FrameMaker 8 crashing constantly
Nov 9, 2007 10:42 AM
Been running FM v8 (unstructured interface) for a couple of weeks now (Windows XP), and it crashes at least 2 times every day. I can produce PDFs fine (with the highly publicized "fix"), but I'm getting all kinds of mysterious memory-related error messages. It seems to happen on Paste operations fairly often, and it seems to happen most often when I'm working in graphic frames. Not seeing much in the forums about FM8 blowing up, and I can't make heads or tails out of the error logs that FM is generating. Any ideas would be greatly appreciated. FM8 is now costing me time and trouble, and I'm not impressed.
Replies 1 2 Previous Next
    Nov 9, 2007 11:09 AM   in reply to (Larry_Carey)
    What are the system specs?
    Art
    Nov 9, 2007 11:22 AM   in reply to (Larry_Carey)
    Can you supply the exact text of the memory-related error messages.
    How much actual RAM and free disk space do you have? If you're pasting
    graphics, then FM needs lots of space in its TEMP area in order to
    create the working files (a jpg can expand drastically - FM needs to
    work with the expanded graphic to display it).
    Have checked through Adobe's FM general troubleshooting technote
    (http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=331964) for
    some possible scenarios?
    Nov 9, 2007 11:39 AM   in reply to (Larry_Carey)
    Larry,
    I think your RAM, or lack of it may be the (or part of the) problem....
    especially if you are running any other applications with FM.
    For example, several of our systems that only had 1 or 2 G were crashing or locking up if we ran Photoshop or Illustrator at the same time as FM (7). Problems have gone away entirely and performance is much improved with 4G on board.
    Art
    Nov 10, 2007 12:47 AM   in reply to (Larry_Carey)
    On Fri, 9 Nov 2007 11:30:28 -0800, Larry_Carey@adobeforums.com wrote:
    >I must ask - is there any reason that the Operating System is listed in the error log as "Windows NT 5.1", when I am in fact running XP? I just noticed it this minute, and it seems odd.
    Windows NT 5.1 is the internal identification of Windows XP. "XP" is
    just the public marketing name. Likewise, Windows 2000 is actually NT
    5.0 and Windows Vista is actually NT 6.0. This Wikipedia page lists
    all NT version codes and their corresponding marketing names:
    http://en.wikipedia.org/wiki/Windows_NT
    http://www.kynosarges.de
    Nov 12, 2007 7:54 AM   in reply to (Larry_Carey)
    Larry,
    What has Adobe Support had to say?
    And, just in passing, RAM is about $100 a Gig now, unless you have a really exotic configuration. About the cheapest upgrade you could do and it would eliminate that as a consideration....
    Cheers,
    Art
    Nov 12, 2007 7:59 AM   in reply to (Larry_Carey)
    This may not help but I'll throw it out there anyway. I was running FM8 under Vista and had problems when I held down my mouse button too long. FM8 froze and I often lost data. I called Adobe and they asked if I had used AutoPlay when I loaded the app. Told them I had. They suggested uninstalling it and then reinstall through Windows Explorer by opening the CD's Framemaker8 folder, right-clicking on the Setup icon, and selecting Run as Administrator. Supposedly it fixes several problems. It didn't seem to fix mine but it may be worth a try. I did not have to reactivate the software when I did that. Also, did you contact Adobe and provide the error message numbers to them. They were very helpful when I called, as well they should be.
    Nov 12, 2007 1:39 PM   in reply to (Larry_Carey)
    Larry, you mentioned using graphics as being when the crashes seem to occur, and you also mentioned it happening on pasting.
    Could you tell us what type of graphic files you're using? What is the source application that you're pasting from? How many graphics do you have in an average FM file?
    Also have you experimented with using referenced graphics rather than copied (pasted) in? Several advantages for referenced graphics: 1) makes your FM files much, much smaller, 2) removes significant amounts of re-work when graphics are updated, 3) makes the files more portable, 4) uses much less memory -- some graphics formats expand the FM file size dramatically when pasted into FM, often several times the graphic's actual file size on disk.
    I have to say I agree with the other folks that 1gig of RAM is more than likely your culprit; years ago I experienced instabilities in FM that were resolved once I got more RAM.
    Nov 12, 2007 11:26 PM   in reply to jackgm1
    Interesting. I did have several FM8 freezes under Vista as well but
    couldn't identify a cause. Depending on how long Larry Carey keeps FM
    running each day those hang-ups might well add up to twice per day.
    Personally I didn't think it was a big deal, though -- Windows can
    still identify and close the hung program, and I never had any data
    corruption in my work files.
