Home/Support/
Forums
72 Replies Last post: Nov 18, 2009 9:21 AM by John Lockwood   1 2 Previous Next
User 1 posts since
Sep 3, 2008
Sep 3, 2008 1:43 PM
Acrobat Pro 9 crashes when opened on network accounts
We use network logins via Open Directory on our network. For users with either 10.5.4 or 10.4.11, whenever they try to open Acrobat on their network accounts, it hangs and eventually crashes. It will open fine on local machine accounts. This has been seen on all machines, be their Intel or G5. Here is the crash log via console. Any ideas?
Process: AdobeAcrobat [10758]
Path: /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/MacOS/AdobeAcrobat
Identifier: com.adobe.Acrobat.Pro
Version: 9.0.0 (9.0.0)
Code Type: X86 (Native)
Parent Process: launchd [83]
Date/Time: 2008-09-03 16:29:56.664 -0400
OS Version: Mac OS X 10.5.4 (9E17)
Report Version: 6
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Crashed Thread: 0
Thread 0 Crashed:
0 libSystem.B.dylib 0x921b2b9e __kill + 10
1 libSystem.B.dylib 0x92229ec2 raise + 26
2 libSystem.B.dylib 0x9223947f abort + 73
3 libstdc++.6.dylib 0x93706005 0x936be000 + 294917
4 libstdc++.6.dylib 0x9370410c __gxx_personality_v0 + 1108
5 libstdc++.6.dylib 0x9370414b std::terminate() + 29
6 libstdc++.6.dylib 0x93704261 __cxa_throw + 101
7 com.adobe.Acrobat.framework 0x8097b2cb CopiesPagesPDE_Open + 8743607
8 com.adobe.Acrobat.framework 0x8093cbb6 CopiesPagesPDE_Open + 8487842
9 com.adobe.Acrobat.framework 0x8093be15 CopiesPagesPDE_Open + 8484353
10 com.adobe.Acrobat.framework 0x8093d400 CopiesPagesPDE_Open + 8489964
11 com.adobe.Acrobat.framework 0x80d05fc7 0x7feb8000 + 14999495
12 com.adobe.Acrobat.framework 0x80d06172 0x7feb8000 + 14999922
13 com.adobe.Acrobat.framework 0x808c7a88 CopiesPagesPDE_Open + 8008308
14 com.adobe.Acrobat.framework 0x807709d0 CopiesPagesPDE_Open + 6603196
15 com.adobe.Acrobat.framework 0x80770bbb CopiesPagesPDE_Open + 6603687
16 com.adobe.Acrobat.framework 0x80005c8b RunAcrobat + 1357585
17 com.adobe.Acrobat.framework 0x800059c0 RunAcrobat + 1356870
18 com.apple.CoreFoundation 0x96973b45 CFRunLoopRunSpecific + 4469
19 com.apple.CoreFoundation 0x96973cf8 CFRunLoopRunInMode + 88
20 com.apple.HIToolbox 0x92cc9da4 RunCurrentEventLoopInMode + 283
21 com.apple.HIToolbox 0x92cc9bbd ReceiveNextEventCommon + 374
22 com.apple.HIToolbox 0x92cc9a31 BlockUntilNextEventMatchingListInMode + 106
23 com.apple.AppKit 0x948b7505 _DPSNextEvent + 657
24 com.apple.AppKit 0x948b6db8 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128
25 com.apple.AppKit 0x948afdf3 -[NSApplication run] + 795
26 com.adobe.Acrobat.framework 0x7febb18c RunAcrobat + 3090
27 com.adobe.Acrobat.framework 0x7feba6b8 RunAcrobat + 318
28 com.adobe.Acrobat.Pro 0x00002e8b start + 2371
29 com.adobe.Acrobat.Pro 0x0000264a start + 258
30 com.adobe.Acrobat.Pro 0x00002571 start + 41
Thread 1:
0 libSystem.B.dylib 0x9214b68e __semwait_signal + 10
1 libSystem.B.dylib 0x9217636d pthread_cond_wait$UNIX2003 + 73
2 com.apple.ColorSync 0x917f7460 pthreadSemaphoreWait(t_pthreadSemaphore*) + 42
3 com.apple.ColorSync 0x91809d92 CMMConvTask(void*) + 54
4 libSystem.B.dylib 0x921756f5 _pthread_start + 321
5 libSystem.B.dylib 0x921755b2 thread_start + 34
Thread 2:
2 ...ple.CoreServices.CarbonCore 0x9376724f TSWaitOnCondition + 126
3 ...ple.CoreServices.CarbonCore 0x9374618e TSWaitOnConditionTimedRelative + 202
4 ...ple.CoreServices.CarbonCore 0x93766ecc MPWaitOnQueue + 208
5 AdobeACE 0x7fc1dd8d ACEMPThread::Task(
User 2 posts since
Sep 18, 2008
1. Sep 18, 2008 5:44 PM in response to: (msingerman)
Re: Acrobat Pro 9 crashes when opened on network accounts
We are having the same problem with Reader 9 on our 10.4.11 macs. Local users have no problem, but network users all experience a stall that requires a force-quit. It's disheartening to see that you have no responses after 15 days.
We recently downloaded a parking permit from one of our local community colleges and normally we would just use the preview app, but this document requires reader 9. So much for PDF being a standard any more.
User 1 posts since
Aug 11, 2002
2. Sep 22, 2008 1:43 AM in response to: (msingerman)
Hello, we also have the same Problem and there seems to be no solution.
So i started a call at Adobe.
But at the free technical support they cannot help me with this.
I should use this user to user forum.
Thanks Adobe for testing your software!
try67 Participant 1,576 posts since
Aug 21, 2008
3. Sep 22, 2008 9:56 AM in response to: (msingerman)
Do you mean that you're trying to open the application itself over a network, or is the application installed locally and the files are opened over a network?
User 2 posts since
Sep 18, 2008
4. Sep 22, 2008 5:07 PM in response to: (msingerman)
the application is locally installed. The user's home directory is on the server.
User 1 posts since
Sep 23, 2008
5. Sep 23, 2008 2:21 PM in response to: (msingerman)
We are having a similar problem.
I have tried various preferences/permissions/etc. with no luck.
It has also been documented/discussed on the Macintosh Management
list on Apple.
