Home/Support/
Forums
1744 Views 8 Replies Latest reply: Nov 8, 2008 6:01 PM by (TS_Berry) RSS
Calculating status... 4 posts since
May 23, 2008
May 23, 2008 11:22 AM
Vista x64 Acrobat window won't maximize or restore properly
I have tried a couple times to run Windows Vista Ultimate x64, but there have been enough problems that I've decided to go back to 32-bit. One of these problems is with Acrobat 8.1.2 Pro.
Whenever I open a PDF in Acrobat, if the window opens fully maximized and I try to restore it to a smaller window, the PDF document does not resize accordingly. It is still zoomed in to the same size as when it was maximized and as a result, I can't see the scroll bar because it's off the window. If I open the PDF in a window that is a smaller restored window and then maximize it, the PDF document again does not resize and remains the same small size that it was in the restored window with the scroll bar in the middle of the now maximized window with just a bunch of useless gray area where the document should have expanded to. The same problem occurs when the window is manually resized as well.
The only workaround I've found is to close the document and reopen it so that the window starts off either maximized, restored, or the new size that you changed it to. This is a real pain, especially when you're in the middle of doing something in the middle of the document.
