Is there a way to create linear spirals?
Oct 25, 2008 Oct 25, 2008
Another spiral question that's been nagging me: does Illustrator provide any way to create a linear (Archimedes) spiral? I'm trying to create a spiral where the distance between the windings is constant. It looks like Illustrator only makes logarithmic spirals, where the angle of the windings is constant but the distance between grows bigger with each successive winding.
If not, are there third-party plug-ins or solutions of any kind?
I suppose I could write the curve in Postscript, but that seems like work. :)
49.7K
Adobe
Oct 27, 2008 Oct 27, 2008
I cracked this one for you, at least sort of :-)
With the pen tool draw a straight horizontal line. Colour the stroke only. Copy-drag it so that the left end of the copy snaps to the right end of the original line. "Un-colour" the copy.
With both lines selected go to the Distort/Twist filter and enter 360° (or 90°, or 180° - it maketh not much of a diff). Apply the filter as many times as you wish. Now select the uncoloured line and delete it.
Bingo-ish.
I notice however that the line is a bit wobbly in some places (the filter doesn't work very accurately and scatters anchor points here and there along the path), so the line will need a bit of adjustment. Object - Path - Simplify will get you most of the way.
Alternatively (if you're good at drawing with the pen tool), you could make a guide of the original spiral path and use the pen tool to re-trace it smoothly. In which case it would be useful to find the centre of the spiral and snap horizontal and vertical ruler guides to it. That way all your new anchor points will be aligned properly and you can hold down Shift as you drag out the handles.
Advocate ,
Steve
Wow...! what a smart solution....brilliant.
The trouble with this method is that the spiral gets increasingly inaccurate the more often you apply the filter. Not sure why, but I think it probably has something to do with the positioning of the geometrical centre, which moves slightly each time you apply the filter.
If you apply the Twist filter far too many times you will find that the path sometimes turns back on itself, forming little loops. This shouldn't happen and even Simplify doen't get rid of those loops.
Something is obviously a bit wrong with the way the filter is written.
http://www.pixentral.com/show.php?picture=1E9ZX9RpRhpK0xqMo3E4cZ6bJTZme0
Here's another way for what it's worth. It corresponds to the old way of drawing a "spiral" with a pair of compasses.
Draw a set of concentric circles with the same increment between sizes. For example 5, 10, 15, 20, 25, 30 units.
Cut and paste the bottom halves of the circles and snap them so that they mis-align by 5 units. Now you've got a double spiral, so you can delete the red bits, Now join up the ends (Join - Smooth) and you've got pretty much what you're looking for. Of course it's not an exact spiral but good enough to fool the eye.
Enthusiast ,
FreeHand's spiral tool can be set for even spacing. It's a breeze to use. If you have a copy of FreeHand you could draw the spiral there and copy it into AI.
FreeHand's spiral tool would make a good feature request.
I had a happy accident with Steve Fairbain's first technique. He's right that it's a bit wobbly, but if, after doing the Distort/Twist, you press Cmd-d to duplicate the transform, you get a wave-type Greek key design. Pretty cool!
Another technique: use the Twirl tool on a straight line and then cut it in the center where the spiral turns back on itself. Adjust the Twirl Rate to control the spacing of the windings.
Oct 28, 2008 Oct 28, 2008
The Twirl tool produces a decidedly wobbly result much like the Twist filter and very inaccurate near the centre. You can't control the number of turns properly and anchor points get produced more or less randomly it seems. I don't know why these inaccuracies creep in. Seems like accurate Archimedes spirals are a thing that the Illy people haven't addressed properly. The smoothest result so far is my second example, the old "compasses" method, even though it isn't a true spiral.
The Twirl method is indeed a bit wobbly at the center and at the points where the twirl begins on the line. The spacing of the turns seems accurate and even, though. In looking closely at the anchor points and control handles, the ones on the turns are parallel, while those at the center and the outside aren't quite parallel, which is what seems to cause the wobble.
