Aug 1, 2007 2:21 PM
I've run into a strange problem. I designed a form using LC designer and added barcodes to it. The form is a multipage form and contains substantial amount of data. Since all this data cannot fit into one form, one the click of the submit button, the script reads all this data and breaks into smaller chunks which are then rendered as barcodes. In the PDF form this script does the job of generating barcodes on the click of the button. The same function is also called on the form load event to render the data incase the form is already populated (when viewed later).
However, when I deploy this form on Adobe form server, the bar codes are not generated properly. The PDF shows around 20 such barcodes, but when I run it through decoder, I only get one or two barcode tags which do not contain any data. Further, any app.alert() tags put in XDP can not make it the PDF generated by Form Server. The log from JBoss reports "app is undefined".
When I take the same XML file and specify it as the default XML file for the XDP template under properties and the test the form in Live Cycle designer, the form is rendered perfectly with all javascript alerts and barcodes with full XML data.
I'm totally stumped on this one. Any help will be greatly appreciated.
Best Regards,
Sanket
