Creating Single PDF from multiple XDP's
Feb 21, 2007 10:28 PM
Is it possible to create Sigle PDF by combining Multiple XDP.
the basic idea behind this is . Different XDP will be based on different
templates i want to combine these XDP to create a single PDF.
    Feb 21, 2007 11:25 PM   in reply to (ArunKS)
    Couple of way to do this.
    1. Merge templates together before rendering as PDF. A common practice known as XDP stitiching. This requires thorough analysis of the XFA format, and the xdp files. Write a utility class that will help you do this.
    2. Merge PDFs together post rendering. Use Adobe LiveCycle Assembler for this. Use Form Server to render each of the PDFs, then use assembler to merge multiple PDFS into one.
    3. Do this manually using Designer. Copy and paste works.
    Cheers
    David
    www.ensemble.com
    May 19, 2008 9:23 PM   in reply to (ArunKS)
    Does anyone (or adobe) has script that can I can use?
    Mar 28, 2011 4:27 AM   in reply to (ArunKS)
    Write me a PM and i send you a script
    Конкурс выиграть iphone бесплатно.
    Jul 12, 2011 11:48 PM   in reply to (David_ck_Liao)
    Do you have any recommendation for the post which is written below.
    http://forums.adobe.com/thread/876637
    Best Regards,
    Mahir
