Hi, For creating PDF documents on the server with data from a DB I suggest to use PDF Duo .Net converting component (download ASP.NET version of this component). It is easy to prepare the templates. Then take data from a DB and dinamicly create PDF files on the fly. For choise it is possible to save resulting PDF on the disk or show it in the browser wondow using next code(c#): Nevertheless read the documentation of the PDF Duo .Net component.
Check out FDFToolkit.net:
FDFToolkit.net can read, populate, parse and merge PDF form field data FDF/XFDF/XML/XDP/XFA/PDF with Adobe Acrobat (Acroform) & LiveCycle (Static XFA) PDF Forms using Microsoft .NET programming languages, e.g: ASP.net, VB.net, C#.
FDFToolkit.net works on workstations, servers, or both. Licenses are very flexible and inexpensive, built for developers by developers utlilizing iTextSharp technologies. Includes 1 year of technical support and updates w/ manual subscription renewals.
For more information:
http://www.nk-inc.com/software/fdftoolkit.net/examples/
Feel free to contact us:
http://www.nk-inc.com/support/sales/
Message was edited by: NKOWA
1) Please try our product PDF-Writer.NET component designed to provide developers with an easy-to-use tool for creating standard PDF file from their .NET applications. The commands provided for adding content to documents are similar to the ones available in the .NET Graphics class. This makes it very easy to use and program
2) Designed for Creating, Editing, Merge, Split, Fill Forms, Encryption, Digitial Sign, standard PDF file from .NET applications.
3) Designed for WinForm , ASP.NET , WPF , Silverlight applications. . It is 100% managed and doesn't require any third-party DLLs.
4) It includes 100% Source code.
Please check below link for more info.
http://www.dbautotrack.com/products/pdfwriter.html
You can Download Full Version with implementation sample using the below link
