How to call "Optimize Scanned PDF" menu item from IAC
Feb 9, 2009 3:27 AM
Hi all,
i would like to know what how to call "Optimize Scanned PDF" menu item from IAC.
i successfully called "Reduce File Size" menu but the file size reduced is not small enough.
i have tried optimize it using "Optimize Scanned PDF" and it works.
I need this so that my VB.net program can invoke this menu and reduce the file size.
thanks.
Best Regards,
Mok
    Feb 9, 2009 5:20 AM   in reply to (mokkimhong)
    Try the PDF Optimizer feature instead!
    Feb 9, 2009 6:50 PM   in reply to (mokkimhong)
    You didn't mention that - PDF Optimizer is only in Professional. In that case, you are indeed limited to the features that you've mentioned.
    Were Professional present, you would also have the full capabilities of Batch processing and Preflight to reduce the file size of a PDF.
