Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
Creating your first application
Avatar
Former Community Member
Hello,
I've downloaded manual "Creating Your First LiveCycle® ES
Application". I was following all the instructions there,
but when I try to start process in workspace I get an error:
An error occurred creating the form (task 109, form 0). (ALC-WKS-007-040)
Does anyone else have similar problems or this app. works fine?
any experience?
Avatar
Level 10
Error ALC-WKS-007-040 is usually a problem with rendering the form.
What render service are you using to render the form?
Can you post the content of the server.log file relevant to the error.
Jasmin
Avatar
I think I found the solution for this error.
In a Workbench ES we can create forms, and those are 2 kind of forms:
1) Adobe XML Form File (XDP)
2) Adobe XML Form File (PDF)
When I create a process and for initForm variable I chose an XDP form then I can not view the form in Workspace, and I get this error ALC-WKS-007-040. If in initForm variable I chose an PDF form then I
can see the form in workspace!!!!! :-)
But now I get to another problem ;-( Which type for the initForm variable should I use? I think I can not use for the type xfaForm.
I mean I've tried, but then even a simplest process (for example to submit the form to another user) is not working. I mean I can not submit the form.
I'll try to describe the process I've created:
I've deployed 2 components, first one is SetValue (Start Activity), and another is User component. I've created variable initForm, selected REQ., IN, OUT, as a type selected xfaForm, for the Template URL selected the PDF form.
At the user component, I've selected a user from Def.Domain (apink), and at the FormDataMappings tab I've selected the initForm as Input form variable, and Output form data. Also I've tried with different values at these fields but still it is not working!
Do you have any ideas?
Avatar
Level 10
You can use an xfaForm variable. What you need to is change the render service that's responsible for transforming the XDP into a PDF.
By default when you create an xfaForm variable (under Advanced Settings), the render service uses a Default render service which can only render PDF documents.
If you want to use XDP, you can select the render service called RenderPDFForm from the Sample - Forms category.
The set the following:
formURL to Task -> Form URL
inDocData (optional) to a variable that contains data to merge with PDF
targetURL to Custom Configuration -> targetURL
userAgent to Custom Configuration -> userAgent
Jasmin
Avatar
The different processes to render different documents are also described in the LiveCycle Workbench ES Quick Starts. You can also access the various Samples if you have them installed.
To access the quick starts, goto www.adobe.com/go/lc_learn_workbench and navigate to Quick Starts > Process Quick Starts. You should see a few Quick Sarts about Rendering Adobe XML forms. You may also be interested in displaying Flex applications which is described in Leveraging Flex applications in LiveCycle Workspace ES.
Hope that helps...
...Gilbert
Avatar
Thank you Jasmin and Gilbert!
Now I understand how to render xdp.
I was confused because in LC ver.7 I was using
xdp forms each time in my workflow
Thank you 1 again!