    For the record, my system is 64-bit Vista with 4 GB and I'm running as
    administrator. No offence to Art Campbell, but it seems very unlikely
    that FM8 would require 4 GB to run stably; and on my system, it
    doesn't. It's more likely that his Photoshop and Illustrator
    processes were gobbling up memory and causing instability.
    Nov 13, 2007 7:45 AM   in reply to (Larry_Carey)
    No offense taken, but you're kinda misquoting me. What I said was the same thing you said -- if other memory hogs (PS; Illustrator) are running at the same time as FM, then FM ends up without enough RAM, especially if it is also trying to process graphics.
    Instability is a whole other issue, but either way the only practical way to compensate is by adding more RAM.
    Art
    Nov 16, 2007 8:51 AM   in reply to (Larry_Carey)
    I have had the same problem (have had over 60 crashes in two weeks) running Frame 8 on Vista and XP systems - both new, stout systems.
    The last four crashes happened within 1.5 hours and included the same INternal Error codes:
    11/8 6:48 PM
    === Header Begin ===
    Internal Error: 8004, 6952719, 4841390, 4841118
    FrameMaker 8.0.0 for Intel
    Build: 8.0p236
    Window System: MSWindows
    Operating System: Windows NT 5.1 (major.minor.build: 5.1.2600 Service Pack 2)
    Generated on: Thursday, November 08, 2007 6:48:23 PM
    To file: c:\program files\adobe\framemaker8\FrameLog_07.11.08_18.48.23.txt
    === Header End ===
    I was creating new templates and imported some formats from some I had created with FM 5.5/6.0. Adobe mentioned the templates may be corrupt (I've never had a problem before with them), so I created them again from scratch. Did not matter, crashes still occurring.
    I noticed several things that may be a symptom or bug(?).
    - The Color Definitions seem to expand from the several default definitions to maybe somewhere over 200 (Definitions named RGB XXXXXXXXX). And you cannot delete them.
    - Table formats (specifically Double line for table header does not continue on the next page) inconsistently applied.
    - Cannot print any Frame or PDF documents - both immediately crash. I can create PDFs from Frame using "Save As."
    - Could not revert back to an editable document per instructions after creating a review only document.
    I scoured the forums when the problems started occurring and did not find any related info until today - so I am not alone!! I copied the crash logs and sent them to Adobe to reopen the ticket last Friday(?) and have not heard from them.
    And I thought I was finally rid of the exacerbation of crashes and corrupt docs replacing Word as our main tool!
    Nov 16, 2007 9:32 AM   in reply to (Tim_Flynn)
    Tim,
    The RGB colour issue is probably coming from an indexed PNG (or other
    indexed image file) used somewhere in your document. Convert it to an
    RGB format to get rid of the recurring colour definitions (these
    happen all of the time and shouldn't be the crash issue).
    Did you install the Adobe PDF printer instance that came with FM8 or
    one from the full Acrobat (Pro, 3D) products? What is your system
    default printer set as?
    Did any of the tables originate from a Word document somewhere along
    the line?
    Have you tried a MIF-wash on your document (save to MIF, open MIF and
    resave as binary)?
    Nov 16, 2007 3:43 PM   in reply to (Larry_Carey)
    Hi Arnis,
    Yes, I have saved numerous times as an .MIF; matter of fact for the past couple of days to continue my work I reverted back to using Frame 7.2 and only save the files as .MIFs. I have not had a crash since.
    To further complicate matters, I finished creating Book templates in Frame 7.2. and built a book to test the generated lists; page numbering, etc. all functioned correctly. I saved the files (as .MIFs) and moved them onto another system which only has Frame 8 loaded. I opened the files saved them as Frame 8 FM and built a book using the template files. The Frnt Matter section page numbering (lc Roman numerals) changed to Arabic, was not sequential through the different sections regardless of my selections in Format, Document, Numbering in the individual book file/book window.
    The table was not imported from Word but created in Frame from scratch. Since I have been having these ongoing problems I wanted to rule out anything external causing the issue(s). I currently have two graphics in the document (TM Block and Logo) both are .jpg. Although, I am switching to PNGs and was not aware of the issue-thanks.
    So, I plan to return to using 7.2 and wait until these issues are resolved.
    Thanks again for your response.
    Nov 16, 2007 8:03 PM   in reply to (Tim_Flynn)
    In the past crashes could be due to driver errors, bad fonts, corrupt
    directories, hardware problems, etc. Do you have any video acceleration
    turned on? Have you tried to see if there is a newer (or older) video
    drivers? Searched for bad fonts? Checked for directory errors? I know
    this is a shot in the dark, but sometimes such a shot will hit its target.