The only "solution" so far has been the suggestion to remove Acrobat Reader.
cpm
User 7 posts since
Aug 11, 2002
6. Sep 26, 2008 12:06 PM in response to: (msingerman)
Has anyone tested this issue using a "Mobile" user account? All of the systems we set up are either AD or OD accounts but are always set up as a mobile user.
I will try to test this in one of our environments as soon as we get a copy of 9 installed.
User 1 posts since
Oct 3, 2008
7. Oct 3, 2008 7:21 AM in response to: (msingerman)
I am having this problem with the plugin and the Acrobat application. The programs are local and the accounts and homes are on the network. I removed the Adobe pdf plugin and now Safari doesn't crash 10 seconds after opening a pdf. Acrobat Pro 9 does the same thing. So we are using Preview.
User 4 posts since
Jun 22, 2006
8. Oct 24, 2008 12:50 PM in response to: (msingerman)
Late October and the problem still exists (at least for me) Anyone found a fix?
thanks
Jim Pattison
User 1 posts since
Oct 27, 2008
9. Oct 27, 2008 8:52 AM in response to: (msingerman)
No Fix yet....
Adobe Still refuses to help over the phone,
or even send word to programmers.
They even were brazen enough to blamed it on the network,
which works for every other application I've installed. Curious.
User 53 posts since
May 30, 2008
10. Nov 5, 2008 7:33 PM in response to: (msingerman)
Since so many of you seem to be having this particular issue with remote user directories then this scenario was likely not tested by Adobe. The question to ask yourselves is "Did this ever work?" If it did, then what has changed? If not, then it may not be possible to get it to work at this time.
Sanctus
User 7 posts since
Aug 11, 2002
11. Nov 6, 2008 12:21 AM in response to: (msingerman)
It has been working fine with Acrobat 8 and Domain accounts for a long time now.
User 53 posts since
May 30, 2008
12. Nov 6, 2008 8:32 AM in response to: (msingerman)
So, what has changed? If you are using Acrobat 9.0 and not version 8.0 then obviously the version of Acrobat, but has anything else changed? Server version? Did you previously use Tiger Server and move to Leopard server?
Sanctus
Nemuri13 User 155 posts since
Jan 12, 2004
13. Nov 6, 2008 11:48 AM in response to: (msingerman)
To all concerned: This is a known issue with people using folder redirection software. To my knowledge Adobe is working on an update that will address this issue; however there is no release date as far as I have seen on the Internet. Acrobat 8 will not cause this issue.
User 4 posts since
Jun 22, 2006
14. Nov 6, 2008 11:58 AM in response to: (msingerman)
Sanctus, to answer your question more fully, the version of server doesn't seem to make a difference, in that Reader 7 or 8 will work fine with accounts hosted on a OS10.4.x server or on a 10.5.x server. Reader 9 won't work with accounts hosted on a 10.5.x server ( I haven't tested it with a 10.4.x as it easier to roll back the Reader version than it is the server version)
Jim
User 7 posts since
Aug 11, 2002
15. Nov 6, 2008 2:56 PM in response to: (msingerman)
Just to possibly further help Adobe:
In my cases the accounts are set up as Mobile Users. The controller can either be an Open Directory or an Active Directory server. I have seen the issue under both environments.
Tom
Steve Cordero Employee2 33 posts since
Jan 16, 2009
16. Nov 7, 2008 11:06 AM in response to: (msingerman)
Can a few of you post the error message(s) and crash logs text? Just want to see if it's the same basic error.
~Steve
User 4 posts since
Jun 22, 2006
17. Nov 10, 2008 6:51 AM in response to: (msingerman)
Here you go-there is no error message-Reader just locks up<br /><br />Process:         AdobeReader [1315]<br />Path:            /Applications/Adobe Reader 9/Adobe Reader.app/Contents/MacOS/AdobeReader<br />Identifier:      com.adobe.Reader<br />Version:         9.0.0 (9.0.0)<br />Code Type:       X86 (Native)<br />Parent Process:  launchd [192]<br /><br />Date/Time:       2008-10-24 14:15:06.860 -0500<br />OS Version:      Mac OS X 10.5.5 (9F33)<br />Report Version:  6<br /><br />Exception Type:  EXC_CRASH (SIGABRT)<br />Exception Codes: 0x0000000000000000, 0x0000000000000000<br />Crashed Thread:  0<br /><br />Thread 0 Crashed:<br />0   libSystem.B.dylib          &n bsp;       0x92c0ab9e __kill + 10<br />1   libSystem.B.dylib          &n bsp;       0x92c81ec2 raise + 26<br />2   libSystem.B.dylib          &n bsp;       0x92c9147f abort + 73<br />3   libstdc++.6.dylib          &n bsp;       0x95682005 0x9563a000 + 294917<br />4   libstdc++.6.dylib          &n bsp;       0x9568010c __gxx_personality_v0 + 1108<br />5   libstdc++.6.dylib          &n bsp;       0x9568014b std::terminate() + 29<br />6   libstdc++.6.dylib          &n bsp;       0x95680261 __cxa_throw + 101<br />7   com.adobe.Acrobat.framework        0x806bb5bb CopiesPagesPDE_Open + 6632861<br />8   com.adobe.Acrobat.framework        0x8068c56a CopiesPagesPDE_Open + 6440268<br />9   com.adobe.Acrobat.framework        0x8068b7c9 CopiesPagesPDE_Open + 6436779<br />10  com.adobe.Acrobat.framework        0x8068cdb4 CopiesPagesPDE_Open + 6442390<br />11  com.adobe.Acrobat.framework        0x809bf41b 0x7feb8000 + 11564059<br />12  com.adobe.Acrobat.framework        0x809bf5c6 0x7feb8000 + 11564486<br />13  