Problems with Vista 64 bit edition
Jan 8, 2007 9:51 AM
When will this be fixed for 64 bit OS, I want to upgrade to version 8, but there is no point at this time. No version works on Vista.
Error "Warning 20225..." or no Adobe PDF printer appears (Acrobat 8.0 on Windows)
Issue
When you install Adobe Acrobat, one of the following issues occurs:
-- The Acrobat installer returns the error message, "Warning 20225: Adobe Acrobat 8 Setup was unable to create a new item: Adobe PDF Converter. The Adobe PDF Printer may be unavailable. GetLastError: The specified module could not be found." When you click OK, the installer returns the error again and completes the installation, but the Adobe PDF printer doesn't appear in Printers And Faxes in the Windows Control Panel.
-- The Adobe PDF printer doesn't appear in Printers And Faxes in the Windows Control Panel.
Solutions
Solution 1: Use a supported installation.
The following are unsupported installations, and the supported solutions:
-- If you install Acrobat (Professional or Standard) on a 64-bit operating system, then you may see this error. Install Acrobat on a 32-bit operating system.
Replies 1 2 Previous Next
    Jan 11, 2007 3:15 AM   in reply to (Dean_Salman)
    No version of Acrobat currently available will install the PDF printer
    on a 64-bit version of Windows (XP or Vista). Adobe have made no
    announcements about availability of a version that will.
    Without this, most other conversion components can't work either.
    Aandi Inston
    Mar 20, 2007 1:41 PM   in reply to (Dean_Salman)
    I just got a brand new HP Pavillion with Vista Home Premium OS on it. I also purchased recently a copy of Adobe Acrobat Pro 8 Upgrade from version 5+. Is there a way I can install this under vista. I have legal copies of Acrobat Pro for versions 5.6.and 7.
    I seem to remember that you have to have a earlier versionn installed on your computer. A problem with Vista I think.
    I know some newer versions of Microsoft Software will install if you have the CD of the olderversion and place it in your CD drive.
    ie. Windows 98 to XP
    Mar 30, 2007 6:19 AM   in reply to (Dean_Salman)
    the adobe people should do something as soonest. the professional versions become useless when the converter or pdf-maker are not available, or not?
    Mar 30, 2007 8:23 AM   in reply to (Dean_Salman)
    fuerer,
    You can download the free Public Preview of the Acrobat 8.0 3D application from the following URL:
    http://labs.adobe.com/technologies/acrobat3d_version8/
    It supports Vista 32 and 64 bit systems.
    Please note that this is a Public Preview of the forthcoming Acrobat 8.0 3D application and therefore has an expiration date.
    May 22, 2007 6:14 AM   in reply to (Dean_Salman)
    Too bad Adobe!!!
    I have used Adobes suite since Aldus PageMaker. I have always been satisfied with products and support. But not now. I recently bought a new computer with Vista because my other one crashed (OS:XP). The Adobe suite will not work correctly with Vista on the new system. Spoken with an Adobe manager in Sweden and he said that he had never heard of the problem that the users complain over this issue. He told me to: "Upgrade to CS3 or Change back to XP".
    He also told me that ""it is up to the customer to find a solution to the problem, this is not Adobes problem". This is so far away from my earlier nice experience with Adobe.
    //Erik
    Jun 12, 2007 4:45 AM   in reply to (Dean_Salman)
    I appreciate this response is probably too late for your particular problem but I was interested in your post because I have the same issue. I have Acrobat 5.0.5 running well on XP professional but am having to move to a Vista (Premium) system and so will need to purchase the Acrobat upgrade to v8. I too was concerned that I could not load the version 5 first onto a Vista machine in order for an upgrade to be possible and so rang Adobe technical support today.
    I am told that the upgrade disc comes with the full system software for v8. You do not have to have an earlier version running on the Vista machine (indeed none works) but you do have to be able to prove ownership of an earlier eligible Acrobat package.
    I don't know if you have by now upgraded your version of Acrobat but if so I would welcome your comments on how easy it is etc.
