Parsing XML with Adobe Javascript
Feb 26, 2006 9:01 PM
I am using the standard SQL QPAC to fetch list data from a database. As we already know, the standard SQL APAC cannot retrieve multiple rows, but I use the "FOR XML AUTO" in my SQL statement so that all rows are returned in XML format.
I now only need to parse the XML and put the items into my drop-down list.
Does anyone have script samples that can parse XML from within LiveCycle? You would think that the capability exists since the product is based on xml/xfa.
Duncan Campbell
Xcellerate IT
    Feb 27, 2006 8:09 AM   in reply to (Duncan_Campbell)
    Are you looking to parse it in a script qpac? If so then you can store the XML in an xml process variable, then use getProcessDataValue() from PATExecutionContext to retrieve a Document object for the DOM.
    Chris
    Adobe Enterprise Developer Support
    Feb 28, 2006 8:47 PM   in reply to (Duncan_Campbell)
    Sure, take a look at the JavaDocs that come with the LiveCycle Workflow SDK. Under Documentation/api/LiveCycle_Workflow_SDK_API_Reference.
    FYI, in a script QPAC the PATExecutionContext is an implicit object accessed under patExecContext. In a custom QPAC it is a parameter to the execute method.
    Chris
    Mar 1, 2006 12:47 AM   in reply to (Duncan_Campbell)
    Hi Duncan
    If you have problems doing it that way, you can also download our SQLPlus QPAC, which will allow you to iterate over a result set and format the output in a number of ways, including a simple comma separated list. You can then use a simple script in the form to unpack the list into a dropdown.
    Howard
    http://www.avoka.com
    Mar 1, 2006 10:33 AM   in reply to (Duncan_Campbell)
    Duncan,
    It may be just as simple to write a QPAC that does the query and returns a comma-delimited list as a string. You could then have the form take that string as a hidden field and parse it into the drop-down list in the same method that Workflow provides the submission choice drop-down list.
    Clifton
    Mar 1, 2006 10:34 AM   in reply to (Duncan_Campbell)
    heh, Howard typed faster. :)
    Mar 2, 2006 7:58 AM   in reply to (Duncan_Campbell)
    You're getting an error because that XML is not well formed so a DOM cannot be built for it.  There needs to be a root node, something like enclosing all that in ....
    I'm attaching a simple workflow I exported.  It sets the value of an XML variable, and then using a script QPAC to call getProcessDataValue() and retrieve a Document object that can be used to parse the XML.
    Chris
    Calculating status...
    Aug 11, 2006 10:40 AM   in reply to (Duncan_Campbell)
    Duncan,
    Did you ever have any luck with this? Any additional pointers?
    I think I am going to do something similar. I am planning on sending in an email that contains XML data of just 9 fields (collected from a form online - outside of the LC system and then using the Email Receiver to collect the email. The email body is the XML data). So, I need to parse this out and set the elements to variables to populate my PDF form.
    If I get something working, I will try to post back.
    Jennifer
    Aug 14, 2006 2:49 AM   in reply to (Duncan_Campbell)
    Hi Jennifer
    You may be able to get a fair bit of it done just using the SetValue QPAC. I think (although I'm not sure) that you can use expressions like:
    /process_data/myxml/rootnode/row[2]/firstname
    So as long as you know the number of rows you want to process, you may be able to get by.
    Let us know how you get on.
    howard
    Aug 23, 2006 4:39 PM   in reply to (Duncan_Campbell)
    Hello,
    Actually, I ended up doing something a little different.
    Since I only have 9 fields to get parse, I did use the Set Value QPAC, but I used substring-after and substring-before functions. I had to do this in two different Set Value QPACS, I couldn't group them together for some reason. So, the body of the email contains my XML data and I set the body to a variables and then parse it out in those 2 Set Value QPACS.
    It works great!
    -Jennifer
    Jun 5, 2007 3:11 AM   in reply to (Duncan_Campbell)
    I could not able to retrieve the remote xml file(which means from server to another server) in Mozilla Firefox and some times inn IE also.
    I found the Error: "Error: uncaught exception: Permission denied to call method XMLDocument.load"
    please help me in this area if you find or knew.
    Thank you
    Jun 5, 2007 3:18 AM   in reply to (Duncan_Campbell)
    Hi Thiru
    It's a little difficult to work out what you're doing from your posting.
    I suspect it may be that you're trying to load a document in Reader. This is not allowed, you must use Acrobat. (Or reader enable the form.)
    Howard
