This is a problem only for x64 platforms… in the same machine I have 2 drives with exactly the same configuration except that one drive runs Windows 7 x32 and the other Windows 7 x64. The preview handler of adobe does not work only when I run Windows 7 x64!
As I see this problem is around for years with vista x64 and adobe has done absolutely nothing. And won't do for the years to come. For some reason adobe does not like much x64 platforms. With the recent exception of photoshop no other product of adobe has a x64 flavor…
I am having a similiar problem with Vista x32. The preview handler is able to display the pdf, but the fields that were filled in prior to the email are not showing any values, but when you open the pdf with reader the values are there. Below is a more detail account of what is happening. I have contacted the third party dll as well, but thought someone here might have an idea too.
I have a client that is using the a thrid party PDF dll (Syncfusion) to generate and email PDFs reports. There seems to be an issue with the PDFs that are generated and using the built-in PDF Preview Handler for Vista. The scenario is ...
1. User receives an email into Outlook that contains a generated PDF (see image ''01-Opening-Email.jpg'')
2. User clicks on the attachment in Outlook and the preview handler starts up (see image ''02-Loading-Previewer.jpg'')
3. The PDF displayed in the preview handler does not have any of the fields filled out (see image ''03-Report-Loaded-In-Viewer.jpg'')
4. User then right clicks on the PDF (in outlook) and selects to open the PDF with Adobe Acrobat Version 9.0 and the report is displayed with all the fields filled out (see image ''04-Report-Opened-With-Adobe.jpg'')
All of these images are included in the attachment that I have uploaded with this incident. As well, in the RAR file is the PDF that was sent by the system using the PDF dll from Syncfusion. Please let me know if you need any more information from me.
I looked into this today and discovered a simple fix for the problem:
http://www.pretentiousname.com/adobe_pdf_x64_fix/index.html
I built a workaround into my own software which uses the Adobe PDF preview handler but you can make a simple registry change to fix the problem in Outlook and Explorer as well.
I thought I'd share it with everyone as it doesn't look like Adobe are going to fix it themselves.
Only thing I know that will view Office 2003 files in Windows Explorer is Office 2007 (or 2010 presumably).
There are alternative file managers which can view Office 2003 files using earlier versions of MS Office, or OpenOffice (free) or things like QuickViewPlus. Even there, though, if you want top-notch Office document previewing then Office 2007 is the best because it is the first version of Office to come with proper file viewing components for other tools to plug-in.
I am running Windows XP 32-bit with Office 2007 and had been able to preview PDF's without a problem until recently when it began displaying an error (detailed in previous posts).
I was able to resolve the problem by running Microsoft Office Diagnostics.
From within Outlook, click Help/Office Diagnostics
This ran for about 10 minutes and although it stated that it did not detect any problems, I am now able to preview PDF's once again.
Good luck.
I have given up on this problem. I have tried all the suggestions offered to fix the preview problem, and have emailed Adobe several times. I've returned to using "Thumbs Plus" a wonderful program (by Cerious Software). My pdf thumbnails display beautifully in this program, and it shows your thumbnails MUCH faster than Explorer. Debbie Knight
please visite this site it works fine for me "vista 64x"
I used the same fix as Leo on Outlook 2007 and Windows 7 64 bit and it worked - I did the manual regedit with no issue. Just waited a few minutes then went to different email with pdf attached and preview worked just like it used to before the windows upgrade
Mike
Thanks Leo! Your solution at:
...Worked on both Win 7 x64 machines we tried it on here.
How on earth do you know where to find these things in the registry? You should be called Neo rather than Leo!
Thanks again for the fix.