    Also can you tell me whether or not v8 includes the document indexing and associated searching facilities that were present in v5? I found them very useful (and they were not present in v6 and possibly in v7 either) and it is really only those that stops me from simply moving to a much cheaper third party system for generating PDF documents.
    Many thanks
    Patrick
    8. ,
    Jun 12, 2007 10:17 AM   in reply to (Dean_Salman)
    PDF Printer works Great for me on Vista 64, Any language (both Roman and double-byte), many different machines. Not sure if you had some previous installation of Acrobat, or something else. UNinstall and clean up files and obvious registry settings, then try again, I think.
    Gary
    Jul 7, 2007 7:04 PM   in reply to (Dean_Salman)
    Is Adobe still a leading company in PDF? It seems Adobe is not able to handle 64-bit OS. The unbelievable delay in issuing 64-bit PDF printer, Flash player, and other Adobe-titled softwares are all not available for 64-bit OS!!! What is wrong with Adobe? I am so so so disappointed on Adobe now.
    Thanks.
    Jul 9, 2007 6:42 AM   in reply to (Dean_Salman)
    Check out this link. There may be hope after all. I hope it works because I too would like to get Adobe to work on my new 64 bit Vista system.
    http://kb.adobe.com/selfservice/viewContent.do?externalId=kb401730&sli ceId=1
    Dan
    Jul 10, 2007 5:03 AM   in reply to (Dean_Salman)
    I installed Adobe Acrobat 8.0 Professional upgrade with update 8.1 along with Microsoft hotfix kb930627 on my Vista 64 bit PC. Good news...Adobe PDF printer is now working. I haven't noticed any other bugs at the moment but I really needed the PDF printer. Hope that helps. Dan
    Nov 16, 2007 12:52 PM   in reply to (Dean_Salman)
    I use ADOBE and I am satisfied of it. In many cases when something goes well I dont improve it. In this case, luckily, I didnt try to upgrade ADOBE ACROBAT. We could compare this with the following example: even we can obtain a free shipping furniture we refuse it because we dont need it.
    Nov 23, 2007 3:18 AM   in reply to (Dean_Salman)
    I'm not sure I understand anything right here. I bought Acrobat 3D (7) some months befor and never got working the PDF Printern on my XP64 (Q6600 RAM 8GB). Now, two Adobe products can not be used here - GoLive CS2 (layout winodw to small on my screen and can not be scaled) and Acriobat PDF Printer (error 20255). Must I buy an Acrobat 3D upgrade? Is it true? Are Adobe products not good for professional engines, only for home users?
    I hope to get a solution, without to pay extra money.
    Micha
    PS: An other problem is that the flash player use very much RAM, if I start a big size object turnaround VR. The RAM usage increase until 2GB. OK, my engine has 8GB, but my clients use standard PCs only and the RAM usage let freeze the flash turntable animation.
    A Quicktime version of the VR need 40MB RAM only. So, I have three Adobe software problems now.
    Nov 23, 2007 9:29 AM   in reply to (Micha_M)
    I believe Acrobat 8.1.0 MIGHT work in Windows XP 64 (the original
    Acrobat 8.0 worked no more than 7.0). It has not been a supported
    platform. There is no direct solution without paying extra money. The
    indirect solution is of course to distill manually.
    Aandi Inston
    Nov 24, 2007 3:50 AM   in reply to (Dean_Salman)
    Thank you for the info, it's not a customer friendly solution, but it's a solution.
    Jan 5, 2008 6:09 PM   in reply to (Dean_Salman)
    Hi all,
    I have Aldus PM5, same one on W3.1, W95, W98, W98se, no trouble changing between machines, but now have been networking two computers, one W98se and XP. I'd like to 'un-network' the two and run PM5 on the XP machine, but I can't make PM5 run on the new machine. I've tried completely removing all traces of PM5 from my W98se machine, including whatever I can find in the registry, but to no avail.
    Any suggestions would be greatly appreciated.
