Adobe Reader Users can not submit form
Avatar
Former Community Member
Hello,
I have created a form with LiveCycle 8.0. The form has a submit button to submit a pdf of the completed form via email. The form works when I test it on any users computer with Adobe professional installed. However, anyone that only has Adobe Reader 8 installed can only open the form and enter data....the submit button will not work for these users.
Could anyone please give me some advice? I need users without Adobe Pro to be able to open, fill out the form, and send via the submit button/email.
Thanks for any help
Brett
Avatar
Hello,
I have created a PDF form in adobe Designer Live Cycle 7.0. I want to send this form in an email to people, have them fill out the PDF and then click SUBMIT and send it back to me. When testing I click the send button in my email client it just won't work. I set up the email SUBMIT node to "PDF" and filled out the mailto:xxxx@xxx.com. correctly. Again when it opens in the email client it just won't send.
Thank you to anyone who could help.
Tom
Avatar
Level 7
Sounds as if you may be trying to send a PDF (rather than form data)
from the free Reader.
Aandi Inston
Avatar
and the difference is??? please explain further. I am also trying to create a form.
When testing I can fill out the first line in the form hit send and the form gets sent.
If I put more info in the form when i hit send the email editor comes up, but instead of the send button i see this email was not sent. And I can not send it..
Anne
Avatar
Level 7
The difference between sending form data and sending a PDF?
The key difference is that Reader can only do the first! (Except for
Reader enabled forms).
Your problem does not sound related to the one above, I recommend
starting a new thread. In any case please use the right forum, the
original message we're all replying too was in the forum for LiveCycle
PDF Generator.
If the form is made in LiveCycle Designer, please try the LiveCycle
Designer forum. Otherwise please try the Acrobat Windows or Acrobat
Macintosh forum.
Good luck,
Aandi Inston
Avatar
Not very helpful are they... This is one way to do it (it's never easy in Acrobat).
Open as a Livecycle form
Select Window menu and make sure /Library/ and /Object are checked
Drag a print button from the pallet onto your form
Change the field type to button
Change the control type to submit
On the submit tab [Submit to URL:] enter "mailto:xx@xx.xxx"
Change the submit as filed to PDF
Save
Open the form in Acrobat Pro
Select advanced menu
Click enable usage right in Adobe Reader
Save
Avatar
I'm new to the Adobe LiveCycle world and was feeling quite confident in the forms I was creating, until I had the same problem that Brett Sarraiocco had ((05:17am Aug 3, 2007). I'm curious to learn if anyone was ever able to answer Brett's query (how to create a email-submittable form that users without Adobe Pro can open, fill out, and send via the submit button/email) or if anyone has further information. Thank you.
Avatar
Level 7
Yes, it has now been answered in considerable detail, even though it's
in the wrong forum.
Aandi Inston
Avatar
Lyle -
Thanks for answering the question so well. However when I got to the point of going into Acrobat and going to the Advanced Menu, I didn't have the choice of clicking "enable usage" ? Am I looking in the wrong place or maybe I have an old version (7.0). ? I think this is why my form is still not working. Thanks.
Avatar
Level 7
yes, this is new in 8.0.
Aandi Inston
Avatar
Lyle's method is what I also got from Adobe tech services. And it works, except for Mac Users. How come Macs can't use the submit button and how do I fix this?
Avatar
Level 7
For a mailto "submit" to work there has to be a compatible e-mail
client. There are millions of PC users who don't (e.g. people with
hotmail, gmail, yahoo), and many Mac users too.
"Submitting" by email is best thought of as a toy for testing, nothing
to be considered for a live system. For anything of any importance,
you need a web programmer to create a server-side solution on a web
server.
Aandi Inston
Avatar
Similar problem. I am hearing from those using Yahoo mail, that the form cannot be submitted from our organization's web site. Does this make sense to anyone?
David Jones
Avatar
Level 7
It does if you are trying to do an "email submit". This is one of many
reasons why email is only suitable for testing, not live applications.
Use http submit.
Aandi Inston
Avatar
I have done what Lyle Huff describe, it work fine, but every time I open the document (Acrobat free or Pro v9) I get an error (twice)
"this task is not autorize" (I have a french version and it's " Cette Opération n'est pas autorisée)
But after I click yes on the 2 same error messages, the document is working and I can send it via e-mail in Acrobat Reader...
Any idea what is the problem ??
Thank you
JF Fortier
Avatar
I've created a PDF in Nitro PDF X or whatever you call it and when i open it in Adobe reader 8.0 and try to fill it in and then save it it won't let me. I want to be able to send it out as an email and have the person at the other end fill it in and then email it back to me completed. I want to add a print button and an email submit button but I don't know how to?? can you please explain to me how I do this.
Avatar
I've created a PDF in Nitro PDF X or whatever you call it and when i open it in Adove reader 8.0 and try to fill it in and then save it it won't let me. I wnat to be able to send it out as an email and have the person at the other end fill it in and then email it back to me completed. I want to add a print button and an email submit button but i don't know how to?? can you please explain to me how i do this.
Avatar
HELP!
I need to submit a grant in Adobe READER instead of ACROBAT, I am at a loss as to how to do this and the grant is due NOW, can anyone help? anita@uvic.ca
Avatar
HELP -- I need to submit a grant application in Adobe READER not Adobe Acrobat. Very tight deadline, can anyone help me with this?? Doesn't make sense to me!
Avatar
Level 1
can you plaese tell me how you figured this out. I have Acrobat 7 and can not get Reader users to submit it.
