On the first drop down list, use a javascript on the change event with the following:<br /><br />if (this.rawValue != xfa.event.change)<br />{<br /> soScript.updateCities(this.parent.DropDownList2, this.boundItem(xfa.event.change));<br />}<br /><br />Then create a script object (on the same level - right click on the parent node in the hierarchy view and select "Insert Script Object") named soScript with the following <br /><br />var g_arrayCities = new Array(<br /> new Array("Anaheim", "Los Angeles", "San Francisco", "San Jose"),<br /> new Array("New York", "Buffalo")<br />);<br /><br />function updateCities(objDropDown, nIndex)<br />{<br /> var arrayStateCities = g_arrayCities[nIndex];<br /> objDropDown.rawValue = "";<br /> objDropDown.clearItems();<br /> for (var i=0; i<arrayStateCities.length; i++)<br /> {<br /> objDropDown.addItem(arrayStateCities[i]);<br /> }<br />}<br /><br />Note: for the first drop down, I have set the "Specify Data Values" on the Binding Tab to attach an index to each State starting at 0.