com.adobe.Acrobat.framework        0x8062bcf8 CopiesPagesPDE_Open + 6044890<br />14  com.adobe.Acrobat.framework        0x804c6fa0 CopiesPagesPDE_Open + 4583298<br />15  com.adobe.Acrobat.framework        0x804c718b CopiesPagesPDE_Open + 4583789<br />16  com.adobe.Acrobat.framework        0x7fff9285 RunAcrobat + 1304851<br />17  com.adobe.Acrobat.framework        0x7fff8fb8 RunAcrobat + 1304134<br />18  com.apple.CoreFoundation           0x93ae7b45 CFRunLoopRunSpecific + 4469<br />19  com.apple.CoreFoundation           0x93ae7cf8 CFRunLoopRunInMode + 88<br />20  com.apple.HIToolbox                0x95726480 RunCurrentEventLoopInMode + 283<br />21  com.apple.HIToolbox                0x95726299 ReceiveNextEventCommon + 374<br />22  com.apple.HIToolbox                0x9572610d BlockUntilNextEventMatchingListInMode + 106<br />23  com.apple.AppKit          &nb sp;        0x90e6b3ed _DPSNextEvent + 657<br />24  com.apple.AppKit          &nb sp;        0x90e6aca0 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128<br />25  com.apple.AppKit          &nb sp;        0x90e63cdb -[NSApplication run] + 795<br />26  com.adobe.Acrobat.framework        0x7febb36d RunAcrobat + 2555<br />27  com.adobe.Acrobat.framework        0x7febaab0 RunAcrobat + 318<br />28  com.adobe.Reader          &nb sp;        0x00002e8b start + 2371<br />29  com.adobe.Reader          &nb sp;        0x0000264a start + 258<br />30  com.adobe.Reader          &nb sp;        0x00002571 start + 41<br /><br />Thread 1:<br />0   libSystem.B.dylib          &n bsp;       0x92ba368e __semwait_signal + 10<br />1   libSystem.B.dylib          &n bsp;       0x92bce36d pthread_cond_wait$UNIX2003 + 73<br />2   com.apple.ColorSync                0x9175f460 pthreadSemaphoreWait(t_pthreadSemaphore*) + 42<br />3   com.apple.ColorSync                0x91771d92 CMMConvTask(void*) + 54<br />4   libSystem.B.dylib          &n bsp;       0x92bcd6f5 _pthread_start + 321<br />5   libSystem.B.dylib          &n bsp;       0x92bcd5b2 thread_start + 34<br /><br />Thread 2:<br />0   libSystem.B.dylib          &n bsp;       0x92b9c4a6 mach_msg_trap + 10<br />1   libSystem.B.dylib          &n bsp;       0x92ba3c9c mach_msg + 72<br />2   com.apple.CoreFoundation           0x93ae70ce CFRunLoopRunSpecific + 1790<br />3   com.apple.CoreFoundation           0x93ae7cf8 CFRunLoopRunInMode + 88<br />4   com.apple.CFNetwork                0x91851eca CFURLCacheWorkerThread(void*) + 396<br />5   libSystem.B.dylib          &n bsp;       0x92bcd6f5 _pthread_start + 321<br />6   libSystem.B.dylib          &n bsp;       0x92bcd5b2 thread_start + 34<br /><br />Thread 3:<br />0   libSystem.B.dylib          &n bsp;       0x92ba368e __semwait_signal + 10<br />1   libSystem.B.dylib          &n bsp;       0x92bce36d pthread_cond_wait$UNIX2003 + 73<br />2   ...ple.CoreServices.CarbonCore     0x9628c24f TSWaitOnCondition + 126<br />3   ...ple.CoreServices.CarbonCore     0x9626b18e TSWaitOnConditionTimedRelative + 202<br />4   ...ple.CoreServices.CarbonCore     0x9628becc MPWaitOnQueue + 208<br />5   AdobeACE           &nbsp ;               0x7fc1dd8d ACEMPThread::Task() + 133<br />6   AdobeACE           &nbsp ;               0x7fc1dd01 TaskGlue + 17<br />7   ...ple.CoreServices.CarbonCore     0x9628a463 PrivateMPEntryPoint + 56<br />8   libSystem.B.dylib          &n bsp;       0x92bcd6f5 _pthread_start + 321<br />9   libSystem.B.dylib          &n bsp;       0x92bcd5b2 thread_start + 34<br /><br />Thread 4:<br />0   libSystem.B.dylib          &n bsp;       0x92b9c4ee semaphore_wait_signal_trap + 10<br />1   libSystem.B.dylib          &n bsp;       0x92bce866 _pthread_cond_wait + 1267<br />2   libSystem.B.dylib          &n bsp;       0x92c14371 pthread_cond_wait + 48<br />3   AdobeAGM           &nbsp ;               0x7e574984 pthread_condition_base::Wait(pthread_scoped_lock_base&) + 26<br />4   AdobeAGM           &nbsp ;               0x7e5748b5 AGMMessageQueueImpl::Pull() + 65<br />5   AdobeAGM           &nbsp ;               0x7e963fc4 AGMWorkQueueTask::operator()() + 84<br />6   AdobeAGM           &nbsp ;               0x7e96524f boost::function0<void, std::allocator<boost::function_base> >::operator()() const + 75<br />7   AdobeAGM           &nbsp ;               0x7e57476d thread_proxy + 45<br />8   libSystem.B.dylib          &n bsp;       0x92bcd6f5 _pthread_start + 321<br />9   libSystem.B.dylib          &n bsp;       0x92bcd5b2 thread_start + 34<br /><br />Thread 0 crashed with X86 Thread State (32-bit):<br />  eax: 0x00000000  ebx: 0x92c9143f  ecx: 0xbfffe49c  edx: 0x92c0ab9e<br />  edi: 0x80a296ec  esi: 0xa03ae578  ebp: 0xbfffe4b8  esp: 0xbfffe49c<br />   ss: 0x0000001f  efl: 0x00000286  eip: 0x92c0ab9e   cs: 0x00000007<br />   ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037<br />  cr2: 0xffe178e0
User 12 posts since
Aug 11, 2002
18. Nov 12, 2008 1:04 PM in response to: (msingerman)
I have a client with the same problem, profiles are kept on an OSX server. Adobe Support said to monitor this forum for a solution. Here's the error log:
Date/Time: 2008-11-12 14:01:43 -0500
OS Version: 10.5.5 (Build 9F33)
Architecture: i386
Report Version: 4
Command: Acrobat
Parent: launchd [126]
PID: 1418
Event: hang
Time: 9.17s
Steps: 66
Process: AdobeAcrobat [1418]
ADDRESS BINARY
