Feb 24, 2009 9:23 AM
I have used Illustrator since AI 7 but have recently begun using CS3 on a new Macbook Pro.
This is such a ridiculous issue which I have never experienced before that I reckon there must be something I've forgotten but if so it beats me what it is.
As we all know, Command-1 is the shortcut for Actual Size (100%), I never use the menu for zooms. However, currently the screen image is clearly NOT 100% but something around 75%. Actual Size is checked in the View menu and 100% is displayed in the title bar and at the bottom of the window.
I check the document setup to make sure that I didn't make a mistake there and it's as it should becorrect size in the correct units.
I use the menu instead of the shortcut and the result is the same. The image is definitely NOT 100%.
What have I forgotten guys?
