If you are referring to the Process Map you can read data from a MS AD by use of LDAP. During the initial install\configuration of AWS, you can configure the AWS Agent to connect via LDAP if that user, you are installing under, is so present on your LDAP server.
If you are referring to connections through the Adobe Form this too is made through a LDAP connection through the use of normal scripting methods.
Concerning, Interaction, not familiar its design\functionality but if its ODBC compliant then any sort of ADO connection should suffice.
Jon