00001000 /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/MacOS/AdobeAcrobat
0059c000 /usr/lib/libmx.A.dylib
005b2000 /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
007d7000 /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/Frameworks/asneu.framework/asneu
007e8000 /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/Frameworks/adobe_eula.framework/adobe_eula
15f7f000 /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AMTLibWrapper.framework/AMTLibWrapper
160e3000 /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/Frameworks/adobe_epic.framework/adobe_epic
16128000 /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/MacOS/AdobeLM_libFNP.dylib
16d68000 /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
16d7a000 /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AcroSQLite.framework/AcroSQLite
75c6d000 /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/Plug-ins/PPKLite.acroplugin/Contents/MacOS/PPKLite
7ac2b000 /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/Plug-ins/Comments.acroplugin/Contents/MacOS/Comments
7d848000 /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/Frameworks/Acrobat.framework/../AdobeCoolType.framework/Versio ns/A/AdobeCoolType
7e4bb000 /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/Frameworks/Acrobat.framework/../AdobeBIB.framework/Versions/A/ AdobeBIB
7e56c000 /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/Frameworks/Acrobat.framework/../AdobeAGM.framework/Versions/A/ AdobeAGM
7fc1b000 /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/Frameworks/Acrobat.framework/../AdobeACE.framework/Versions/A/ AdobeACE
7feb8000 /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/Frameworks/Acrobat.framework/Acrobat
Thread id: 10d13128
User stack:
66 start + 41 (in AdobeAcrobat) [0x2571]
66 start + 258 (in AdobeAcrobat) [0x264a]
66 start + 2371 (in AdobeAcrobat) [0x2e8b]
66 _RunAcrobat + 318 (in Acrobat) [0x7feba6b8]
66 _RunAcrobat + 3090 (in Acrobat) [0x7febb18c]
66 -[NSApplication run] + 795 (in AppKit) [0x9336dcdb]
66 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128 (in AppKit) [0x93374ca0]
66 __DPSNextEvent + 657 (in AppKit) [0x933753ed]
66 _BlockUntilNextEventMatchingListInMode + 106 (in HIToolbox) [0x90d8810d]
66 _ReceiveNextEventCommon + 374 (in HIToolbox) [0x90d88299]
66 _RunCurrentEventLoopInMode + 283 (in HIToolbox) [0x90d88480]
66 _CFRunLoopRunInMode + 88 (in CoreFoundation) [0x95ff4cf8]
66 _CFRunLoopRunSpecific + 4469 (in CoreFoundation) [0x95ff4b45]
66 _RunAcrobat + 1356870 (in Acrobat) [0x800059c0]
66 _RunAcrobat + 1357585 (in Acrobat) [0x80005c8b]
66 ??? [0x80770bbb]
66 ??? [0x807709d0]
66 ??? [0x808c7a88]
66 ??? [0x80d06172]
66 ??? [0x80d05ef4]
66 ??? [0x8093d336]
66 ??? [0x8093d228]
66 ??? [0x8093d17d]
66 ??? [0x8097b47e]
66 _sqlite3_open + 45746 (in AcroSQLite) [0x16da1ee5]
66 _sqlite3_open + 45003 (in AcroSQLite) [0x16da1bfe]
66 _sqlite3_get_table + 2851 (in AcroSQLite) [0x16daa1fa]
66 _sqlite3_open + 26121 (in AcroSQLite) [0x16d9d23c]
66 _sqlite3_mprintf + 14007 (in AcroSQLite) [0x16da6cbc]
66 _sqlite3_mprintf + 11140 (in AcroSQLite) [0x16da6189]
66 _sqlite3_mprintf + 8238 (in AcroSQLite) [0x16da5633]
66 ??? [0x16d85d0c]
66 _sqlite3_prepare_v2 + 1981 (in AcroSQLite) [0x16da2786]
66 _sqlite3_prepare_v2 + 1797 (in AcroSQLite) [0x16da26ce]
66 _sqlite3_prepare_v2 + 904 (in AcroSQLite) [0x16da2351]
66 ??? [0x16d83fce]
66 ??? [0x16d82998]
66 ??? [0x16d7df82]
66 _sqlite3_open + 17532 (in AcroSQLite) [0x16d9b0af]
66 _sqlite3_open + 7720 (in AcroSQLite) [0x16d98a5b]
66 _sqlite3_close + 1611 (in AcroSQLite) [0x16d95beb]
66 ??? [0x8093ba76]
66 ??? [0x8076aaa5]
66 _mach_wait_until + 10 (in libSystem.B.dylib) [0x964a05c6]
Kernel stack:
5 _dtrace_get_cpu_int_stack_top + 543 [0x1974c2]
5 _mach_wait_until_trap + 61 [0x12975d]
5 _thread_block + 33 [0x136ac0]
5 _thread_block_reason + 135 [0x136a1c]
5 _thread_setrun + 3173 [0x135f10]
5 _machine_idle + 278 [0x1a2aab]
Thread id: f7efc80
User stack:
66 _thread_start + 34 (in libSystem.B.dylib) [0x964d15b2]
66 __pthread_start + 321 (in libSystem.B.dylib) [0x964d16f5]
66 _PrivateMPEntryPoint + 56 (in CarbonCore) [0x95bb7463]
66 _TaskGlue + 17 (in AdobeACE) [0x7fc1dd01]
66 __ZN11ACEMPThread4TaskEv + 133 (in AdobeACE) [0x7fc1dd8d]
66 _MPWaitOnQueue + 208 (in CarbonCore) [0x95bb8ecc]
66 _TSWaitOnConditionTimedRelative + 202 (in CarbonCore) [0x95b9818e]
66 _TSWaitOnCondition + 126 (in CarbonCore) [0x95bb924f]
66 ___semwait_signal + 10 (in libSystem.B.dylib) [0x964a768e]
Thread id: fd29e40
User sta
User 1 posts since
Nov 17, 2008
19. Nov 17, 2008 2:17 AM in response to: (msingerman)
As was mentioned before a local user has no problem. With a networked user (home on a 10.5.4 server) we observe the same lockup as described above. However, when I create a mobile account whereby the user home is synched to the local harddisk Adobe Acrobat Pro 9 (and Adobe Reader 9 as well) work flawlessly.
Roger
User 2 posts since
Dec 8, 2008
20. Dec 8, 2008 7:29 PM in response to: (msingerman)
Same problem here.
Tried disabling Acrobat plugins. No luck.
Tried copying user plist files from local admin account to remote user account. No luck.
Read something about acrobat 7 having this issue and solution being to alias cache to local computer's shared folder. I tried this unsuccessfully.
