Removing the blue lines
Jan 14, 2008 Jan 14, 2008
How to remove or to say clear or hide those blues lines and view the page without them,that displays actual(final) page on the screen.
How to
163.8K
Community Beginner , Aug 26, 2015 Aug 26, 2015
Hide Baseline grid. Ctrl+Alt+'
Depends which "blue lines" you mean.
By default, ruler guides are light blue, and can be hidden from the view menu or using the keyboard shortcut Ctrl + semicolon .
Also by default, bounding box edges on layer 1 are blue. Hide those using Ctrl + H.
You can hide anything non-printing buy going into preview mode. Hit W if there is no active text cursor, or use the view menu or the button at the bottom of the toolbox. Preview mode has three states: Page only, bleed area, or bleed plus slug area.
You can clear an individual guide by selecting it and hitting backspace or delete, or shift clicking or marqueeing a group of guides if you want to do several. Clear all guides, and this is going to seem strange, using Layout > Create guides ... and leaving the horizontal and vertical number fields at zero, then check the clear existing guides box.
Peter
Apr 14, 2008 Apr 14, 2008
Hello,
InDesign has blue lines overlayed some menu item's.
I have started a new job which has these lines,
my version at home has no lines (I would like to remove them)
I will attach a link to show what I mean...
http://img89.imageshack.us/img89/9717/picture1wr3.png
You'll probably do better in the Mac forum, but my guess is this is
something coming from the OS, not from Indesign.
Kenneth Benson
Pegasus Type, Inc.
www.pegtype.com
Apr 15, 2008 Apr 15, 2008
It's a CS3 feature that allow you to customize the menus. It can be
changed through workspaces or through the edit>menus command.
Bob
Ok, cheers.
It looks like you selected a workspace which shows the various features of InDesign. Change back to the default workspace.
Harbs
Nov 19, 2015 Nov 19, 2015
Apr 13, 2022 Apr 13, 2022
Thank you, was battling with this too. Such a quick fix.
Jun 14, 2022 Jun 14, 2022
Thank youuuu!
Advocate ,
You can also hit the W key or Shift+W
Contributor ,
May 27, 2016 May 27, 2016
Thank you!
Advocate ,
May 31, 2016 May 31, 2016
No problem.
Mar 17, 2016 Mar 17, 2016
View/Grid & Guides/Delete All Guides on Spread. This worked for me.
May 26, 2017 May 26, 2017
View > Grids & Guides > Hide Baseline Grid
Jan 02, 2022 Jan 02, 2022
This Worked for me.
Thank you!
