Lost text line 'guides' in the text box, how to show hidden paths
Nov 13, 2008 4:10 AM
I have managed to loose the text line guides (the blue little guide that shows the path/line the text is typed on) and I cannot remember how to get it back. In illustrator the control H command shows/hides the text bounding box and line guide, but in ID only the box is affected. It is especially annoying when you are trying to type text on a path, and the path you are trying to click on is invisibele.
Please help.
    Nov 13, 2008 5:18 AM   in reply to (Karma_Forester)
    Do you mean you have lost the page grid (View > Grids and Guides) or have you lost all page guides, in which case you have probably slipped into preview mode. With nothing selected hit W. Or click on the last tool in the toolbox.
    k
    Nov 13, 2008 7:26 AM   in reply to (Karma_Forester)
    None whatsoever.
    "then you also have the lines denoting each line of type inside that text box."
    Not that I've ever seen.
    Unless, I wonder if you mean "greeking" which is when type below a determined size is replaced by a grey bar. But you can't type on it because there is already type there.
    I know what you mean for the pen tool. If you use the selection tool you see the boundary box only, but if you select it with the direct selection tool (white arrow) you will see the line inside.
    k
    Nov 13, 2008 7:29 AM   in reply to Ken Grace
    Or are you talking about the baseline grid? View > Grids and guides > Show baseline grid.
    k
    Nov 13, 2008 7:53 AM   in reply to (Karma_Forester)
    Are you seeing them just in the text frame, or do they extend across the whole page?
    What version of InDesign?
    k
    Nov 13, 2008 8:00 AM   in reply to (Karma_Forester)
    That's Baseline Grid.
    Kenneth Benson
    Pegasus Type, Inc.
    www.pegtype.com
    Nov 13, 2008 8:07 AM   in reply to (Kenneth_Benson)
    But it should show outside the frame - unless he's put it right on the edge of the page and the page has got no margins.
    k
    Nov 13, 2008 8:12 AM   in reply to Ken Grace
    You can set a baseline grid for a single text frame.
    Bob
    Nov 13, 2008 8:19 AM   in reply to Bob Levine
    How do you display it?
    k
    Nov 13, 2008 8:27 AM   in reply to Ken Grace
    there is no option to show only for TextFrames or only for Page - both or none
    robin
    www.adobescripts.com
    Nov 13, 2008 8:30 AM   in reply to (Karma_Forester)
    Now I'm stumped. How are you displaying the baseline grid for a single frame?
    k
    Nov 13, 2008 8:36 AM   in reply to (Karma_Forester)
    Sure, it is
    i possible
    -- use "white" as grid color for 'all' frames, and Layer color or a custom one for the single one you want to see.
    I can't imagine how you
    i accidentally
    can set this.
    Nov 13, 2008 9:09 AM   in reply to [Jongware]
    Or why you would want to do it deliberately.
    k
    Aug 9, 2010 3:57 AM   in reply to (Karma_Forester)
    I can view the baseline grid if I go to the menu: View - Grids & Guides - Show Baseline Grid, but the shortcut keys don't work - Alt, Cmd and '. The shortcut for viewing the grid works all right. I'm using CS5 on a Mac (Snow Leopard).
