re: Install error PDFX1aSet_PSR_ gravure
Greetings,
My installation of Acrobat Pro 6.0 hangs when it can't find the file PDFX1aSet_PSR_ gravure.pdf. Any ideas about how to fix?
Context clues:
- Acrobat was running fine (as would have the install CD, I believe) until I removed Acrobat due to an unrelated issue using the Windows Install Cleanup program.
- I've uninstalled and reinstalled Reader 8.0; no effect
- The error is also temporally related to getting the following error when opening and closing Excel: "..compile error.. autoexecnew," then "distmon," respectively. I attempted this solution, but failed:
http://www.adobeforums.com/cgi-bin/webx/.3bc307c7
http://support.microsoft.com/?id=307410
- I've uninstalled and reinstalled Office 2003; run repair w/in Excel; no effect
- In Internet Explorer, I can open a PDF successfully, but the following error also appears: "One or more Adobe PDF extensions are disabled. This may impact how PDFs are displayed... enable add-ons [in IE]." However, all the Adobe add-ons are already enabled in IE.
Thanks very much for your ideas.