    Mike
    Nov 19, 2007 11:44 AM   in reply to (Larry_Carey)
    Hi Mike,
    I have updated the drivers and performed the Windows OneLive Care analysis and recommended fixes. Video drivers/acceleration - have the latest with Acceleration set to Full.
    Bad Fonts.... Upon opening some templates I have created with Frame 5.5 and 6.0, I did receive different Font Messages which as I remember were advisories stating a font did not exist and Frame 8. was going to substitue X for X. Although, I did not receive these messages when creating the new templates in FM 8. How does one check for bad Fonts?
    Directory Errors - Have not had any issues with any directory issues. With the system maintenance checks I have performed I think (hope) any existing errors would have been found and corrected. How would one verify this?
    Thanks for your input.
    Tim
    Nov 19, 2007 8:49 PM   in reply to (Tim_Flynn)
    Tim,
    I seem to remember the OneLive can actually cause problems. Try turning
    it off.
    Mike
    Nov 30, 2007 12:06 AM   in reply to (Larry_Carey)
    Hi Larry,
    I would like to help you with these crashes. Can you send me some of the crash logs at sgoyal@adobe.com.
    --Sumeer
    Dec 24, 2007 8:20 AM   in reply to (Larry_Carey)
    This post seems to reflect my experiences with FrameMaker 8 on Vista.
    I downloaded Frame 8 to create a Christmas & New Years newsletter. The graphics are in JPEG, PNG, PSD,and one GIF. I have 12 pictures on two pages. The computer is a Dell 1520 laptop, Vista, 128 MB video card, 2 GB RAM, 200 GB 7200 RPM drive. Have been using FrameMaker for 12 years.
    I experienced four or more crashes a day. The FrameMaker application freezes and the window whittens. This seems to happen when I cut and paste. If I hold the mouse button down too long also might cause it.
    I really can't figure out what the problems is. The Adobe InDesign version of my previous newsletter was essentially the same letter. InDesign on Vista does not crash; FrameMaker 8 on Vista crashes often.
    Dec 24, 2007 3:54 PM   in reply to (Larry_Carey)
    I am about to post a message with more details of FM 8 crashes (PDF and Book Update/Generate). Larry Carey mentioned something about a "I can produce PDFs fine (with the highly publicized "fix"). What fix is that?
    Does anyone know if Save As PDF is related to issues with Book Update/Generate?
    Ken Whitaker
    Seattle, WA
    Dec 24, 2007 4:05 PM   in reply to (Larry_Carey)
    With Windows XP Professional SP2, FrameMaker 8 crashes with about 20 documents in a book whenever I either do an Update Book and Generate Lists or Save As PDF. I am not using a font manager but have installed Adobe CS3 including Adobe Acrobat 8 Professional. I assumed that Acrobat 8 is a superset of the version of Acrobat Distiller that comes with FrameMaker 8 and hopefully should work.
    My configuration is:
    Build: 8.0p266
    Window System: MSWindows XP Professional SP2
    System: Quad-Core, 4GB RAM, plenty of available disk storage, two 24 inch monitors
    Adobe Acrobat: 8.1.1
    Adobe Distiller: 8.1.0 (Note that I started this up and this is what was displayed in the log text window (Im not sure if this is a problem):
    Acrobat Distiller 8.0
    Started: Monday, December 24, 2007 at 15:29:07
    Adobe PostScript software version: 3016.102
    CID support library initialization completed.
    Error in PDFX4 2007.joboptions:
    /CheckCompliance out of range
    The book uses OpenType/Type 1 fonts, cross-references, tables, and links to graphic files. Page size is 8 in. x 9.25 (so it is smaller than letter page size). I made sure that no other Adobe CS3 application was running and I did the following with this book:
    1. Save [the book] As XML. Worked (all files were processed successfully to create the XML).
    2. Print [the book] to an HP Laserjet as a PRN file. Worked.
    3. Update Book and Generate Lists. Crash with Error number 8004 (Internal Error: 8004, 8443407, 4460228, 4414681).
    4. Save As PDF with PDF Job Options of Standard (just to keep it simple). Crash with Error number 8004:
    And then, in this case, when I click OK, another error window is automatically displayed.
    Bam!
    Im not sure if:
    The book has too many chapters.
    The book has content that FM 8 doesnt like.
    There is a coordination issue with Acrobat Distiller (does FM 8 still use Distiller?).