    Many thanks
    Grant
    Jan 6, 2008 11:45 AM   in reply to (Dean_Salman)
    Hey Grant,
    You probably want to ask this question on a PageMaker forum. This is an Acrobat forum that deals specifically with 3D issues.
    Jan 15, 2008 2:14 PM   in reply to (Dean_Salman)
    If you dont mind the hassle there is a workaround. When you have a window open try either selecting web layout view in the bottom left corner of the window (this will make the window redraw/refresh) or switch to mobile view and then back to web layout view (will also cause a refresh).
    Jan 21, 2008 12:02 PM   in reply to (Dean_Salman)
    Instructions from God how to install adobe on windows vista.
    I was having trouble installing adobe on windows vista and after reading and trying endless instructions nothing worked...
    Then it hit me....
    Jesus said: Ask and it will be given to you; seek and you will find; knock and the door will be opened to you. For everyone who asks receives; he who seeks finds; and to him who knocks, the door will be opened." Matthew 7:78
    I prayed to the Lord to forgive my sins and to give me wisdom and He answered my prayer.
    Glory to the Lord for being so loving, forgiving and giving us what we seek even when we dont deserve it.
    I hope that the following instructions will help you with your work as God helped me.
    Step 00. Backup your important files and documents because the installation of vista will delete all
    Step 01. Install Dell Media Direct CD wich will create a partition for media files ( I have Dell Pc)
    Step 02. Install windows vista choosing to create fresh installation. when prompted delete the previows windows partition then create a new one and do not forget: chose the option to format it.
    Step 03. Install all necessary drivers, anti-virus, firewall and update your windows.
    Step 04. Turn Off UAC ( user account control ) by going on control panel - click user accounts -
    Step 05. Restart your PC on safe mode by pressin F8 when it is starting up.
    Step 06. Insert your adobe CD and copy all the files in your favorite folder on your Pc
    Step 07. Restart your PC normally - open the folder where you saved adobe - right click on setup.exe and chose option "run as administrator". You will now be able to use adobe on vista
    Praise the Lord for guiding us when it seems impossible. We struggle because we dont ask and when we ask we doubt. Believe and you will receive the blessings of God. We try to solve things ourselves and we dont ask The Almighty that created everything that has ever been created. God knows it all and He is willing to give us wisdom without finding fault. We just have to come near him by prayer and with repentful heart and He hears us and helps us no matter what.
    If you need more info contact me at: mynotebook@hotmail.co.uk
    God Bless
    Feb 23, 2008 6:29 PM   in reply to (Dean_Salman)
    There's got to be a solution other than re-installing Vista. Anyone have experience with it working with Vista SP1? I installed the MS hotfix before SP1 and it still would not print from anything other than Notepad. Adobe Acrobat version 8.1 says it supports Vista - no mention on whether or not it includes 64 bit. Also, the Adobe site says it will support Acrobat on 64 bit after the hotfix is installed. But still, no luck.
    This is my first experience with Adobe...no support options other than pay-as-you-go. For $1500 worth of software (I purchased Web Design Premium) this seems a bit ridiculous.
    Anyone have any luck?
    Feb 24, 2008 12:10 AM   in reply to (Dean_Salman)
    Jeff,
    Your question might be better answered on the Acrobat User-to-User forum. This forum deals specifically with 3D issues. The other forum has very many folks who you are more likely to get a quick answer from.
    Mar 2, 2008 4:49 PM   in reply to (Dean_Salman)
    The following worked for me to get acrobat print in vista x64 browser.
    go into C:\windows\inf\
    1. delete the adobe printer in your printer folder
    2. find INFCACHE.1, give yourself "full control" permission to the file.
    3. delete INFCACHE.1
    4. reboot
    5. launch acrobat 8.1.2, go to help and launch repair
    this will re-create your adobe printer.
