InDesign and Hungarian Text
Jun 24, 2008 9:36 AM
I am currently using InDesign CS2 Windows and I have been able to work with a wide range of characters/languages with no problems; from Romanian to Icelandic once I installed the appropriate font not characters were ever missing. Until I tried to pour text in Hungarian. I cannot get the 2 character ő to appear even after installing a couple of "Hungarian" fonts. Can someone help me please?!?
    Jun 24, 2008 10:21 AM   in reply to (Karina_Conant)
    Karina...
    This is a FrameMaker forum, not an InDesign forum. Someone here may be able to help you, but this is not the appropriate place to ask this question.
    Dennis...
    Jun 24, 2008 10:25 AM   in reply to (Karina_Conant)
    Frame 8 supports Unicode. Earlier versions do not. What version are you
    using?
    Kenneth Benson
    Pegasus Type, Inc.
    www.pegtype.com
    Jun 24, 2008 11:00 AM   in reply to (Karina_Conant)
    What do you mean by Hungarian fonts. There are a number of TrueType fonts/Type 1 fonts that cover the Central European languages (CE fonts). If you use Unicode fonts (most OTF fonts), they automatically contain the characters you need.
    The key is to use the correct codepage and keyboard setup for you to access the needed correct fonts by a mere typing on the keyboard.
    Try these links:
    http://www.hungarianassociation.com/TypeInHungarianInWindows.htm
    http://www.microsoft.com/globaldev/keyboards/kbdhu.htm
    keep smiling
    thomas
    Jun 25, 2008 2:18 AM   in reply to (thomas_bro)
    Thomas,
    Attention! Unicode and OpenType are only "formats". It's up to the designer(s) of the font which glyphs to include and which not. It's absolutely fine to create a Unicode OTF font that only covers the glyphs for "western" languages. And there are enough OpenType fonts out there with no support for e.g. central European languages.
    Beside this, I suggest to not use old (non-unicode) Type1 Fonts in a Unicode Environment like FrameMaker 8 or InDesign.
    I suggest to carefully check the preferred font for the languages covered. You can check this with your font vendor or check for consulting of a specialist for multilingual publishing ;-)
    Jun 25, 2008 5:45 AM   in reply to (Karina_Conant)
    Karina accidentally posted in the wrong forum. She fixed her problem
    (that she couldn't get o double accent acute in Indesign) by installing
    the Hungarian keyboard layout.
    I've been trying to figure out why that fixed it. Anyone know?
    Kenneth Benson
    Pegasus Type, Inc.
    www.pegtype.com
    Jun 26, 2008 1:50 PM   in reply to (Karina_Conant)
    Stefan,
    Thanks for the clarification.
    Keep smiling
    Thomas