User 2 posts since
Dec 8, 2008
21. Dec 9, 2008 8:07 PM in response to: (msingerman)
Downgraded to Acrobat 8 and now it works, but still gives an error that can APPARENTLY be ignored:
"Could not initialize Organizer database. Organizer features will not be available"
User 3 posts since
Dec 11, 2008
22. Dec 11, 2008 3:10 PM in response to: (msingerman)
Has this been resolved?
I just started installing CS4 and Acrobat Pro 9 hangs when launched on a network home.
User 5 posts since
May 21, 2006
23. Dec 11, 2008 4:38 PM in response to: (msingerman)
Phillip,
Not that I have heard-everyone that tries it gets the same results that you see
Jim
User 3 posts since
Dec 11, 2008
24. Dec 14, 2008 2:34 PM in response to: (msingerman)
Thanks Jim
Interestingly if you drag and drop a document onto the app it opens that document then hangs.
User 2 posts since
Nov 24, 2008
25. Jan 21, 2009 9:43 AM in response to: (msingerman)
We have just installed Acrobat 9 and are having the same issue. We are running Mac on OS 10.5.6 with users on an Xserve with OS 10.4. Acrobat 8 works fine.
User 3 posts since
Dec 11, 2008
26. Jan 27, 2009 7:44 PM in response to: (msingerman)
I gave up waiting for someone to even acknowledge there is a problem despite putting in a bug report.
I've downgraded to version 8.
User 1 posts since
Jan 28, 2009
27. Jan 28, 2009 4:41 PM in response to: (msingerman)
I'm having the same problem.
a related question -- Does anyone know how to make a network user a local administrator?
Perhaps if the networked user is a local admin on the computer it could work...
User 4 posts since
Jun 22, 2006
28. Jan 29, 2009 6:33 AM in response to: (msingerman)
Elliot, when logged in as the user, go to system preferences/accounts, click on the user's name, then click on (going from memory here as my Mac is elsewhere) allow user to manage this computer.
However, that doesn't solve this problem. All my users have that right.
Jim PAttison
(Zeljko_Milic) User 2 posts since
Jan 25, 2005
29. Feb 9, 2009 12:59 AM in response to: (msingerman)
I have 2 pofiles: One on my Macintosh (G5) and one on the XServe.<br />Acrobat 9 on the profile on the mac (admin), goes with no problems.<br />After switching on the user profile on the server, acrobat crashes on starting the app (endless spinball!). The same effect is, when i started a webbased pdf on my browser (safari or firefox).<br />The errors on my crashreporter:<br /><br />Process:         AdobeAcrobat [1902]<br />Path:            /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/MacOS/AdobeAcrobat<br />Identifier:      com.adobe.Acrobat.Pro<br />Version:         9.0.0 (9.0.0)<br />Code Type:       PPC (Native)<br />Parent Process:  launchd [87]<br /><br />Date/Time:       2009-01-30 14:38:51.043 +0100<br />OS Version:      Mac OS X 10.5.6 (9G55)<br />Report Version:  6<br /><br />Exception Type:  EXC_CRASH (SIGABRT)<br />Exception Codes: 0x0000000000000000, 0x0000000000000000<br />Crashed Thread:  0<br /><br />Thread 0 Crashed:<br />0   libSystem.B.dylib          &n bsp;       0x9491caf0 __kill + 12<br />1   libSystem.B.dylib          &n bsp;       0x949b7bac abort + 84<br />2   libstdc++.6.dylib          &n bsp;       0x9094ce24 __gnu_cxx::__verbose_terminate_handler() + 400<br />3   libstdc++.6.dylib          &n bsp;       0x9094a940 __gxx_personality_v0 + 1240<br />4   libstdc++.6.dylib          &n bsp;       0x9094a9a4 std::terminate() + 68<br />5   libstdc++.6.dylib          &n bsp;       0x9094abe4 __cxa_throw + 124<br />6   com.adobe.Acrobat.framework        0x81039208 CopiesPagesPDE_Open + 14244664<br />7   com.adobe.Acrobat.framework        0x80fe5f04 CopiesPagesPDE_Open + 13903924<br />8   com.adobe.Acrobat.framework        0x80fe44e8 CopiesPagesPDE_Open + 13897240<br />9   com.adobe.Acrobat.framework        0x80fe7268 CopiesPagesPDE_Open + 13908888<br />10  com.adobe.Acrobat.framework        0x8175bc40 0x7feb8000 + 25836608<br />11  com.adobe.Acrobat.framework        0x8175c1e0 0x7feb8000 + 25838048<br />12  com.adobe.Acrobat.framework        0x80f33860 CopiesPagesPDE_Open + 13173136<br />13  com.adobe.Acrobat.framework        0x80cf6120 CopiesPagesPDE_Open + 10824272<br />14  com.adobe.Acrobat.framework        0x80cf653c CopiesPagesPDE_Open + 10825324<br />15  com.adobe.Acrobat.framework        0x800db844 RunAcrobat + 2229524<br />16  com.adobe.Acrobat.framework        0x800db30c RunAcrobat + 2228188<br />17  com.apple.CoreFoundation           0x904759d8 CFRunLoopRunSpecific + 2968<br />18  com.apple.HIToolbox                0x9340dbc4 RunCurrentEventLoopInMode + 264<br />19  com.apple.HIToolbox                0x9340d9e8 ReceiveNextEventCommon + 412<br />20  com.apple.HIToolbox                0x9340d828 BlockUntilNextEventMatchingListInMode + 84<br />21  com.apple.AppKit          &nb sp;        0x90ae6724 _DPSNextEvent + 596<br />22  com.apple.AppKit          &nb sp;        0x90ae60dc -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 112<br />23  com.apple.AppKit          &nb sp;        0x90adfd98 -[NSApplication run] + 736<br />24  com.adobe.Acrobat.framework        0x7febcb2c RunAcrobat + 6140<br />25  com.adobe.Acrobat.framework        0x7febb428 RunAcrobat + 248<br />26  com.adobe.Acrobat.Pro              0x00003b98 start + 5392<br />27  com.adobe.Acrobat.Pro              0x000029b0 start + 808<br />28  com.adobe.Acrobat.Pro              0x000026b4 start + 44<br /><br />Thread 1:<br />0   libSystem.B.dylib          &n bsp;       0x948a1b6c __semwait_signal + 12<br />1   libSystem.B.dylib          &n bsp;       0x948de3cc _pthread_cond_wait + 1580<br />2   com.apple.ColorSync                