as:49] <br /><BR>at <br />mx.rpc::AsyncRequest/fault()[E:\dev\3.0.x\frameworks\projects\rpc\s rc\mx\rpc\AsyncRequest.as:103] <br /><BR>at <br />mx.messaging::ChannelSet/faultPendingSends()[E:\dev\3.0.x\framework s\projects\rpc\src\mx\messaging\ChannelSet.as:1399] <br /><BR>at <br />mx.messaging::ChannelSet/channelFaultHandler()[E:\dev\3.0.x\framewo rks\projects\rpc\src\mx\messaging\ChannelSet.as:935] <br /><BR>at flash.events::EventDispatcher/dispatchEventFunction() <BR>at <br />flash.events::EventDispatcher/dispatchEvent() <BR>at <br />mx.messaging::Channel/connectFailed()[E:\dev\3.0.x\frameworks\proje cts\rpc\src\mx\messaging\Channel.as:997] <br /><BR>at <br />mx.messaging.channels::PollingChannel/connectFailed()[E:\dev\3.0.x\ frameworks\projects\rpc\src\mx\messaging\channels\PollingChannel.as:35 4] <br /><BR>at <br />mx.messaging.channels::AMFChannel/statusHandler()[E:\dev\3.0.x\fram eworks\projects\rpc\src\mx\messaging\channels\AMFChannel.as:369] <br /><BR><BR>Is there any one minute idle timeout? <BR><BR>We have tried: <br /><BR><BR>&lt;flex-client&gt; <BR>&lt;timeout-minutes&gt;0&lt;/timeout-minutes&gt; <br /><BR>&lt;/flex-client&gt; <BR><BR>But it doesn't fix the problem. <BR><BR>Any <br />help would be appreciated. <BR><BR>Thanks a lot. <BR><BR><br /><HR align=left width=200><br />View/reply at <A <br />href="http://www.adobeforums.com/webx?13@@.59b4dc44">NetConnection. Call.BadVersion <br />amfsecure timeout??</A><BR>Replies by email are OK.<BR>Use the <A <br />href="http://www.adobeforums.com/webx?280@@.59b4dc44!folder=.3c061a 83">unsubscribe</A> <br />form to cancel your email subscription.<BR><BR>
    Apr 1, 2008 5:35 AM   in reply to (paco)
    If you're using the secure channel, you'll need
    new SecureAMFChannel instead of new AMFChannel in your Flex client.
    new AMFChannel("my-secure-amf" ... ->
    new SecureAMFChannel("my-secure-amf" ...
    Feb 19, 2009 11:58 AM   in reply to (paco)
    Paco
    Just curios did changing to SecureAMFChannel solve your 1 minute timeout problem?
    Neil
    Feb 27, 2012 10:03 PM   in reply to (paco)
    Why are the html tags not being parsed in this thread...?
