[CS3] How to add multiple panels in a single FR
Jun 17, 2008 8:45 PM
Fellow Developers,
I have tried every other way to try adding a 2nd panel definition to a single fr - no luck. Here is what I did.
// PanelList definition.
resource PanelList (kSDKDefPanelResourceID)
// 1st panel in the list
kSDKDefPanelResourceID,
kGINPluginID,
isResizable,
kGINPanelWidgetActionID,
kGINPanelTitleKey,
"",item in a second place
0.0,
0,0,
c_Panel,
// 2nd panel in the list
kGINDocPanelPanelWidgetResourceID,
kGINPluginID,
notResizable,
kGINDocPanelPanelWidgetActionID,
kGINDocPanelPanelTitleKey,
0.0,
0,0,
c_Panel
resource GINPanelWidget(kSDKDefPanelResourceID + index_enUS)
resource GINDocPanelPanelWidget(kGINDocPanelPanelWidgetResourceID + index_enUS)
In ID.h
#define kGINDocPanelPanelWidgetResourceID 720 // random number
Code builds but I get an assert complaining about missing resource with id = 720.
All the included samples in SDK illustrate single panels.
Appreciate any help. Thanks
CG
    Jul 22, 2008 11:07 AM   in reply to (Carl_Green)
    I'm having the exact same issue, only my error message is: "PanelMgr::CreatePanel - could not load panel from plugin MYPLUGINNAME.PLN with rsrc id 5000"
    I'm assuming that it's possible to program multiple palettes, and that I'm missing completely obvious.
    Thanks.
    Jul 23, 2008 12:26 AM   in reply to (Carl_Green)
    You are trying to merge two panel resource with SDK PanelList. Instead create a separate panelist for each panel resource -
    resource PanelList (kGINDocPanelPanelWidgetResourceID)
    kGINPluginID,
    notResizable,
    0.0,
    0,0,
    c_Panel
    Hope this helps !!
    - Amit Gupta
    MetaDesign Solutions
    Aug 9, 2008 4:08 AM   in reply to (Carl_Green)
    Hello Amit gupta
    I am also creating a panel using the .fr file and I've added the panels in the list as u assisted in the separate panellists. but im also getting the same error as of charlene burke. can u tell what is the issue?
    MS Chaudhary
    Aug 10, 2008 7:49 AM   in reply to (Carl_Green)
    Do you have a LocaleIndex resource with the ID specified in the PanelList?
    Is the boss class for your custom resource type correctly defined in the classes resource?
    Dirk
    Aug 10, 2008 8:11 PM   in reply to (Carl_Green)
    Hello Dirk
    can u please show me the skelton that how can i define the localindex and panellist.
    What actually i want to do is to define a palette with two panels in it with my plugin.
    Thanks for your support
    MS Chaudhary
Bookmarked By (1)