0x903710b0 pthreadSemaphoreWait(t_pthreadSemaphore*) + 36<br />3   com.apple.ColorSync                0x90384bec CMMConvTask(void*) + 48<br />4   libSystem.B.dylib          &n bsp;       0x948dd024 _pthread_start + 316<br /><br />Thread 2:<br />0   libSystem.B.dylib          &n bsp;       0x948a1b6c __semwait_signal + 12<br />1   libSystem.B.dylib          &n bsp;       0x948de3cc _pthread_cond_wait + 1580<br />2   ...ple.CoreServices.CarbonCore     0x9240e688 TSWaitOnCondition + 132<br />3   ...ple.CoreServices.CarbonCore     0x923ecae4 TSWaitOnConditionTimedRelative + 204<br />4   ...ple.CoreServices.CarbonCore     0x9240e244 MPWaitOnQueue + 272<br />5   AdobeACE           &nbsp ;               0x7fc1dc5c ACEMPThread::Task() + 148<br />6   AdobeACE           &nbsp ;               0x7fc1dbb0 TaskGlue + 24<br />7   ...ple.CoreServices.CarbonCore     0x9240c478 PrivateMPEntryPoint + 76<br />8   libSystem.B.dylib          &n bsp;       0x948dd024 _pthread_start + 316<br /><br />Thread 3:<br />0   libSystem.B.dylib          &n bsp;       0x9489b1b8 semaphore_wait_signal_trap + 8<br />1   AdobeAGM           &nbsp ;               0x7e5757b0 AGMMessageQueueImpl::Pull() + 72<br />2   AdobeAGM           &nbsp ;               0x7e9759f8 AGMWorkQueueTask::operator()() + 88<br />3   AdobeAGM           &nbsp ;               0x7e9761b4 boost::function0<void, std::allocator<boost::function_base> >::operator()() const + 96<br />4   AdobeAGM           &nbsp ;               0x7e57562c thread_proxy + 44<br />5   libSystem.B.dylib          &n bsp;       0x948dd024 _pthread_start + 316<br /><br />Thread 4:<br />0   libSystem.B.dylib          &n bsp;       0x9489b1d8 semaphore_timedwait_signal_trap + 8<br />1   libSystem.B.dylib          &n bsp;       0x948de2c8 _pthread_cond_wait + 1320<br />2   com.apple.Foundation               0x95532b24 -[NSCondition waitUntilDate:] + 384<br />3   com.apple.Foundation               0x95532950 -[NSConditionLock lockWhenCondition:beforeDate:] + 268<br />4   ...adobe.acrobat.amtlibwrapper     0x0de28a40 AVAMTForegroundUpdateCheckEnabled + 180820<br />5   ...adobe.acrobat.amtlibwrapper     0x0de170e4 AVAMTForegroundUpdateCheckEnabled + 108792<br />6   ...adobe.acrobat.amtlibwrapper     0x0de26f40 AVAMTForegroundUpdateCheckEnabled + 173908<br />7   com.apple.Foundation               0x954f5764 __NSThread__main__ + 1004<br />8   libSystem.B.dylib          &n bsp;       0x948dd024 _pthread_start + 316<br /><br />Thread 5:<br />0   libSystem.B.dylib          &n bsp;       0x9489b1d8 semaphore_timedwait_signal_trap + 8<br />1   libSystem.B.dylib          &n bsp;       0x948de2c8 _pthread_cond_wait + 1320<br />2   com.apple.Foundation               0x95532b24 -[NSCondition waitUntilDate:] + 384<br />3   com.apple.Foundation               0x95532950 -[NSConditionLock lockWhenCondition:beforeDate:] + 268<br />4   com.apple.AppKit          &nb sp;        0x90b41eac -[NSUIHeartBeat _heartBeatThread:] + 664<br />5   com.apple.Foundation               0x954f5764 __NSThread__main__ + 1004<br />6   libSystem.B.dylib          &n bsp;       0x948dd024 _pthread_start + 316<br /><br />Thread 0 crashed with PPC Thread State 32:<br />  srr0: 0x9491caf0  srr1: 0x0200f030   dar: 0xe0963088 dsisr: 0x40000000<br />    r0: 0x00000025    r1: 0xbfffdc00    r2: 0x00001000    r3: 0x00000000<br />    r4: 0x00000000    r5: 0x00000001    r6: 0x000049da    r7: 0x00000840<br />    r8: 0x9094cd8c    r9: 0x0dc32bf0   r10: 0x948e5964   r11: 0xa0862530<br />   r12: 0x9491cadc   r13: 0x00000000   r14: 0xa0082478   r15: 0x7fffffff<br />   r16: 0xffffffff   r17: 0x00000001   r18: 0x00000000   r19: 0x00000000<br />   r20: 0xbfffdf2c   r21: 0xbfffde84   r22: 0xbfffde9c   r23: 0x0d869024<br />   r24: 0xbfffde6c   r25: 0xbfffdefc   r26: 0xbfffdeb4   r27: 0x0dc731a0<br />   r28: 0xa018cca0   r29: 0xa08603a0   r30: 0x810faf88   r31: 0x949b7b64<br />    cr: 0x44042202   xer: 0x00000000    lr: 0x949b7bb0   ctr: 0x9491cadc<br />vrsave: 0x00000fff<br /><br />Binary Images:<br />    0x1000 -     0x3fcf +com.adobe.Acrobat.Pro 9.0.0 (9.0.0) <40558512dee14e998d35a3a0bacb696b> /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/MacOS/AdobeAcrobat<br /> 0xcf97000 -  0xd149ff7  com.apple.RawCamera.bundle 2.0.10 (2.0.10) <385afe576f8fd60530711a5eab4ed182> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera<br /> 0xd53e000 -  0xd55cfe3 +com.adobe.selfhealer AdobeSelfHealing version 2.2.0 (2.2.0) <51d258fb243d450fbd639084d19aad11> /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeSelfHealing.framework/AdobeSelfHealing<br /> 0xdb83000 -  0xdbcbffb +com.adobe.adobe_caps adobe_caps 0.0.120.0 (0.0.120.0) /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/Frameworks/adobe_caps.framework/adobe_caps<br /> 0xdbd1000 -  0xdbf2ff1  libmx.A.dylib ??? (???) /usr/lib/libmx.A.dylib<br /> 0xddfa000 -  0xdf41fff +com.adobe.acrobat.amtlibwrapper 1.0 (1.0) <5063d34522494fe8adb6fdc3cd829e2c> /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AMTLibWrapper.framework/AMTLibWrapper<br /> 0xdf6b000 -  0xdf7efef +com.adobe.asneu.framework asneu version 1.6.2f01 (1.6.2) /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/Frameworks/asneu.framework/asneu
User 2 posts since
Feb 10, 2009
30. Feb 10, 2009 8:02 AM in response to: (msingerman)
ADOBE DOESN'T CARE. We spent money on Acrobat 7 and Acrobat 8 and were unable to run them unless the user had administrative privileges. With Acrobat 9 that seems to be fixed, however network users are still left in the cold. We are having the EXACT same issues. Mobile accounts work; network accounts do not. I'm TIRED of their arrogance.
