Hi Hodmi,
I have opposit problem, where I had LiveCycle Designer and every time I distribute my form and submit the form, it is attached as PDF.
I want to submit the Form as XML, so I put a new button, and in the designed view -> submit as -> I selected XML data.
In the same time I selected Form Properties -> Defaults tab -> PDF render Format -> and I selected Dynamic XML Form.
After I save the form and distributed it, I submitted it, but the form is attached as PDF not XML.
I checked the Form properties and I found that is return back to PDF.
So Can you help me with this, why I could not change the form properties to XML.
I have a PDF of an insurance application that I have added fields to in LiveCycle Designer ES. We want the user to fill out the form and then email it to us.
When my test users open the PDF using only Reader, they have to go through all the steps to deactive PDF/A mode to see th fields needed to fill out.
My first question - how do I make it so the document does not open in this mode and actually displays the fields we need them to fill out?
Then my second issue is when the user tries to send me the form (after selecting to never show PDF/A mode!!!). I have tried implementing BOTH button types: Email Submit Button, which only sends me the XML data - NOT what I want.
And I tried implementing the standard button type and including mailto:tpepe@usli.com, submit as: PDF, and nothing happens for my test users with Reader when they try clicking this - BUT IT WORKS FOR ME (I have Acrobat 9 Professional).
I've read all of the posts within this thread and found nothing helpful.
I even tried the javascript add to the click event on a regular button but CLICK is grayed out for me!
Any help is greatly appreciated.
Thank you!
I've read through tons of posts and am simply trying to be able to provide a client with an interactive PDF that can be emailed once completed. I'm using Acrobat 7 Professional, added fields for data and a submit button which I have set using the combo box option and just a plain button. When I test in Reader I get the message "Operation not permitted." Can you explain, offer suggestions, etc.
I am working on a Mac running OS 10.3.9 but do have access to a Windows machine with XP. Any suggestions?