    So, I made a simplified book with four files (Title, TOC, 1 chapter, and index).
    1. Saved As XML. Worked.
    2. Update Book. Worked! (This is great, compared to the long book example that crashed)
    3. Save As PDF. Crashed with error 8004.
    I am packaging the files to send to Sameer of Adobe (looks like he volunteered in a prior posting) but I am having to keep both InDesign and FrameMaker documents updated cause I am not trusting FrameMaker 8 at the moment. If, as Larry Carey, says in a prior posting that there is a much publicized fix, Id sure like to know about it.
    With Adobe CS3 installed I really dont want to remove / uninstall Acrobat 8 if I can help it. The Activate/De-activate feature can be a mess. I also dont quite know how to diagnose this issue because the number of possible causes of these errors are almost endless and I dont have the time. I still have FrameMaker 7.1 installed (is that the cause?) so I guess I could try that too.
    Please, any suggestions???
    Ken (Software Maniac)
    Seattle, WA
    Dec 26, 2007 6:23 AM   in reply to (Larry_Carey)
    I have performed many test steps on both Adobe FM 8 and 7.1 using a very simple book template and found similar results all with the latest Adobe Acrobat Distiller 8 that comes with Adobe CS3 Design Suite. I've sent sample files to Sumeer at Adobe (tried to send them, IF we can get the attachment past Adobe's IT e-mail filters)!!!
    Any other findings from you guys out there in FM-land?
    Frustrated and confused,
    Ken
    Dec 26, 2007 11:19 AM   in reply to (Larry_Carey)
    Both FM 8 and Adobe Acrobat 8 have been patched since release... Are y'all up-to-date?
    Art
    Dec 26, 2007 11:45 AM   in reply to (Larry_Carey)
    Sorry to hear additional folks are having FM 8 crash problems. I feel your pain...
    I am using a Dell Inspiron 1505 Duo Core 1662Mhz/WindowsXP Pro with all Packs and updates. Initially had a lot of cashes which I could not pinpoint to a single Frame function causing them.
    After talking with Adobe Tech Support and reading this forum, I rebuilt the templates from scratch to rule out corruption carried forward from templates created with earlier Frame versions, increased my RAM to my lap top's physical limit (2.GB), and consistently check temp files and delete all prior to launching Frame (Start - Run - type in %temp% and hit enter, Ctrl-A, delete). It seems the increase in RAM helped the most.
    A recent patch from Adobe (151MB) seemed to also help quiet down the crashes, and (gulp) shutting down my virus scanner helped as well. Still have 1-2 crashes a day but a big improvement as compared to having over a dozen...
    Another issue which may be related is the Track Change function. I used the Track Change function while reviewing documents (editing, updating para formats, etc.). After opening a doc that most likely crashed earlier (so many crashes could not keep track), a good portion of the document has green, underlined text which looks like an insert. I have not been able to remove or set it back to black text without underlines no matter how I tried. I contacted Adobe about this to ensure I did not miss something in regard to its correct functionality and they could not figure it out over the phone. The tech requested I send the file for him to look at (haven't heard back from anyone yet). Have dead lines 12/31 and decided to retype the chapter.
    On the same topic, I find the Track Change function a great addition to Frame, but as it currently functions on my system it is Worhtless. When entering text, Frame is slowwwwwwwwwwwwww and always "behind," skipping over the characters you type - and I am not a fast keyboardist. If you want to use the info you input, you'll have to retype it - Slowly! I won't use it again.
    If I had an inkling to the problems I was going to face with FM 8, I never would have brought it in as our main doc tool until these issues are corrected.
    - Removed duplicate response. -
    Dec 27, 2007 12:09 PM   in reply to (Larry_Carey)
    Yes, updated FM to build 266 and Adobe Acrobat Distiller 8 to 8.1.0 (which is part of Adobe CS3 Professional v8 package).
    I've uploaded the book template that I created and Adobe Support is apparently reviewing it. Hopefully, they have internal tools that can assist diagnosing what is wrong.
    What used to be simple when you would get Distiller tied with the FM has now gotten far complicated - especially those of us who also use other Adobe tools (like CS3 suite packages which can include its own updated Distiller).
    I have done an interesting test since I have created like doc templates in both InDesign CS3 and with FrameMaker 8 (this exercise would make a great book!) and although I prefer FrameMaker for historical reasons, InDesign works without a hitch. I'm just not sure if InDesign CS3 uses Distiller because when I do a Save to PDF, I don't see Distiller do anything... Does anyone know?