User 2 posts since
Feb 10, 2009
31. Feb 11, 2009 10:44 AM in response to: (msingerman)
Console report:
2/11/09 12:31:54 PM [0x0-0xa90a9].com.adobe.Acrobat.Pro[865] terminate called after throwing an instance of 'SQLiteUtils::SQLiteException'
2/11/09 12:32:01 PM com.apple.launchd[815] ([0x0-0xa90a9].com.adobe.Acrobat.Pro[865]) Exited abnormally: Abort trap
2/11/09 12:32:57 PM com.apple.launchd[815] ([0x0-0xae0ae].com.adobe.Acrobat.Pro[883]) Exited: Terminated
User 2 posts since
Feb 12, 2009
32. Feb 12, 2009 2:30 PM in response to: (msingerman)
My client computers are having the same problems with Acrobat 9 and Reader 9.
Setup is as follow:
Servers
1 - Apple Xserve G5 10.5.6 Server - Open Directory Authentication
1 - Apple Xserve G5 10.5.6 Server- Home Folder Share via AFP
Clients tested
1 - eMac G4 1.42 GHz 10.5.6
1 - PowerMac G5 2 GHz 10.5.6
1 - iMac Intel 2 GHz 10.5.6
Upon Login to a Network Home the following occurs if I try to open a PDF or open Acrobat/Reader 9
The PDF will open and the program will lock up
If I try to open the Application without a PDF it will lock up almost immediately
After a little trial and error I think I've isolated the problem file being
~/Library/Application Support/Adobe/Acrobat/9.0_x86 (9.0_ppc)/AdobeCMapFnt09.lst
I moved all files in
~/Library/Application Support/Adobe/Acrobat/9.0_x86/ to
/Users/Shared/ and then aliased them back to
then relaunched Acrobat
Acrobat will launch and you can click through the menus but the moment you try to open something it will lock up again.
Interestingly, the AdobeCMapFnt09.lst file doesn't populate properly on a network account when you open it via TextEdit vs. if you open this file in TextEdit from a Mobile or local account.
Hope this helps someone find a solution to this issue plaguing all the network admins out there.
(thomas_mostert) User 2 posts since
Feb 20, 2009
33. Feb 20, 2009 5:47 AM in response to: (msingerman)
Hi
I also have the exact same error. When I spoke to a techie they said that they are aware that windows has the problem and it would be fixed as soon as they release the update. They could also not inform me as to when the update would be released.
Has anyone in the meantime found a fix to the problem.
User 2 posts since
Feb 12, 2009
34. Feb 20, 2009 9:02 AM in response to: (msingerman)
I found a solution to this issue for Network Users running 10.5.6
1. Log in as a Network User
2. Go to /Users/Shared/
3. If you are on an Intel based Mac create a folder in /Users/Shared/ named 9.0_x86 if you are on a Mac that is a G5/G4 create a folder named 9.0_ppc
At this point you should have created either
/Users/Shared/9.0_x86/
/Users/Shared/9.0_ppc/
4. Go to ~/Library/Application Support/Adobe/Acrobat/ and trash the 9.0_x86 or 9.0_ppc folder contained within
5. Go to Applications/Utilities/ and open Terminal
6. Enter one of the following into the Terminal
If you are on an Intel based Mac enter
ln -s /Users/Shared/9.0_x86 ~/Library/Application\ Support/Adobe/Acrobat
If you are on a G5/G4 Mac enter
ln -s /Users/Shared/9.0_ppc ~/Library/Application\ Support/Adobe/Acrobat
7. Open up Acrobat 9 and it should work!
What this does is create a symbolic link on the network location to the folder we created in the Shared which resides on the hard disk so the Organizer90 file doesn't stall during creation.
This also fixes Reader 9.0
(Orlando_Petrini) User 2 posts since
Dec 8, 2003
35. Feb 22, 2009 12:08 PM in response to: (msingerman)
I had the same problems as all you folks. Jason's solution works well with me. Amazing tht the Adobe folks were not able to give me the solution - this is a serious bug Adobe is carrying over since Acrobat 7 - previous versions did just not open the Organizer, but at least they did not crash.
I start having doubts about Adobe taking bugs very seriously... In any case, thanks to Jason.
Dec 8, 2003
36. Feb 23, 2009 12:09 PM in response to: (msingerman)
You'll find the solution at
http://www.adobeforums.com/webx/.59b660c2/34?@@
At least, it worked flawlessly for me.
User 1 posts since
Feb 25, 2009
37. Feb 25, 2009 4:59 AM in response to: (msingerman)
I have 800+ Design-Students on 100+ Intel and PPC-Networked Mac's.
I can not tell them all to do this stuff every Time they log in and want to use Acrobat 9.
Does anyone have an Idea how to make it work for all ??
Thanks, Achim
User 7 posts since
Aug 11, 2002
38. Feb 25, 2009 1:21 PM in response to: (msingerman)
Achim, how are your user accounts managed (AD, OD)? I'm thinking you could use ARD to push out the folders into the Shared User on all the machines. You could either do it in two batches, one for Intel and one for PPC or send both folders to all machines.
The second part is the tricky part. Could you add a login script to each user that creates the symbolic link when they log into a machine? The issue then would be separating the users by machine type and creating different scripts.
This assumes that you have no classrooms with a mix of PPC and Intel boxes.
Hope this has been of some help.
I am currently telling all of my corporate clients not to buy Acrobat 9 until this issue is resolved by Adobe.
