can i sort data in a table?
May 18, 2006 2:46 AM
hi everybody,
i have a table loading xml-data. i want the user to be able to resort the loaded data. is there a way to do it?
thanks very much,
valerio
    May 18, 2006 3:38 AM   in reply to (Valerio_Chiessi)
    There's no way built into the Table object to sort the data; you'd either need to sort it at the source, or write JavaScript code to sort it - there's a sort method for a JavaScript array, so if you can get the elements into an array, you can sort the array and then populate the table from that.
    SteveX
    Adobe Systems
    Feb 15, 2011 11:28 AM   in reply to (Valerio_Chiessi)
    Hi Valerio,
    Would you be able to share a pdf where you utilize this functionality?
    Mark
