Convert AI to JPEG
Sep 27, 2006 Sep 27, 2006
Hi All,
We have a requirement to programatically convert AI files to JPEG files. (But not as a plug-in). Can this be done using the Adobe AI SDK? If so, could any one provide any pointers on how to do it? If not, what other ways are available for programatically converting AI to JPEG? Are there any other 3rd party SDK which can do this?
CS
SDK
69.4K
Adobe
Apr 11, 2007 Apr 11, 2007
I also have this same requirement. I noticed this post is quite old but I'm hoping someone may have an answer for it. Thanks in advance for any help you might be able to give me....
May 30, 2007 May 30, 2007
Me too, keep searching....
I ended up doing this by using the ImageMagick APIs. It does most of the things what we want. However, if the AI file has multiple layers, it does not extract the different layers. Other than that, it pretty solid and reliable.
Jul 07, 2007 Jul 07, 2007
What I have found that works best and I am currently still looking for something easier by the way. But what I do is I open the Adobe Illustrator file, select all, copy everything, then open a new clipboard file in adobe Photoshop and paste it in there then I save m as a jpeg format. So far that has worked but it is still time consuming. So if all else fails you can try this it works for me.
Jul 09, 2007 Jul 09, 2007
E-spec has a plug-in that extracts the layers as jpegs. http://www.e-spec.net
All,
Thanks for all your replies. I need to do this as a stand alone application. Not as a plug-in.
Shannon, Are you doing what you said thru scripting or thru the SDK?
Any leads would be appreciated.
CS
Jul 12, 2007 Jul 12, 2007
What language are you planning on writing the stand-alone application in? If you save the illustrator file with PDF compatability(on by default), any of the several PDF libraries should be able to rasterize the file as a generic image, which you can then convert to whichever format you desire.
Hi Jeff,
Thanks for your reply.
Some of our customer AI files are NOT saved with PDF compatability. And even if they are, the other PDF libraries do not see the contents outside the AI artboard. I have tried ImageMagick/Ghostscript and other PDF conversion utilities as a possible solution and it does not work:(
As for the programming language, I'm ok with c# .Net / Visual Basic.
CS
Aug 06, 2007 Aug 06, 2007
Hi Guys,
I am looking for the same solution, with no luck so far.
I need to convert a pdf to jpg using classic asp/vb...
Other modules/team is dependant on this code, so I need to get this done asap.
Any luck with using Ghostscript in asp code?? I dont know how to use it in classic asp. Any pointers will be helpful.
Heena
Aug 07, 2007 Aug 07, 2007
Hi Guys,
My requirement is also similar. i want to display the .ai images on the web. Is there any tool which gets internally converted? i went through an article
http://www.15seconds.com/issue/030630.htm
but i dont know whether it is possible using SVG.
Shankar.N
Sep 05, 2007 Sep 05, 2007
The Illustrator Scripting API provides functions to export documents to swf, jpg, gif, png, psd and svg and you can script Illustrator in JavaScript, VBScript and AppleScript. These scripts can either be run from Illustrator File > Scripts > Other Script menu or from the file system, provided the correct context is set up in the script. There are several sample scripts provided in the Illustrator install folder to use as reference. Not sure this is feasible for your application but it is another option.
Feb 20, 2008 Feb 20, 2008
Hi CS,
Exactly, same problem, I got here, May be this discussion is older but useful for others.
I am using here ImageMagick and Ghostscript in command line with programming. I am able to convert AI file format to JPEG. But got error in some of AI files which has Post Script as format PS,Some of AI files with format PS/PDF are converted with no error, but some particular AI files are not.
I got this error while using Ghostscript,
Error: /undefined in Adobe_level2_AI5
I tried lots of option but always got this error for particular type of AI files.
Any helps!
Thank you.
Oct 16, 2012 Oct 16, 2012
I have the same problem, while some files works, other files don't works 😕
Mar 16, 2008 Mar 16, 2008
my AI document size is 150*200.
i want to convert folder of ai to jpg which size will be 3000*4000
anyone can help me in Adobe illustrator.
Apr 05, 2008 Apr 05, 2008
If you open the file up in AI and then save as for Web & Devices ( File>Save for Web & Devices) You can select GIF, JPEG OR PNG.
Nov 03, 2008 Nov 03, 2008
DONT SAVE, EXPORT. AND THEN YOU GET MORE SAVING CHOICES.
Enthusiast ,
Sep 02, 2015 Sep 02, 2015
This can be done using plugins, extensions or scripts. Adobe provides tools, documentation to develop any of this solutions.
Any other solution won't work or won't work as fine as those.
Guest
Nov 30, 2015 Nov 30, 2015
The simplest way to change ai to jpeg is copy and paste. control V from ai file and control C to psd format file.
