Got the same emf error.
I'm a bit confused since this is a Flex Builder Plugin. FlexBuilder is built on Eclipse, but it deosn't have all the
features ( some Flex/as3 developers might not need all Java/other related plugins) and that's ok I guess.
I'm also guessing that if I try to install the Cairngorm plugin straight into eclipse, not Flex Builder, that would work
because it has the right plugins.
I tried installing the necesary plugins but I got into a vicious circle.
I am trying to install emf from here:
http://download.eclipse.org/modeling/emf/updates/releases/
via Help > Software Updates > Find and Install
but I get an error that some JET plugin is missing.
I'm trying to install JET ( with the whole stuff that comes with it ) from here:
http://download.eclipse.org/modeling/m2t/updates/releases/
But I can't because Jet is saying it won't install without emf and emf says it can't without jet.
Anyone gone past that ?
Has Adobe tried to actually install the Cairngorm Plugin into a clean FlexBuilder release?
I'm using Flex Builder 3 Version: 3.0.214193
It was hard to find, but here is the solution to install the Cairngorm Plugin into Flex Builder (the standalone version).
I think it would be very helpfull to add these instructions in the Plugin page, because I was close to give up...
Summary:
- When choosing location, check the adobe one AND the Europa Discovery Site
- When you select the Cairngorm plugin, the error message will appear
- Select the Europa Dicovery site, and click on the "Select required" button
- The required items will be selected and the error will disappear
And, Voila... The installation should be successfull...
