Feb 10, 2005 12:48 PM
I am really in trouble.
I have a Workflow Server 6.2, without Form Server, and I need to give my client a tool for design forms to use in the processes.
I am trying to create a form in Adobe Designer 7, saving it as PDF and using in my process (webaccess). It is not working. The AWS WebAccess presents me the PDF form without the valid actions (defined in the process) and the submit does not work.
My second option was using Form Designer 5, which can save the form as HTML for using with the workflow server. Well, it is not working as I wish. When I configure the task for using the HTML form, the workflow designer tells me that it is not possible to read the form fields. It does not understand the embedded XFT. It used to work with Workflow Server 6.1.
BIG problem.
Anyone have any idea about how can I create the forms (HTML or PDF) with Adobe Designer 7 (or even Form Designer 5) for using with Workflow Server 6.2 without the need of the Reader Extension and Form Server? Is there any AWS fix that can help me?
Regards.
