Howdy.
Thanks for this solution, it worked for me. I too just switched to Vista x64 and have the issue where my scans were not previewing and only showing the red Acrobat icon. I opened the reader, chose File Open and pointed it to my folder of PDFs and chose Views/Large Icons and it created thumbnails that were available to Windows Explorer. Thanks, this was, like the other folks, really bothering me!
--dave
There is a fix for it :
http://www.pretentiousname.com/adobe_pdf_x64_fix/index.html
It will fix both the preview of icon is not showing and the preview of the content of the document is not showing
The installer and executables are digitally signed. Thanks to GPSoftware for signing them for me.
You'll need to re-run the preview-handler fixer each time you update Adobe Reader. A start menu shortcut is provided.
I am having the opposite problem, so I am hoping that the solution to yours might also entail a solution to mine. I just installed Adobe Reader 9 on Windows 7 Professional (32 bit), and now my pdf icons show up as previews. It's a nifty feature, but I'd prefer to turn it off. Does anybody know if there is a way I can get Adobe Reader 9 to use a fixed icon rather than a preview? Thanks.
Download the fixes:
- With installer: Adobe_Reader_x64_fixes_v2_002_installer.zip (1MB)
- Without installer: Adobe_Reader_x64_fixes_v2_002_noinstaller.zip (1MB)
Well yeah this is it! This fixed it for me. ![]()
It's too bad Adobe doesn't take care of these bugs that they create. ![]()
Did you ever find an answer for this??? I am sure you have since your post is rather old but just in case someone else gets here and needs it. I had the same issue and was searching for an answer. I saw this and since I fixed mine I thought I would tell you what I did.
Opened Windows Explorer -> Tools -> Folder Options
Go to the View tab
Check "Always show icons, never thumbnails"
Hit Apply
All your PDF files on your desktop should now show with the generic PDF icon.
Reverse this to get the preview icon "thumbnails".
I am using Adobe Acrobat X Pro on Windows 7, 64 Ultimate. I generate the thumbnails by opening the first one and then save as PDF in the directory. This will generate the correct thumbnails. I also browse through several directories, whilst the save as is open. So, now I have all thumbnails, showing the first page of the documents.
After about a week, or sometimes more, all thumbnails turn back into generic pdf's. I use the same procedure again, to regenerate all thumbnails. I have done this now for the past few months and is driving me nuts. I have no idea as to why and when they will turn back to generic ones. I has happened again today. Nothing downloaded, nothing installed