    Also, I have another question - under FrameMaker 8, I also update all references with the Book Update (Generate TOC and Lists) command. And it too crashes sometimes. Yet if I do a Save As XML which is another way to traverse through my documents in a book, it always works. Has anyone seen this behavior?
    best regards,
    Ken Whitaker
    Seattle, WA
    Dec 27, 2007
    Dec 27, 2007 12:49 PM   in reply to (Larry_Carey)
    Ken...
    As an additional weapon for your Frame arsenal, you might want to look at your installed printers on your computer. You should find one that is named "Adobe PDF."
    Instead of creating PDFs using the Save as PDF menu selection, try "printing" the book using the Print command. Select Adobe PDF as the Printer and make certain that the Print to File check box is UNCHECKED. You will be prompted for a location to print the PDF, and you can edit the name of the PDF while you're at it.
    If you have cross-references, hyperlinks and such that you want to preserve in the PDF, check the Generate Acrobat Data box after reviewing and configuring what you want via the PDF Setup button.
    The Print method always works perfectly for me. I have had all kinds of problems using the Save As PDF approach, including crashes.
    The free SetPrint plug-in is useful for ensuring that the Adobe PDF printer becomes your "default" printer just for FrameMaker when it is launched. Here is a link to SetPrint:
    http://www.sundorne.com/FrameMaker/Freeware/setPrint.htm
    I hope this helps...either way, Happy New Year!
    Dennis...
    Grass Valley, CA
    Dec 30, 2007 12:02 PM   in reply to (Larry_Carey)
    Thanks Dennis
    Tried the Print to Adobe PDF printer driver (guess that came along with Adobe Acrobat Professional 8) and it crashes also.
    Crap.
    Ken Whitaker
    Seattle, WA
    Dec 30, 2007 12:04 PM   in reply to (Larry_Carey)
    Larry,
    You mentioned: "I can produce PDFs fine (with the highly publicized "fix"), "
    What fix is this? You mean FM build 266?
    Ken Whitaker
    Seattle, WA 98012
    Feb 21, 2008 8:17 AM   in reply to (Larry_Carey)
    Folks, I am having the same issue with 8.0p273 (the latest)...We are totally up against the wall with this. ANY HELP ANYWHERE????
    Feb 21, 2008 8:19 AM   in reply to (Larry_Carey)
    Would like an update from Adobe on this. How do I engage them.
    Thanks for any help.
    Phyllis
    33. ,
    Feb 21, 2008 8:29 AM   in reply to (Larry_Carey)
    "How do I engage them"[?]
    Given that it's FrameMaker 8, is Adobe support of any help? (This of course being a user-to-user forum only intermittently browsed by Adobe personnel...)
    Cheers & hope this helps,
    Riley
    Feb 21, 2008 9:09 AM   in reply to (Larry_Carey)
    Phyllis,
    If you scroll back to the earlier portion of the thread, a FM engineer posted his email address and asked people to send him crash logs...
    I assume he's still looking for input.
    Cheers,
    Art
    Feb 21, 2008 1:52 PM   in reply to (Larry_Carey)
    Thanks Art. Having a hard time navigating my way back to this thread!
    It's been a nightmare. Now we are having trouble with page numbering remaining SAVED. Once I finally got updates to work, and removed Update All Text Insets (and doublechecked every last single-sourced topic to assure they were all in v8.0), I could update and PDF, but all the page numbers now remain in Roman numerals...can't save the changes when I reset them.
    This sounds to me like product was pushed out the door because the date for release had arrived, and it hadn't been fully tested. I am performing excruciating test cycles for them...with a customer hanging over my shoulder...
    Feb 21, 2008 2:20 PM   in reply to (Larry_Carey)
    Phyllis...
    At the top of this screen, just below and to the right of your original posting, click on the "Show All Messages" link. Then simply scroll down to message #19 from Sumeer Goyal.
    Dennis...
    Feb 21, 2008 2:21 PM   in reply to (Larry_Carey)
    My bad. That should have read "Larry's original posting."
    Dennis...
    Feb 21, 2008 2:28 PM   in reply to (Larry_Carey)
    Phyllis,
    Not to minimize your troubles at all, but not everyone is having problems, and few shops are having the severity that you're experiencing. I was a beta tester, and then delayed adopting until after the first patch was released. But no major problems to report...
    So at least consider that it's something in your configuration that's contributing.
    Just in passing, did you ever post details of your system and network configs? It's useful trouble shooting info for the rest of us to have.
    Art
    NICE. Thanks. One thing I've gotten right all day.
1 2 Previous Next
Actions