User 1 posts since
Mar 4, 2009
39. Mar 4, 2009 3:50 PM in response to: (msingerman)
This workaround still failed for me. I'm part of the support team at a school.
With Open Directory services / mounted NFS shares for home directory, Adobe Acrobat Pro 9 has yet to open. OSX 10.5.6, Intel Imac.
However, Acrobat Reader in the same version has no issue. As always, local user has no problems. The last output before every crash is:
3/3/09 12:33:27 PM authexec[1565] executing /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat
Pro.app/Contents/Frameworks/AdobeSelfHealing.framework/Resources/MoverTool
3/3/09 12:33:27 PM [0x0-0x7b07b].com.adobe.Acrobat.Pro[1561] terminate
called without an active exception
Acrobat 8 Pro reveals no such issue. Same machine, same network user, different OS partition...
User 2 posts since
Mar 4, 2009
40. Mar 4, 2009 6:15 PM in response to: (msingerman)
Heya everyone, i had the same issue with network home directories with hundreds of users, and i i had to get them up pretty quick smart, here is how i did it, it gets around the launch issue and also the authenticate issue most of the time as long as you have launched both programs as the default admin user on your gold image.....
in short I already have Network Home Redirection running to reduce the load on the servers for things like office and cache files... so basically I added a redirect for the appropriate application support for acrobat as well... but here is step buy step from scratch..
firstly install NHR on your main gold image - http://www.jochsner.dyndns.org/scripts/NHR.html
then log in as root and navigate to /etc/hooks
Open LIclean.hook with Xcode or something similar and modify the script in the following places....
#This section will delete the Fonts etc....
Add line
'i' rm -rf "$home_loc"/Library/Application\ Support/Adobe/Acrobat/9.0_x86
#This will copy several Microsoft folders of the local admin user.... etc
add line
'i' cp -R /Users/$LocalAdminUser/Library/Application\ Support/Adobe/Acrobat /tmp/$1/Adobe/
#This last section will set up symbolic links for the current user.....
Add lines
'i' ln -s /tmp/$1/Adobe/9.0_x86 "$home_loc"/Library/Application\ Support/Adobe/Acrobat/
'i' ln -s /tmp/$1/Adobe/9.0 "$home_loc"/Library/Application\ Support/Adobe/Acrobat/
and this should sort the issue out.... basically you are simply copying the default admin app support for acrobat to a tmp directory and then creating a symbolic link, but this is happening as a login that runs when a network user logs in.
Most important thing is that the main admin user (UID 501) has launched these apps so that the application support files are there.... otherwise this will not work...
If you get really stuck then i guess you can email me and i will try to help seeing as support is not playing ball and it is start of semester....
Rene
User 2 posts since
Mar 4, 2009
41. Mar 6, 2009 5:21 PM in response to: (msingerman)
Just noticed a slight typo in these, none of the lines should have 'i' at the beginning - not sure where they came from, and there should also be a a line
if you are running ppc machines
so to be nice and clear for Intel machines do the following
Add line
add line
Add lines
for PPC machines do the following
Add line
add line
Add lines
User 7 posts since
Aug 11, 2002
42. Mar 11, 2009 10:00 AM in response to: (msingerman)
Has anyone had a chance to test with the new Acrobat 9.1 patch?
Tom
User 2 posts since
Jan 28, 2009
43. Mar 12, 2009 1:34 AM in response to: (msingerman)
Yes, I installed Acrobat 9.1 yesterday on our Test-Network-Mac and it doesnt work.
User 4 posts since
Mar 26, 2009
44. Mar 26, 2009 2:05 AM in response to: (msingerman)
Sam problem here Is there another patch for this comming out soon? ________________________________________________________________
movie phim online media... music nhac online the world of wholesale fashion and models wholesale clothing and lovely phim han quoc film..?!!
User 3 posts since
Mar 27, 2009
45. Mar 27, 2009 2:49 AM in response to: (msingerman)
confirmed 9.1 push didn't fix the problem. wondering if we plan any near future patch for this? thanks in advance.
movie phim media music nhac online sound model of wholesale fashion and lovely korean phim han quoc film movie
GFLORO User 6 posts since
Apr 9, 2009
46. Apr 9, 2009 7:41 AM in response to: (Jason_Eng)
Jason
Thanks for the tip. It's working for us as a temporary fix. Thankfully, not too many copies of Acrobat 9 deployed yet, and they are all on the same platform [PowerPC].
gregory
SteveTN User 1 posts since
Apr 14, 2009
47. Apr 14, 2009 2:27 PM in response to: GFLORO
I have the same problem as everyone here. In addition to Acrobat 9 problems, Illustrator just bounces in the dock and updates fail. All other apps work fine as a network user. If I switch over to a local accout, all work with no problems.
Fred_beauxarts User 1 posts since
Apr 15, 2009
48. Apr 15, 2009 7:19 AM in response to: (msingerman)
Hi, I had the same issue with acrobat Pro and Reader 9 and network
accounts. I followed the solution of Rene with NRH and i added few
lines in the file "LIclean.hook" to resolve the crash.
Open LIclean.hook with vim for example:
Add lines:
# acrobat Pro and reader 9 crashes
cp -f /Users/$LocalAdminUser/Library/Preferences/com.adobe.
118.registration "$home_loc"/Library/Preferences
cp -f /Users/$LocalAdminUser/Library/Preferences/com.adobe.acrobat.
90.sh.plist "$home_loc"/Library/Preferences
com.adobe.Acrobat.Pro_x86_9.0.plist "$home_loc"/Library/Preferences
com.adobe.Reader_x86_9.0.plist "$home_loc"/Library/Preferences
launched these apps and so that files are there.... otherwise this
will not work... and be sure, when you launch acrobat pro or Reader
with the main admin user, that the registration's window doesn't
appear.
Fred
neidadddda User 1 posts since
May 15, 2009
49. May 15, 2009 6:30 AM in response to: (msingerman)
We have the same problems. Adobe told us in polite terms to f.off.
Illustrator problems aswell. (make a script that copies the preference files to the users library/preferences/Adobe Illustrator CS4 Settings) This solves the problem. Illustrator manages to create the folder, but not the files within (way to go adobe)
We are in the process of relocating and are contemplating to stop teaching adobe software. Issues like this does not further adobes cause.