    It seems it's possible that there might be some permission issue with the old INFCACHE.1 file which get in the way of printing. After patching up to 8.1.2 and run the repair which recreate the file (call it the INFCACHE.1 acrobate 8.1.2 version) seems to have fix my printing problem.
    and I still have UAC turned on :)
    hope the above helped.
    Shigeru Go (shigeru_go@hotmail.com)
    Mar 3, 2008 11:48 AM   in reply to (Dean_Salman)
    That worked great for me as well. Cheers!
    Mar 11, 2008 7:00 PM   in reply to (Dean_Salman)
    I tried the fix suggested by Shigeru Go but, it did not work. I am still getting a "printing (not responding)" error. I have to go to task manager and close this item. I then get an error message something like "an unexpeted error occured PDF maker was unable to produce the PDF". Adobe has not been much help. I have updated from 8.0.0 through 8.1.2, run repair (twice), to no avail.
    I bought Adobe since I thought they were the best; the program that should work "out of the box". I am very dissapointed. I will let you know how they respond. I have a service case open but, it currently has yielded no results. One of the troubleshooting links they suggested was delving deeper into system issues than I care to go. While not a complete dilletant, it seems that programs that cost hundreds of dollars should execute their basic functions without too much ado.
    Mar 18, 2008 6:10 AM   in reply to (Dean_Salman)
    Acrobat works fine if UAC is off on all versions of Acrobat and all versions of Vista. The problem is the use of the printer in such a way that it ensures it is a kernel level execution. If you do not like this, get Adobe to change it. They are only doing this to keep track of your license, likely in a system devised by Norton. Norton said they would pay me back for their software because it does not work properly.
    Given the extra level of security in Vista with UAC, I turn it off only when I have to use their printer. Most times, I print with Microsoft's XPS document printer. When I open those documents they are assigned to open in Adobe and I can convert from there. I do hope that XPS documents become more prevalent. They provide great images and are interchangeable with Adobe as indicated.
    From my perspective, Adobe just refuses to play by the rules of Vista. I had a lot more negative to say, but why bother.
    Apr 9, 2008 5:49 PM   in reply to (Dean_Salman)
    i still cant get mine to work, any help appreciated.
    [Stealth spam link removed by host. Note: such activities will impact membership as well as reception in these forums!]
    Apr 9, 2008 6:00 PM   in reply to (Dean_Salman)
    E Marrero,
    What version of Acrobat 3D are you using?
    Apr 17, 2008 6:03 PM   in reply to (Dean_Salman)
    There is a known issue with 64-bit versions of these operating systems which causes the Adobe PDF Printer to not work correctly. Microsoft has released a Hot Fix for this issue which is documented in Microsoft Knowledge Base Article #930627 available at http://support.microsoft.com/kb/930627. Adobe has tested and will support the Adobe PDF Printer with this Hot Fix installed.
    _______________________________________________________
    http://www.themeparkcodes.com , http://www.disneylandsecrets.com , http://www.rentalcarscode.com , http://bathingape-bape.blogspot.com , http://nikedunksbs.blogspot.com , http://nikeairforceonekicks.blogspot.com
    Apr 26, 2008 5:30 AM   in reply to (Dean_Salman)
    Acrobat works fine if UAC is off on all versions of Acrobat and all versions of Vista but you have to know that What version of Acrobat 3D are you using? See if these sites can help you:
    Martin Fowl
    | inkjet
    cartridge
    | data recovery
    | data recovery |
    Apr 30, 2008 7:45 AM   in reply to (Dean_Salman)
    I bought Adobe since I thought they were the best . Acrobat works fine if UAC is off on all versions of Acrobat and all versions of Vista, but I am having a small problem out here and looking for its solution.
    Martin Fowl
    | inkjet
    cartridge
    | data recovery
    | data recovery |
    Jul 5, 2008 1:38 AM   in reply to (Dean_Salman)
    For a month I have been looking for a solution to the problem with printing PDF documents from my windows Vista 64. I doesn't work when it's 32bit application. And after trying various solutions found here the only result is an inactivated Acrobat that cannot be activated. I only found one solution and that's a free PDF writer. This one works flawless on Vista 64.
