I've got 9.4, and I too am having the crash to desktop problem when trying to OCR the pages, and usually with amounts of 50 or more pages, and randomly. Very frustrating due to the amount of time involved in scanning, waiting for the program to OCR, and then seeing that dreaded error screen, with no apparent explanation. Not every time though, praise the Lord. So far I have not seen anyone answer this problem decisively in this thread. Does anyone know a cecisive answer? Thanks, Bill W.
I have not seen the problem with AA 9.4. What you might try is OCR on a portion of the document. Save that result and then try the next part of the document. The key may be so many pages. It used to be that Acrobat had a 50 page limit, but that is gone. Still it might be a size issue. You could also try clearing your TEMP folder and see if that helps.
With all such experiments, do work on a copy.
MacBook Pro (1997)
- Mac OS X 10.7.2
- 2.6GHz Core 2 Duo
- 4GB RAM
Acrobat 9 Pro
- version 9.4.6
Acrobat 9 Pro OCR always crashes when using ClearScan but not when using "Searchable Image" or "Searchable Image (Exact)." I scanned several journal pages at 300 dpi (color, grayscale, bitmap) in .tiff and .png as well as screen selecting text from a browser. The results were consistent across all variations.
The last time I used the Acrobat's OCR function was last Summer before upgrading from Snow Leopard to Lion. Under Snow Leopard, Acrobat did not crash during OCR (it did crash, just not while processing text for OCR). I did not attempt Acrobat OCR under Lion 10.7 or 10.7.1.
Repeatable test.
1. Open wikipedia "Crash (Computing)" page
http://en.wikipedia.org/wiki/Crash_(computing)
2. Enlarge text size, if desired.
I tried several text sizes from the default to much, much larger. Text size has no impact on the results.
3. Create a PDF
File >> Create PDF >> From Selection Capture
I selected the first paragraph:
A crash (or system crash) in computing is a condition where a computer or a program, either an application or part of the operating system, ceases to function properly, often exiting after encountering errors. Often the offending program may appear to freeze or hang until a crash reporting service documents details of the crash. If the program is a critical part of the operating system kernel, the entire computer may crash. This is different from a hang or freeze where the application or OS continues to run without obvious response to input.
4. OCR
Document >> OCR Text Recognition >> Recognize Text Using OCR
4.1 Searchable Image (Exact)
Primary OCR Language: English (US)
PDF Output Style: Searchable Image (Exact)
Downsample: None
Result: No crash — OCR successful
4.2 Searchable Image (tested for each downsample option)
- Downsample: Lowest (600 dpi)
- Downsample: Low (300 dpi)
- Downsample: Medium (150 dpi)
- Downsample: High (72 dpi)
4.3 ClearScan (tested for each downsample option)
PDF Output Style: ClearScan
Result: Crash — OCR not successful
I'm having Acrobat 9.5.0.270 crashes on some pdfs, when using batch processing, fast web view feature, with OCR and PDF optimizer, monochrome images were set to JBig2 lossless.
Faulting application name: Acrobat.exe, version: 9.5.0.270, time stamp: 0x4f03f71d
Faulting module name: OCRLibraryInf.dll, version: 9.5.0.270, time stamp: 0x4f03e982
Exception code: 0xc0000094
Fault offset: 0x00093aeb
Faulting process id: 0x14fc
Faulting application start time: 0x01cd02e462799896
Faulting application path: C:\Program Files (x86)\Adobe\Acrobat 9.0\Acrobat\Acrobat.exe
Faulting module path: C:\Program Files (x86)\Adobe\Acrobat 9.0\Acrobat\plug_ins\PaperCapture\OCRLibraryInf.dll
Report Id: 0dbea415-6f62-11e1-a8e9-005056ba0009