I agree that Illustrator needs a better way to make spirals. I don't use them all that often, but it's frustrating when I do need one.
http://www.pixentral.com/show.php?picture=1cXMXReDQoa9AsM5CHmdEMfzUfIO
Here's a shot of another "faux-spiral" done with the "compasses" method. It's easy to construct and completely accurate (see how the stroke widths kiss exactly). Like I said, not a true spiral but good enough for most people and much smoother than anything that Twirl and Twist can do.
Oct 29, 2008 Oct 29, 2008
The Spiral tool was introduced in Illustrator 6.0, and in those days I think the tool had the capability of making Archimedes spirals.
Here's an image used in the AI 6 User Guide:
http://www.newmango.com/test/spiral.png
The description says "Hold down the Control key to increase or decrease the amount by which each wind of the spiral decreases relative to the previous wind."
In recent versions, that value is a percentage, and I'm thinking that in 6.0 it may have been an absolute value. And Adobe has since disallowed the Control key, so now it does nothing. You can enter the decay rate in the Spiral options dialog, but it has to have a value of 5% or greater.
- Draw a horizontal stroked line, 200 mm wide for example
- Select the line and Copy Move, Vertical Movement: 5 mm, for example
- Hit Command+D as often as you like, for example 8 times
- Direct select all anchor points at the right ends of the lines
- Hit Enter and set vertical movement to 5 mm
- Select all and create an Art brush out of the selection
- Draw a stroked circle, 60 mm diameter, for example
- Apply the Art brush
This is, of course, no Archimedes spiral, no it's the so-called Circular Probert Spiral. It was originally discussed in the Illustrator Windows forum some years ago.
Hmm... I was wondering when someone would bring that up.
BTW, you can get a better center on the spiral above, I just didn't monkey with it much.
Theoretically, you should get a more controllable spiral by mapping the same art, via a symbol, to a cone created by revolving an angled line, then viewing it from above.
But again, Illustrator 3D leaves a lot to be desired
Apparently Illustrator outlines the strokes of the climbing angled lines, and trashes the accuracy of the original linework in the mapping process.
Thanks for the sketches, Jean.
I was too busy preparing stollens which will then be scorched as always.
I was actually playing with the 3D version when I saw your post come up. I had already done the pattern brush version, but hadn't made an image yet.
The 3d version is a lot of fun to play with in alternate views.
I've found the art brush to work pretty well too. You would think that there would be an easier way to accomplish something so seemingly simple.
This method may give a little more control. Here I started with a series of concentric circles, and created a brush which represents only one revolution, which rises the same distance that the rings increase in diameter.
When the concentric rings are stroked with the art brush they combine to create a spiraling effect.
Guest
Nov 03, 2008 Nov 03, 2008
http://en.wikipedia.org/wiki/Image:Archimedean_spiral.svg#file
Guest
That is a really clever solution, Jean.
Jean,
This looks very nice. I haven't tried making a spiral like yours but what is the output like? Do you get a single stroke or is it outlined? If so, I suppose you could delete one edge of the outlined stroke, but it would be nice to know before I start experimenting.
Guest
After expanding the appearance, you get one stroke for every concentric circle you started with. You then need to join the endpoints together to get a single path. I noticed that, the farther away you get from the center, the farther apart the endpoints are spaced, but it's very slight.
I wonder whether Average:Both, Join:Smooth would do it, or whether it would distort the spiral too much. Reckon we'd better do some experimenting :-)
as Kurt mentioned earlier, the single circle/multiple line brush version is something that has been kicked around on the Illustrator Windows forums: that's where I first saw it.
The single line brush/multiple circle version is my variation of that technique. It has some advantages, some disadvantages.
the 3D version was just a thought. It is actually the most versatile by far if you want fun variations (think spiraling confetti, etc.) and the center is more correct, but it is sloppy in the straight-on view.
All of them break at least once per revolution. The two brush methods wouldn't be too horribly difficult to join if you wanted to do that.
