Jan 8, 2007 9:51 AM
When will this be fixed for 64 bit OS, I want to upgrade to version 8, but there is no point at this time. No version works on Vista.
Error "Warning 20225..." or no Adobe PDF printer appears (Acrobat 8.0 on Windows)
Issue
When you install Adobe Acrobat, one of the following issues occurs:
-- The Acrobat installer returns the error message, "Warning 20225: Adobe Acrobat 8 Setup was unable to create a new item: Adobe PDF Converter. The Adobe PDF Printer may be unavailable. GetLastError: The specified module could not be found." When you click OK, the installer returns the error again and completes the installation, but the Adobe PDF printer doesn't appear in Printers And Faxes in the Windows Control Panel.
-- The Adobe PDF printer doesn't appear in Printers And Faxes in the Windows Control Panel.
Solutions
Solution 1: Use a supported installation.
The following are unsupported installations, and the supported solutions:
-- If you install Acrobat (Professional or Standard) on a 64-bit operating system, then you may see this error. Install Acrobat on a 32-bit operating system.
