(Dina_So)
Run several test suites in sequence
Jan 22, 2009 5:53 PM
I have several test suites. I would like to run each of them in sequence because each has its own configuration. If I did the following, tests from different suites will be mixed with others while running.
testRunner.test = new Suite1();
testRunner.startTest();
testRunner.test = new Suite2();
Anyone has ideas how to solve this?
Dina
    Jan 31, 2009 6:03 PM   in reply to (Dina_So)
    A couple of suggestions. Dynamically create a new testRunner for each<br />TestSuite, that way you can run them in sequence. Each test runner<br />could be thrown into a tab navigator to easily view the results. The<br />TestRunnerBase fires a TestsCompleteEvent which could be used to<br />execute the next suite. The reporting of total tests across all suites<br />could be done with a custom TestListener.<br /><br />-- Daniel R. <danielr@neophi.com> [http://danielr.neophi.com/]<br /><br />> I have several test suites. I would like to run each of them in sequence<br />> because each has its own configuration. If I did the following, tests from<br />> different suites will be mixed with others while running.<br />><br />> testRunner.test = new Suite1();<br />>  testRunner.startTest();<br />>  testRunner.test = new Suite2();<br />>  testRunner.startTest();<br />>  testRunner.test = new Suite2();<br />>  testRunner.startTest();
    Feb 2, 2009 2:17 AM   in reply to (Dina_So)
    Hi,<br /><br />Surely the ability to add test suites to test suites (the composite pattern) already allows this?<br /><br />Cheers,<br /><br />Ali<br /><br /><br />On 01/02/2009 02:03, "Daniel Rinehart" <member@adobeforums.com> wrote:<br /><br />A new message was posted by Daniel Rinehart in<br /><br />FlexUnit Development --<br />  Run several test suites in sequence<br /><br />A couple of suggestions. Dynamically create a new testRunner for each<br />TestSuite, that way you can run them in sequence. Each test runner<br />could be thrown into a tab navigator to easily view the results. The<br />TestRunnerBase fires a TestsCompleteEvent which could be used to<br />execute the next suite. The reporting of total tests across all suites<br />could be done with a custom TestListener.<br /><br />-- Daniel R. <danielr@neophi.com> [http://danielr.neophi.com/]<br /><br />> I have several test suites. I would like to run each of them in sequence<br />> because each has its own configuration. If I did the following, tests from<br />> different suites will be mixed with others while running.<br />><br />> testRunner.test = new Suite1();<br />>  testRunner.startTest();<br />>  testRunner.test = new Suite2();<br />>  testRunner.startTest();<br />>  testRunner.test = new Suite2();<br />>  testRunner.startTest();<br /><br /><br />------------------------------------------------------<br />View/reply at <a href=http://www.adobeforums.com/webx?13@@.59b799c6/0><br />Replies by email are OK.<br />Use the unsubscribe form at <a href=http://www.adobeforums.com/webx?280@@.59b799c6!folder=.59b62b92> to cancel your email subscription.
    Feb 4, 2009 7:47 AM   in reply to (Dina_So)
    Can someone post some code that allows this to work? I'm new to AS and don't think I can tackle a custom TestListener, etc. One would think this would already be supported behavior.
    -Dave