    How come Adobe only blame various drivers from Microsoft when these guys seems to get it to work? I can but blame incompetence. I give up on adobes bloated PDF printer. Sorry.
    I wont put up a link here on the other solution as it may be taken as an ad.
    Jul 8, 2008 3:51 PM   in reply to (Dean_Salman)
    Actually Adobe did do something about this - its called Acrobat 8.1 (or later) - which will install the PDF driver on x64 machines. You do need to have the latest service pack for Windows however - see http://kb.adobe.com/selfservice/viewContent.do?externalId=333360&slic eId=1 for more info. 8.1 is a free update so you shouldn't have to worry about 3rd party pdf drivers to make this work.
    Also Acrobat 9 is compatible with x64 systems as well.
    Anyhow at this point if you still can't print to Adobe PDF in Windows x64 call support :).
    Jul 22, 2008 9:41 PM   in reply to (Dean_Salman)
    Got a new Dell with Vista SP1 x64 installed.
    I have installed my CS3 set and everything works but I am unable to create PDF's.
    I have downloaded and attempted to install the upgrade to 8.1 or later and get a message indicating that there is a problem installing the upgrade because it can not find the installation or because the software is improperly installed.
    But I can run all the software without problems. Just can not create a PDF or update the installation.
    Any help?
    Sep 9, 2008 12:26 PM   in reply to (Dean_Salman)
    I gather that Adobe in its infinite arrogance has simply abandoned all GoLive users, but now it appears it's abandoning its stalwart Acrobat Professional users. If the fix cited works as successfully as it appears to [rendering my $1300.00 investment in CS2 now barely usable in XP Pro x64], then one must wonder how it can be that a company with such a vast loyal user-base can continue to avoid responsibility to correct their promise that GoLive CS2 would work correctly under XP Pro x64. I had simply held off using XP Pro x64 until I'd acquired a 64-bit capable processor and system. But now I find that Adobe was misrepresenting GoLive CS2's functionality under Windows XP Pro x64 all along. It's more than a bit insulting to our collective intelligence. But more than that, it's a disgrace that Adobe felt obliged to simply lie about the usability of it's products under a 64-bit operating system just to gull the public into going ahead with 64-bit Vista System computer purchases. One could be justified for wondering if their wasn't a little kickback money sent Adobe's way from Microsoft, to push the commit decision for consumers considering the purchase of 64-bit Adobe Apps and Vista systems.
    Sep 9, 2008 11:52 PM   in reply to (Dean_Salman)
    I bought an HP Pavillion 64-bit with Vista. Installed Adobe Design CS3, couldn't print to PDF from Explorer (possibly other applications) with PDF printer. Installed all Adobe and Windows updates and service packs (as of 7 Sept 2008), including Acrobat 8.1.2; still couldn't print to PDF with Adobe Acrobat from Explorer. These instructions by Shigeru Go on updating Adobe and deleting the file in windows/inf *worked*. Uninstall/reinstall of Adobe Design CS3+Updates after disabling AV+UAC *did not work*.
    Sep 10, 2008 6:31 AM   in reply to (Dean_Salman)
    I bought an HP Pavillion with Windows Vista Home Premium 64-bit edition with service pack 1. I cannot get my CS2 software to download. Adobe wants me to upgrade to CS 3.3 for $599.
    Obviously, I feel like I am getting it put to me. Does anyone have any solutions on how to get this sofware to work?
    Sep 11, 2008 10:50 AM   in reply to (Lisa_McClenthan)
    You can follow Adobe's advice, or downgrade to Windows XP.
    Aandi Inston
    Sep 11, 2008 12:02 PM   in reply to (Dean_Salman)
    Its great to see that it supports finally! We are in love with adobe. thank you.
    Sep 11, 2008 12:56 PM   in reply to (Dean_Salman)
    Aandi,
    Thanks for the advice. I will do the downgrade.
    Lisa :)
1 2 Previous Next
Actions
