Virtual Scott
Illustrator file not viewable in finder in Leopard.
Feb 27, 2009 8:11 AM
Interestingly, I seem to remember that when scrolling through Illustrator files in the finder on a Mac, if you have the preview window active, at least with .AI files, you'd get a preview of the graphics and not the default AI (or EPS) icon. Now I don't get any preview. Any suggestions?
    Feb 27, 2009 8:15 AM   in reply to Virtual Scott
    You'll need the SneakPeek Pro plugin for the QuickLook feature in Leopard. It's available from Code-Line Software.
    :) Mordy
    Feb 27, 2009 8:53 AM   in reply to Virtual Scott
    Hello Scott.
    That is right a $50.00 plug-in for Adobe's Failure. This bug started on CS3 and is live and well on CS4 too.
    Be aware that this plug in does not work with Illustrator, is like a second program.
    But also you can use a Second Program called "Bridge" that comes only when you wasted your money on Creative Suite Edition.
    In short, you have to use 2 programs to do a simple task. Good luck!
    Feb 27, 2009 9:39 AM   in reply to Virtual Scott
    First of all, this has nothing to do with CS3 or CS4. It has nothing to do with Adobe. It's Apple's implementation of their OS. By default, Illustrator embeds PDF versions of your file in each document, if you save it with PDF Compatibility turned on. Apple's OS can read and display PDF files, but for performance reasons, the OS only does this for files under a certain size. Anything above that size is displayed the document icon.
    With Tiger, Apple started to implement a feature called QuickLook that allowed you to better preview files directly in the Finder and really anywhere the OS is called (Open and Save dialogs, etc). This feature got better in Leopard, and Apple also opened this feature as an API so that other developers could develop custom readers to give extended functionality to the QuickLook feature.
    Code-Line software developed such a plugin that enables Apple's QuickLook feature to display Illustrator files, even if those files saved with PDF compatibility. In this way, you can simply tap the spacebar in your finder with any AI file selected, and you'll see a preview, PLUS a list of some of the metadata for that file (fonts used, colors used, images used, etc). The SneakPeek plugin works not just for Illustrator files, but also for EPS, FreeHand, and InDesign files. It's a valuable plugin, in my opinion, and the cost is $20, not $50.
    :) Mordy
    Feb 27, 2009 11:29 AM   in reply to Virtual Scott
    Ok, Let me see if I understand this:
    A $20.00 plug-in can do what a $600.00 program can't?
    What about the PC versions?:
    http://www.adobeforums.com/webx/.59b57671
    That is right, in this Windows Forum they blamed Microsoft.
    But what about the memory BUG on CS4?
    http://www.adobeforums.com/webx/.59b6d86f
    In PC version too? So what is the difference between a Mac Program and a PC Program?
    I started to wonder that maybe, just maybe, there is a probably of 0.000000001% chance that Adobe has something to do with all these bugs.
    Is a shame that Xara Extreme ($89.00) is only available for PC users.
    Nov 13, 2011 8:32 AM   in reply to Mordy Golding
    Nonsense. How diificult would it be for Adobe to code this plug-in? In fact plug-ins for all of it's products. This would be the right thing to do for it's customers.
