Feb 20, 2009 3:13 AM
Camera Raw 5.3 insufficient memory
Like (0)
Two points..............
1. It has only just dawned on me that the OP wrote about problems he was having with 5.3. At the time, I had 5.2 installed and, at Adriana's prompting, I installed 5.3 beta (and subsequently 5.3 release) and all my problems with memory leakage were solved. So, for the record, I never had problems with 5.3. Quite the contrary.
2. A couple of weeks back, I installed 5.4 beta and my problems returned to some extent - though not quite as bad. While 5.2 was unworkable - I kept getting the memory error message with even one or two Hasselblad files open in ACR - 5.4 beta only allows me to save three or four Hassie files at a time. I then have to go back to Bridge and open the next three or four.
However, I am also getting a new error message. In the main Bridge window, while dealing with Hassie files (not Canon) I am getting a "Bridge will soon run out of memory. It is suggested that you restart the program." error message. (This didn't even occur with the dreaded 5.2!) I know when this is about to happen because when I highlight a few images to open them in ACR, a scroll bar appears before they open. Bad sign! ;-)
I've just noticed that 5.4 full release is now available. I'm currently downloading and installing it, so I'll see how it goes.I hope that it's as good as 5.3.
How are others faring? Any memory problems?
I'm Vista x64 with 8Gb RAM.
Where, precisely, are Bridge's and ACR's memory allocations set? In PS/CS4's preferences?
In Bridge, under Edit/Camara Raw Preferences, what do others have the Camera Raw Cache size set to? I have it set to 10Gb. I have a very fast, internal 50Gb HD that I use exclusively as a scratch disk for PS. It is also the location for ACR's cache and Bridge's cache - currently only 140Mb of this disk are in use. So, there really shouldn't be any issues.
In Bridge, under Edit/Preferences/Cache, I have the cache size set half way between 10,000 and 500,000.
Finally, in PS, I have memory set to 70% and the 50Gb D: drive set as my number 1 Scratch Disk with my C: drive set as number 2.
Would appreciate any feedback.
D.
Even though you are using Vista 64 with 8 gigs, I'm not sure that it's advisable to set Photoshop's allocation to 70%. Since Camera Raw get's it's member either from Photoshop (when hosted by Photoshop) or Bridge you can't control Camera Raw's allocation at all. I also think Bridge is still a 32 bit app so that's one reason for the ram starvation. Try the Photoshop allocation at the Windows default of 50% and make sure you open the raw files via the 64 bit Photoshop (with the 64 bit version of Camera Raw) not in Bridge (which would be forced to use the 32 bit version of Camera Raw).
Jeff,
Many, many thanks for taking the time to reply directly. Very much
appreciated.
I never knew that Bridge CS4 was still only 32 bit. Opening in ACR via PS is
a neat suggestion and I will certainly give it a try.
My problem is only with my Hasselblad TIFFs (processed from 220Mb/4 shot
multi-shots, so they have to be TIFFs by the time ACR sees them), so I
assume that in PS choosing File/Open and selecting 'Camera Raw' from the
Files of Type menu in the dialogue is the only way to do this? If so, it's a
bit more longwinded than via Bridge.
With Adrian's help, 5.3 had solved the problem and I had considered
reverting back to it, but I'll try your workaround first.
Thanks again.
Denis Mortell
Ps. By sheer concidence, I bought both 'Real World Camer Raw' (first
impressions, marvellous!) and 'CS4 The Ultimate Workshop' (first
impressions, seriously high fibre, but I'm going to stick it out!) this
week. Love the Hands/Globe shot!
D.
Dinarius wrote:
so I assume that in PS choosing File/Open and selecting 'Camera Raw' from the Files of Type menu in the dialogue is the only way to do this? If so, it's a bit more longwinded than via Bridge.
No, as long as you Control "O" instead of Control "R" you should be able to open in the 64 bit version of Photoshop, if it is already running. If you use Control "R" you will always only be hosting Camera Raw in Bridge...
Thanks for the kind words...impressive considering it was done with Photoshop 2.5 huh?
Will PS automatically recognize the tiff as raw in this situation or do you also have to set your Camera Raw preferences appropriately in PS to have it open in ACR?
-X
Forgive my ignorance, but I'm still a wee bit confused.
Firstly, I should have written in my last post (which I can't edit for some reason, though I can edit all my other posts) that, with PS open, I can open a TIFF in ACR by choosing File/Open As (not File/Open, as I wrote above) choosing 'Camera Raw' from the Files of type menu and then highligting the file and choosing open. All very well and all as described here> http://kb2.adobe.com/cps/404/kb404656.html
However, oddly, unlike when I choose File/Open, the File/Open As option does not appear to allow me to choose a bunch of files from the folder (via Ctrl and clicking on each in turn) and then open them in ACR - only one at a time. Since I use ACR via Bridge for applying general changes to an entire folder of TIFFs (after they have been processed in Flexcolor), being able to open more than one at a time is crucial for me.
Please tell me I'm doing something wrong. Otherwise, I'm going back to 5.3.
Thanks.
D.
Edited:
Sorted!
I've left my post above un-edited in case it might be of help to those who were having the same problem. But, here is the solution.............
1. In PS, under Edit/Preferences/Camera Raw, under Jpeg and TIFF handling, 'Automatically open all supported Jpegs/TIFFs' *must* be selected in the drop down menus, not 'Automaticall open Jpegs/TIFFs with settings', which is what was selected on my computer (is that the default setting?).
2. Now when I choose File/Open (not File/Open as) and then 'Camera Raw' from the 'Files of type' drop down menu (leaving All Formats selected does not make ACR an option when you click on a file and choose 'Open with ...') I can Ctrl/click on a bunch of images and they will all open in ACR.
I just tried this on a folder of 14 220Mb files followed by a folder of 18 220Mb files. I made a change to them in ACR and then saved them. It ran through them like a train! If I had tried this via Bridge, it would have choked on any more than four or five files.
One very happy camper! ;-) I'm now getting full use of my x64bit/8Gb setup. Thanks to Jeff for bringing this neat work around to my attention.
Two further points:
1. In PS, after choosing File/Open, with 'All formats' selected, it would be nice to have ACR as a choice under 'Open with....' rather than having to select Camera Raw in 'Files of type'. Is it possible to edit the selection of programs offered in the 'Open with...' menu and add ACR?
2. When opening a large number of large files in ACR, the yellow triangle with the exclamation point appears over each file and disappears as each file is cached(?). The only way of knowing if the files further down the list have settled is by either scrolling down through them, or checking to see if the green light on the front of the computer tower has stopped flickering. It would be nice if ACR had something on screen (similar to the rotating circle that appears in PS when you are saving changes to a file) to indicate that it has done its thing.
D.
Dinarius wrote:
…my last post (which I can't edit for some reason, though I can edit all my other posts)
You can edit any post of yours to which no one has replied. Once someone has replied to a post, you can't edit that particular post of yours.
Since the work around to the memory problem is a little long winded (hosting ACR via PS) I have two more questions:
1. Do Adobe intend to make Bridge 64bit?
2. I've never used Lightroom, but I note that it's 64bit. I presume that it's a standalone program and not 'hosted' by either Bridge or PS. So, would anyone recommend that as the solution? Does it have everything that ACR has?
Thanks.
D.
Dinarius,
You're certain to find more Lightroom fans in the Lightroom forum.
(Just a thought, since I see no point in explaining whay I decided not to use Lightroom as I'm perfectly happy with Bridge, ACR and Photoshop.)
Copyright © 2011 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
