Creating your first application
Sep 3, 2007 4:06 AM
Hello,
I've downloaded manual "Creating Your First LiveCycle® ES
Application". I was following all the instructions there,
but when I try to start process in workspace I get an error:
An error occurred creating the form (task 109, form 0). (ALC-WKS-007-040)
Does anyone else have similar problems or this app. works fine?
any experience?
    Sep 4, 2007 5:29 AM   in reply to (Stipe_Pavicic)
    Error ALC-WKS-007-040 is usually a problem with rendering the form.
    What render service are you using to render the form?
    Can you post the content of the server.log file relevant to the error.
    Jasmin
    Sep 14, 2007 5:40 AM   in reply to (Stipe_Pavicic)
    You can use an xfaForm variable. What you need to is change the render service that's responsible for transforming the XDP into a PDF.
    By default when you create an xfaForm variable (under Advanced Settings), the render service uses a Default render service which can only render PDF documents.
    If you want to use XDP, you can select the render service called RenderPDFForm from the Sample - Forms category.
    The set the following:
    formURL to Task -> Form URL
    inDocData (optional) to a variable that contains data to merge with PDF
    targetURL to Custom Configuration -> targetURL
    userAgent to Custom Configuration -> userAgent
    Jasmin
    Sep 14, 2007 7:37 AM   in reply to (Stipe_Pavicic)
    The different processes to render different documents are also described in the LiveCycle Workbench ES Quick Starts. You can also access the various Samples if you have them installed.
    To access the quick starts, goto www.adobe.com/go/lc_learn_workbench and navigate to Quick Starts > Process Quick Starts. You should see a few Quick Sarts about Rendering Adobe XML forms. You may also be interested in displaying Flex applications which is described in Leveraging Flex applications in LiveCycle Workspace ES.
    Hope that helps...
    ...Gilbert
