Create PDF from database, Edit PDF and save back to database
Aug 9, 2007 8:41 AM
Is there a tool out there where I can update a pdf created from a database online and save the changes back to the database?
    Jan 5, 2008 6:05 AM   in reply to (sgt13echo)
    I also have the same problem, ACCESS may be, but I have not used. If there are good ways to help me. Thanks.
    other some help here, http://livedocs.adobe.com/livecycle/es/sdk help /programmer/sdkHelp/wwhelp/ price /common/html/wwhelp.htm?context=sdkHelp&file=assemblePDFIntroduction.9 3.1.html
    This site may have some help.
    Apr 26, 2008 4:59 AM   in reply to (sgt13echo)
    In this case i don't think I can help you much...still you can go through this site for a better result:
    www.nativewinds.montana.com/software/tomahawk.html
    www.planetpdf.com/forumarchive/68110.asp
    Martin Fowl
    | inkjet
    cartridge
    | data recovery
    | data recovery |
    Apr 30, 2008 9:25 AM   in reply to (sgt13echo)
    sorry I have the same problem. I am really looking for a solution for this.
    Martin Fowl
    | inkjet
    cartridge
    | data recovery
    | data recovery |
    May 10, 2008 11:12 PM   in reply to (sgt13echo)
    I have searched all over the internet but i cant seem to find a solution to setting my documents to expire after 3 months. Now am thinking of implementing javascript but i ran into one hurdle: the script is dependent on the system clock so if one sets the clock to an earlier date/time, the document will open.
    Is it possible to implement this sort of security via javascript? If so, how can i also disable interactivity on my documents since most of them are learning materials in latex and implemented using Acrotex bundle?
    __________________________________________________
    http://www.dogbreedss.org/puppy-names.htm
    Jul 31, 2008 10:01 PM   in reply to (sgt13echo)
    Hi
    Here is a tool that meets your requirement. It only reads data from the Excel file or database(any kind) and stores it in a PDF document..
    have a look at it. Follow the link bellow.
    http://www.convert-in.com/data2pdf.htm
    Hope this helps.
    cheers.
    Aug 4, 2008 6:35 PM   in reply to (sgt13echo)
    http://www.dogbreedss.org/dog-diseases.htm
    Data-to-PDF
    Data-to-PDF is a program to convert any kind of relational data (that could be represented as a table) into Adobe PDF format.
    Features
    Converts MS Excel spreadsheets to PDF
    Converts MS SQL tables to PDF
    Converts MS Access tables to PDF
    Converts MySQL tables to PDF
    Converts relational data from text file to a table and then into PDF format
    Converts XML file to a table and then to PDF
    Converts whole database (SQL Server / MS Access / MySQL) with number of tables to one PDF document with multiple pages
    Converts a text file to PDF as it is
    Allows user to create new grid of data and to convert that into PDF format
    Common editing, finding & replacing options for data grid
    Query Builder tool to create and execute queries rapidly against data grid
    Easy to use wizard-style interface for most of the operations
    ___________________
    dog disease
    Feb 2, 2009 6:51 AM   in reply to (sgt13echo)
    Yeah! I finded it h e l l o
    Feb 11, 2009 7:11 AM   in reply to (sgt13echo)
    We have a problem converting a document from Microsoft Access to PDF,
    we lost all the original colors from the access table and the document
    shows up gray scale (black and white)in the pdf when converted.
    This problem is recent before we no have any problem with the conversions of the same document.
    Any of the adobe setings has been changed, this just start happens after feb 5
    If any one have any sugestions?
    Joe
    Feb 17, 2009 5:51 AM   in reply to (sgt13echo)
    I'll check it out!
    gold teeth
