at org.apache.axis.message.SOAPFaultBuilder.createFault(SOAPFaultBuilder .java:222)
at org.apache.axis.message.SOAPFaultBuilder.endElement(SOAPFaultBuilder. java:129)
at org.apache.axis.encoding.DeserializationContext.endElement(Deserializ ationContext.java:1087)
at org.apache.xerces.parsers.AbstractSAXParser.endElement(Unknown Source)
at org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanEndElement(Unknow n Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContent Dispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Un known Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:375)
at org.apache.axis.encoding.DeserializationContext.parse(Deserialization Context.java:227)
at org.apache.axis.SOAPPart.getAsSOAPEnvelope(SOAPPart.java:696)
at org.apache.axis.Message.getSOAPEnvelope(Message.java:435)
at org.apache.axis.handlers.soap.MustUnderstandChecker.invoke(MustUnders tandChecker.java:62)
at org.apache.axis.client.AxisClient.invoke(AxisClient.java:206)
at org.apache.axis.client.Call.invokeEngine(Call.java:2784)
at org.apache.axis.client.Call.invoke(Call.java:2767)
at org.apache.axis.client.Call.invoke(Call.java:2443)
at org.apache.axis.client.Call.invoke(Call.java:2366)
at org.apache.axis.client.Call.invoke(Call.java:1812)
at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapAxisDispatcher.doSe nd(SoapAxisDispatcher.java:100)
... 4 more
The source code is:
public class UploadForm
public static void main(String[] args)
try
Properties connectionProps = new Properties();
connectionProps.setProperty("DSC_DEFAULT_SOAP_ENDPOINT", "http://myserver:40005");
connectionProps.setProperty("DSC_TRANSPORT_PROTOCOL", ServiceClientFactoryProperties.DSC_SOAP_PROTOCOL);
connectionProps.setProperty("DSC_SERVER_TYPE", ServiceClientFactoryProperties.DSC_WEBSPHERE_SERVER_TYPE);
connectionProps.setProperty("DSC_CREDENTIAL_USERNAME", "administrator");
connectionProps.setProperty("DSC_CREDENTIAL_PASSWORD", "password");
ServiceClientFactory myFactory = ServiceClientFactory.createInstance(connectionProps);
invokeMyService ( myFactory );
catch (Exception e)
e.printStackTrace();
private static void invokeMyService ( ServiceClientFactory myFactory ) throws Exception
ServiceClient serviceClient = myFactory.getServiceClient();
HashMap parameters = new HashMap ( );
parameters.put ( "confirmationNumber", "000000000012" );
InvocationRequest request = myFactory.createInvocationRequest( "QueryForm", "invoke", parameters, true );
InvocationResponse response = serviceClient.invoke( request );
Document xmlDocument = (Document) response.getOutputParameter ( "xmlDocument" );
The question is, I don't know if this is a client problem or on the server side. If it's the process problem, how can I tell if my process is working?
